Question about Toshiba Televison & Video
How do i switch a toshiba 20vl63b to video output without a remote
I want to connect a toshiba 20vl63b tv to a laptop to use as an external monitor. however i do not have a remote and i am unable to put the tv in video output.
  • 3 Answers
SOURCE: problems connecting computer to tv via dvi
Not sure if you have fixed your problem or not. When I hook up my pc to the ILO 32 HD...I ran DVI input for picture...you can also use HDMI if you like..I had a problem with sound and had to use a splitter and run sound into AV2 IN to get sound for some reason...your no picture...if you are getting a black screen, you need to set the resolution on your pc. VGA to 640x480 and SVGA should be 800x600 and XGA should set at 1024x768..most likely the last one is the one you need..and this is not a normal pc res....set your refresh rate to 60HZ. All this is done in the control panel/display/settings tab. Also remember that you need to change your source on the TV to the proper connection to see it...ie component, HDMI etc.
Posted on Apr 11, 2007
  • 179 Answers
SOURCE: Using external monitor with Vista
the problem with adapters is they dont always pass all information thru,,try changing the screen resolution on the laptop down a little
Posted on Dec 01, 2007
  • 43 Answers
SOURCE: Connect LG 42LY95 LCD to Toshiba Laptop
Hiran
can you use the vga source from your laptop to the pc input on the LG a standard vga monitor cable will do then set your laptop to output the vga signal
Scott
Posted on Mar 23, 2008
  • 90 Answers
SOURCE: philips 42" HDMI connection to VGA on laptop connection problems
why dont u just use the vga input and select vga from your input selection. it should work just fine. if not, email me back.
Posted on May 25, 2009
  • 5163 Answers
SOURCE: Switch the tv to video without the remote
On some Dynex TVs, there are control buttons on the side of the TV (Volume controls, Channel controls, Menu, Input and Power). Just press the Input button until you get to the correct source.
http://www.dynexproducts.com/products/televisions.html#support=open&active=false&pageNumber=1&subcategoryId=31-to-40&resultsPerPage=all
will let you find your model and get a copy of the manual to check where those buttons are on your TV.
I hope this helps.
Posted on May 09, 2010
How do i fix a split screen of my Toshiba c600d-t36b laptop
The quickest way to change the display output settings is to use the
display hot key (Fn + F5):
1 Press Fn and F5 simultaneously.
2 While holding down Fn, press F5 repeatedly until the setting
you want takes effect. Briefly pause each time you press the F5
key to allow time for the display to change.
This hot key cycles through the settings in the following order
(the last two options are available if an external monitor is
connected):
? Built-in display only
? Built-in display and external monitor (simultaneously)
? External monitor only
? Built-in display and TV (or other external video device)
? TV (or other external video device)
? External monitor and TV
? Built-in display and external monitor (extended mode)
? Built-in display and TV (extended mode)
? External monitor and TV (extended mode)
? Swap-Switch primary display between internal display
and external monitor when using extended desktop
Feb 12, 2015 | Toshiba Computers & Internet
Acer connect projector
Connecting an External Monitor or Data Projector
You can switch to an external monitor or data projector by two methods.
1. Connect the external monitor to the laptop's video port, power up the external monitor first and the laptop. The video information will automatically switch to the external monitor.
2. If you power up the laptop first then you can switch the video output to the external monitor by pressing the Fn key and one of the Function keys, depending upon your make and model laptop. You can also toggle between the external monitor or both LCD screen plus the external monitor or back to LCD screen only by pressing the Fn key plus one of the function key a few times.
