If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the relative post easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
SOURCE: remote control for sky
I own a One-for-All universal remote (model URC-4220), and my booklet says the setup code for a Toshiba TV is one of the following numbers: 0060, 0154, 0156, 1265, 0695, 0845,1145,1045.
Hope these numbers help you out. Please take a moment to rate this info, by using the rating system below. Thanks.
SOURCE: Have a Toshiba 26A3000R TV
Sky don't list a specific code for the 26A3000R, but there are some generic codes for Toshiba TVs with a Rev 4 remote:
0536, 0581, 0063, 0473, 0530, 0746, 0121, 0742, 0173
Try each of the above codes until you find one that works the power and volume functions. If you have no success or you need code entry instructions, please post back and I will try to assist you further.
Regards,
BElectric
SOURCE: I do not know the
You should be able to buy a universal remote to fix this problem.
Can you get into your main menu.? If yes, try reseting to factory default. If asked a pass, try 0000.this should do the trick.
Hope this helps.
Toshiba
28W93B 2563DB
536 063 271 098 117 232 530 581 130 473 088 182 064 216 253 508
Toshiba
156T9B 175T9B 213T4B 2151TB 2197DB 2512DB 2535DB 2539DB 2550TB 2563DB 256T9B 28Z27B2 2812DB 2857DB 2835DB 2873DB 2877DB 28W93B 2500TB 3357DB 573DB 2879DB T1510T8 25001TB7 32DB 32M8DB 2855DB CT9689 2939DB 40PW03B MV40PWA 32M9DB3 2893DB 32317B 2573DB 337BB 2552D 36/21P 28207B 2173DB 285T8B 2173DB 28W8DBA 28N03B 2505 238DB 439J936 3377DB 2181TB 82Z27B 28W23B 32ZP18P 42PW33P 32NW2DB 28ZH37B 32W8DB 32ZP38B 32NW7DB 32WIS 28N33B VTV1400 2987DB
536
Toshiba
2101TB 213T4B 2573DB 32ZP38
581
Toshiba
3377DB
216
Toshiba
2987DB
253
Toshiba
2987DB 3339DB 2877DB 322D09B 2173D6 14N21B2 14N21B2
063
Toshiba
14T01B, 21TO1B, CT815, CT81500082B, CT824, CT832
746
Toshiba
TVD213B
726
Toshiba
CT90040
508
OK.
