Question about Cooktops
The blomberg MCE 614/2 glass ceramic unit does not turn on at all, although there is full power, 380V.
Perhaps it is a fuse that needs changing. Is that possible, if so, how is it done?
Telefunken spare parts australia
Try turning off the power for a short while to allow the p c board to re set itself turn it back on and individually turn on each elements for a few minutes. Good luck
Ray
Apr 16, 2014 | Kuppersbusch Glass ceramic induction hob...
The unit light (not the hot surface indicator light) in my GE Profile ceramic cooktop does not turn off although the burners are off.
Hi Danielle, I reviewed the manual for the GE JP350 cook top. Pg. 6 states:
"The UNIT ON indicator light will glow when any surface unit is on."
If the burners are all set fully to the Off position, this lamp should be off. The off position requires that the knob be pressed in to change to Lo, High or any position between (once no longer in the Off position, depressing the knob to change it is not required). If you're able to change the from Off position without pressing the knob, there is an issue with the switch - that may be contributing to the problem.
The cooktop is a 208 / 240 volt appliance. This is the highest voltage in your home. Voltages as low as 50 in the right circumstances can kill, and for this reason repairs must be performed with safety as the first priority. The cooktop sensors have determined that a control is on. If they are indeed off, there is a problem with either the sensor or one (or more) of the controls. You may have luck by locating the circuit breaker or fuse (2 pole 40 amp breaker or (2) 40 amp fuses) and removing power from the cooktop for a minute or two, and then restore power. This would allow the electronics to reset and if a logic problem - it would clear. If there is a hard fault somewhere, the indication would return again.
You should have the cooktop professionally serviced if the indicator fails to extinguish. I hope this helps & good luck!
Sep 16, 2011 | GE 30 in. Profile JP350 Electric Cooktop
How to repair cracked corner of black ceramic cooktop
Epoxy would not work. If it is a very small chip and is NOT STRUCTURAL or in the heated are you could TRY the adhesive used for rear view mirror to glass attachment.
Sep 13, 2009 | Jenn-Air 30 in.JGD8430ADS Gas Cooktop
I have kenmore ceramic top range model number 79096011407, the glass top is cracked and I want to replace it but don't know how it comes off the manual is lost. There are three screws above where the oven...
are u sure u want to replace the ceramic glass top,much beter to check the price of the unit, coz it is very expensive almost halt the price of the new one...dont try to replace it by ur self coz the glass cover is no waranty if u broke or wrong intallation,u waste ur money if hapen that,much beter to canvas first & call an expert tecnician to do it.
Sep 08, 2009 | Cooktops
TOUCH CONTROL HOB (SCHOTT CERAM) GLASS CRACKED
Hi. Yes you can buy a new glass. Most of the come with frame top now. If you get me the model # I can look this up for you and get you an idea on cost.
Vic
May 18, 2009 | Cooktops
Igniter
I should say that it very dangerous to service glass appliances if you are not trained. If you have any question of your abilities stop here and call the pro's. Although I think I can help. 1st turn off the glass and disconnect it from valve. 2nd unplug 110v plug. Remove the cook top from counter and lay it top down on a towel. There is a series of screws around the perimeter of bottom. Remove these screws. The bottom should lift away allowing full access to all components. hope this helps and good luck.
May 07, 2009 | GE 30 in. JGP336 Gas Cooktop
Whirlpool ceramic cooktop
Scott,
On each of the heating elements there is a thermostat that does two things. It is a high limit safety thermostat and then a different set of contacts turn on the hot surface light. Unfortunately, you can't just replace that part. You will need to isolate which element it is with a mutimeter and replace the entire element.When you turn one of the units on high you will see a dark line under the glass running 1/2 way across the elements. Those are the thermostats... Find the defective one and the rest is pretty simple to replace
Dec 18, 2008 | Whirlpool 30 in. RC8700 Electric Cooktop
Replace JED8430ADB Ceramic Glass
First, you have to pull out the cooktop from the counter and remove the knobs.
Next, there are hex screws around the perimeter - do not remove the lowest ones on the front and the back (they hold the tray that the burners sit in) or the ones on the bottom (they help to hold on the blower assembly).
The final trick are two screws that are located in the downdraft plenum - there's one on each side (you don't have to remove the two in the back or the front - those are for small covers only).
The glass should lift out.
When putting the new glass in, remember that the plenum walls fit on the inside of the glass (you won't see the top of the steel).
Nov 25, 2008 | Jenn-Air JED8430 Electric Cooktop
Can fuse be blown?
youl have to pukk out the unit and check the connection/installaiton. youll need to determine if you have proper voltage going to machine. ther if no fuse on the machine, more than like a power supply issue
Oct 30, 2008 | Whirlpool 30 in. RC8700 Electric Cooktop
Cooktops Logo
80 people viewed this question
Top Cooktops Experts
Dan Webster
Dan Webster
paulcarew
Are you a Cooktop Expert? Answer questions, earn points and help others