Here is a list of key combinations for some of the laptops :-
IBM ThinkPad = Fn + F7
HP and Compaq = Fn + F4
Toshiba = Fn + F5
ASUS and Dell = Fn + F8
May 07, 2013 | IBM ThinkPad Computers & Internet
I would like to boot a toshiba satellite m105-s30401 with an external monitor as the laptop screen is busted and i would like to use an external monitor until i get a replacement screen, how do i get
You can switch to an external monitor or data projector by two methods. 1. Connect the external monitor to the laptop's video port, power up the external monitor first and the laptop. The video information will automatically switch to the external monitor. 2. If you power up the laptop first then you can switch the video output to the external monitor by pressing the Fn key and one of the Function keys, depending upon your make and model laptop. You can also toggle between the external monitor or both LCD screen plus the external monitor or back to LCD screen only by pressing the Fn key plus one of the function key a few times. Here is a list of key combinations for some of the laptops :- IBM ThinkPad = Fn + F7 HP and Compaq = Fn + F4 Toshiba = Fn + F5 Dell = Fn + F8
Mar 03, 2013 | Toshiba Satellite M105-S3041Notebook
I connected RGB from toshiba m45-s169 to tv. Had a signal but now cant get it back. Tried updating video driver. Help?
You can switch to an external monitor, TV or data projector by two methods. 1. Connect the external monitor to the laptop's video port, power up the external monitor first and the laptop. The video information will automatically switch to the external monitor. 2. If you power up the laptop first then you can switch the video output to the external monitor by pressing the Fn key and one of the Function keys, depending upon your make and model laptop. You can also toggle between the external monitor or both LCD screen plus the external monitor or back to LCD screen only by pressing the Fn key plus one of the function key a few times. Here is a list of key combinations for some of the laptops :- IBM ThinkPad = Fn + F7 HP and Compaq = Fn + F4 Toshiba = Fn + F5 Dell = Fn + F8
Oct 23, 2012 | Toshiba Satellite M45-S169 Notebook
Video connections
Sep 24, 2012 | Sylvania Synet7wic-bk-z2 Netbook
Which key outputs video (screen) to projector
You can switch to an external monitor or data projector by two methods. 1. Connect the external monitor to the laptop's video port, power up the external monitor first and the laptop. The video information will automatically switch to the external monitor. 2. If you power up the laptop first then you can switch the video output to the external monitor by pressing the Fn key and one of the Function keys, depending upon your make and model laptop. You can also toggle between the external monitor or both LCD screen plus the external monitor or back to LCD screen only by pressing the Fn key plus one of the function key. Here is a list of key combinations for some of the laptops :- IBM ThinkPad = Fn + F7 HP and Compaq = Fn + F4 Toshiba = Fn + F5 Dell = Fn + F8
Sep 17, 2012 | Dell Latitude D510 Notebook
How to connect a Monitor to laptop
Sep 06, 2012 | HP Computers & Internet
Connecting laptop to projector
You can switch to anexternal monitor or data projector by two methods.1. Connect the externalmonitor to the laptop's video port, power up the external monitor first and thelaptop. The video information will automatically switch to the externalmonitor.2. If you power up thelaptop first then you can switch the video output to the external monitor bypressing the Fn key and one of the Function keys, depending upon your make andmodel laptop. You can also toggle between the external monitor or both LCD screenplus the external monitor or back to LCD screen only by pressing the Fn keyplus one of the function key. Here is a list of keycombinations for some of the laptops :-IBM ThinkPad = Fn + F7HP and Compaq = Fn + F4Toshiba = Fn + F5Dell = Fn + F8
Jun 05, 2012 | HP Pavilion dv6200 Notebook
Unable to connect projector
May 20, 2012 | IBM Lenovo ThinkPad T510 Notebook
I need to install external monitor on my toshiba. help
You can switch to anexternal monitor by two methods. 1. Connect the externalmonitor to the laptop's video port, power up the external monitor first and thelaptop. The video information will automatically switch to the external monitor. 2. If you power up thelaptop first then you can switch the video output to the external monitor bypressing the Fn key and one of the Function keys, depending upon your make andmodel laptop. You can also toggle between the external monitor or both LCDscreen plus the external monitor or back to LCD screen only by pressing the Fnkey plus one of the function key.
Toshiba = Fn + F5
Aug 10, 2011 | Toshiba Satellite M55-S325 Notebook
Televison & Video Logo
56 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
