I unplugged the cords to change the paper.
Now it doesn't print.
How do I get it working again?
The green light is on.
SOURCE: Hi, My Smart Label Printer
unplug your Smart Label Printer (slp430) from your pc,
go into your control panel, then to add/remove programs.
remove the slp430 software then reboot your pc.
DONT PLUG IN YOUR SLP430 yet...
reinstall the software that came with the label printer.
follow on screen instructions.
plug power in for the printer
then attatch to your pc.
if this doesnt work let me know ; )
Hi
Error 5C10 means a paper jam or the printer has
encountered an internal error. And error 6A00 is
caused due a paper jam in the sheet feed unit or near the print head. You can also reset the printer to resolve
this issue. On the printer press and hold the ON/OFF button or unplug the power
cord. Wait for 10 seconds, press power button ON/OFF button again. If this
doesn't resolve the error code then unplug the printer for 10 minutes. Also,
inspect the back panel of the printer for any paper jams. To clear the paper
jams---
Turn off the printer and disconnect the power cord
and USB cable. Remove the jammed paper slowly using the following procedure.
Open the rear cover to check if the paper is jammed. Pull out the cassette and
check if the paper is jammed inside the cassette area. Stand the printer with
the rear side down, holding the document cover. Press the tabs together and
pull the green cover toward you. Check if the paper is jammed. (If you were not
doing Duplex printing, you do not have to follow this procedure.) Close the
green cover and place the printer back to a normal position. Reconnect the
power cord and power on the printer. Confirm the Alarm light is off. Load paper
back into the ASF or cassette. Press to clear the message and continue
printing. If you are printing from application software, follow the
instructions displayed on your computer. Hope this helps... Please post back if
you need more information.
Daniel
