Question about Coleman 110561 Digital Compass
I've replace the battery and on the compass mode give me always ERR, I've lost my instruction manual and I don't know how to fix it.
  • Francesco Cesari Nov 11, 2012
    I've replace the battery, and when I put the display on the compass mode , doesn't work and shows always ERR, I don't Know how to fix the problem. NO problem with the time display, LA, or temperature.
How can I reset jeep compass comput(er) after replacing battery?
is this a compass car?
or are you say fiddling he electronic compass on a grand Cherokee.
or the compass on a compass, OMG.
if fiddling the electronic compass
the operators guide covers that.
lost that.
its here.
2004 and up
http://www.jeep.com/en/owners/manuals/
read the manual first, then ask for help of lost.
it is there, read it.
Feb 16, 2016 | Jeep Cars & Trucks
My Eurosonic 7 day programmable timer doesn't activate. I've lost the instructions, are they available?
1) Eurosonic appears to analog timer:
http://waterheatertimer.org/How-to-set-timers.html
2) There is new series of digital timers from china, also sold as Eurosonic:
Copy following link for possible manual. Always reset digital timers before programming.
http://waterheatertimer.org/Woods-timers-and-manuals.html#13568
3) Add a comment March 2013 and describe timer in detail
Mar 10, 2013 | Hardware & Accessories
My Canon EOS Rebel XS only takes pictures indoors (ERR. 01)
You didn't say which shooting mode you're using, but I'd bet you're in Manual mode and have dialed in a completely wrong aperture/shutter speed combination for bright lighting conditions. For example, 1/60th of a second and f2.8 in bright sunlight would be "burning out" your image, so the camera may be giving you an error message. Try using AUTO or PROG setting and see if the problem persists. If it does, try a different lens. You may have an incompatible mount, or one of the contacts may be damaged. If all else fails, try your lens on another Canon camera.
May 14, 2017 | Canon EOS Rebel XS 35mm SLR Camera
My WW78 scale keeps giving an ERR message when I stand on it.
Usually I change the weight by weighing one foot and then weighing again with both. And then I keep repeating that until my results are consistent. Then that result seems to be accurate
Feb 19, 2012 | Conair Weight Watchers® WW78 by Glass...
I put in a vcr tape and get err 2 this is a dvd/vcr player made by sylvania. the dvd player works fine
The instruction book will give a list of Error Messages and their meaning.
If you've lost the book go to Sylvania's website where there will be easy to follow steps to either viewing the book for the device or downloading and printing it.
Sep 20, 2011 | Sylvania DV220SL8 DVD Player/VCR
We've lost the instruction manual for our light switch timer so don't know how to reprogram it. Directions, please!! We've just replaced the battery.What buttons do we press in what order to...
Question posted under Intermatic timer:
Open following link to identify timer and download possible manual:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
IF Intermatic timer stopped working because battery failed, then all that's needed is to reprogram current time, because the original timer programs you set are stored inside timer forever until timer is manually reset using reset button.
If you have Intermatic ST01C timer, then open following page for ez instructions:
http://waterheatertimer.org/ST01C-program.html
If you need help programming specific timer, then get as far along in manual as possible, and then add a comment.
If you have different brand timer, than each brand has link that shows on Intermatic page.
Aug 10, 2011 | Intermatic Hardware & Accessories
I have a Casio PCR-T275, but the printer does not work well. The receipt just printed out half as it supposed be! Can u give me a hand on what to do? My email address is yunyun.c@hotmail.com
This is the standard problem with this model. The printer fails after a while as it has a short life span and prints only one side of the receipt. I've now lost count of the number I've replaced. You will need a new printer unit. It is not too expensive but it would be a good idea to sell it once you have it fixed. I've seen some machines that are on their fourth printer. If you don't have it in paper save mode so you only issue occasional receipts, it will race through printers.
Jun 28, 2011 | Casio Parts Cash Register PC Desktop
I've lost the instructions, so don't know the code for my 28" whel diameter bike
The specific product you're inquiring about is not showing in your post. Name the make and
model first, then we'll look for the manual. Then (maybe) find a solution. You might find it
at the manufacturer's support site.
May 15, 2011 | Cycling
TCM Digital Watch
v:* {behavior:url(#default#VML);}o:* {behavior:url(#default#VML);}w:* {behavior:url(#default#VML);}.shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 st1:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Cmpass (COM)
The integrated compass tells you the direction (e.g.SSW for south­southwest) as well as the number of degrees. To determine a direc­tion,hold the watch horizontally with the 12 o'clock position poin­ting in thedirection you want to know.
General information about the compass
The compass always points to the magnetic north pole.Maps are always drawn in alignment with the geographic north pole (verticallyupwards at 90 ). The declination angle denotes the deviation between themagnetic north pole and the geographic north pole. This deviation depends onwhere you are located. To obtain exact results, the declination angle must beentered into the compass.Remember to change the angle when travelling abroad.Within the UKthere is no need to change the angle because deviati­ons are only slight.Overleaf you will find a table showing the declination angles for a number ofcities around the world.A fault has occurred if the display shows"ERR" while taking a direction or calibrating the compass. Thecompass must be re-calibrated (refer to section after next) .
Table of declination angles
Amsterdam 01 W Little Rock 03 E San Francisco 15E Atlanta 04 W Livingston, MT 14 E Seattle 19E Bombay 01 W Munich01 E Shanghai 05W Boston 16 W NewYork City 14 W Toronto 11W Calgary 18 W Orlando 05 W Vancouver 20W Chicago 03 W Oslo 02 W Warsaw 04E Denver 10 E Paris 02 W Washington DC 10W Jerusalem 03 E Prague 02 E London 03 W Rio de Janeiro 21 W
Mar 05, 2008 | Tag Heuer cj1110.ba0576 Wristwatch
Coleman 110561 Digital Compass Logo
104 people viewed this question
Top Coleman Camping, Backpacking & Hiking Experts
Jim London
Jim London
weirdtop
Are you a Coleman Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
