Question about Vacuums
I have a black and decker dust buster plus 9.6v..i am searching for a charger as mine has snap off
I bought it from target and its a hand vac and vac cleaner it is also lilac and white in colour
  • Vacuums Master
  • 18,402 Answers
Agent Don
  • 310 Answers
SOURCE: No problem. Just bought
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=553450
Generic problem for all Vacuums
Posted by jmrowe on Apr 28, 2008
No problem. Just bought a new Black & Decker Corded Hand Vac and want to register @ BlackandDecker.com/New Owner
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
I checked the website and if you go to the BlackandDecker.com website you can register on line clicking on the contact us tab @ the top of the page and then scroll down to register your product on line, feel free to contact the factory with the information listed below:
http://blackanddecker.com/
Contact Us -- Customer Service and Produce Support
1-800-544-6986 (M-F from 8am until 5pm, Eastern Time)
Black & Decker
101 Schilling Road
Hunt Valley, MD 21031 USA
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Posted on Apr 28, 2008
SOURCE: black & decker steam buster
Step 1 - fill the rear tank with water. Clip the tank onto the back of the unit.
Step 2 - plug the unit into the wall.
Step 3 - move the switch to "steam". You should hear the unit 'ticking' at the rate of about 120 clicks a minute (2 clicks a second). The clicking should be "kind of" loud until the water makes its way into the pump.
The clicking will get quieter as the water moves through the pump and into the heater. The book says that you should start getting steam in a couple of seconds. My experience is that you don't get a good head of steam up until the unit has been going for about 20 seconds.
Another recommendation: don't use "Spray" until the steam is really rolling out of the unit. It just overpowers the heater and slows your steam production.
Step 4 - Steam the spot you want steamed. If you want to soak the spot, use "Spray". Most of the really good cleaning power of the unit is through the steam, so use that more than spray.
Step 5 - Switch to Vacuum and **** up the moisture from the steaming.
Repeat Steps 4 and 5 until you're happy with the cleaning.
Step 6 - Empty the front tank, rinse it out. Empty the rear tank; you probably won't get all of the water out, but that's not a problem. If you use tap water, put in a couple of teaspoons of vinegar and let the unit run until you've sucked the last of the water/vinegar solution out of the tank. If you use distilled water in the rear tank, you might be able to skip this step.
Step 6 is intended to reduce the amount of lime scale that will build up in the pump over time. You should probably avoid stronger chemicals, since they are going to sit in the pump until you use the unit next, and the first few seconds of steam on the next use will have whatever chemicals you are using.
Posted on Aug 22, 2008
bulldogchief
  • 388 Answers
SOURCE: I think I need to replace the main battery in my small floor vac
I see my sense of humor is not appreciated...it was only a joke. Anyway, here is what you do: First, slide the battery cover off the bottom of the hand held unit. Remove the battery from the motor housing by pressing the tab on connector “A”; this releases the battery from the motor housing. Plug the new battery (LC-R064R2P) into connector “A”. When installing the battery the wires have to go in first and they must be placed in front of the battery or you'll never get the battery cover back on.
Posted on Oct 16, 2009
SOURCE: I lost the manual for the Black and Decker Scum
how long do you charge the batteries for the S300 Scum Buster
Posted on Aug 01, 2010
aquaman987
  • 927 Answers
SOURCE: I HAVE A BLACK &
I am not certain about this specific battery, however, if many batteries are unused for a long period of time, they can not be rejuvenated.
Try the switch in each position for 24 hours and if there is no action, it is probably not worth repairing.
Gary
Posted on Feb 20, 2011
It will not hold a charge. Been plugin for days at a time then it will run a minute then stop
Hello Karen, It sounds as though may have a bad battery or the charger is shutting down before the battery gets fully charged.
Nov 01, 2015 | Black & Decker CHV1210 Vacuum
How do I get more batteries for a dust buster?
You have 3 options:
1. You could do a search under the part number of the machine for a parts break out diagram.
2. Open the vacuum, and do a search for the battery when you see the part number on the old battery.
3. Call the manufacturer for assistance.
Oct 04, 2014 | Dewalt Black And Decker Vpx Cordless Hand...
Black & Decker 9.6 V Dust Buster --- how do you remove (for replacing) the rechargeable battery.
Response by small6363 was right on target. All the reviews and comments I had read up to this point for my Dustbuster CHV9600 indicated the battery could not be replaced. I am so glad this link was here.I have ordered the part and will follow the other posters' cautions about reassembling the product. I could not be happier as I could not find the model anymore and it is my favorite purple color. Thanks again small6363. You are a life saver.
Sep 12, 2011 | Black & Decker Vacuums
I HAVE A BLACK & DECKER DUST BUSTER CORDLESS VACUUM. I'VE HAD THE CHARGER PLUGGED IN FOR ALMOST 24 HOURS AND IT IS STILL DEAD. SHOULD THE SWITCH BE IN THE OFF POSITION OR THE MIDDLE POSITION. IT'S...
Gary
Feb 20, 2011 | Black & Decker AV1200 DustBuster Handheld...
Filters
Hi there - just found two packages of 2 filters each (SVF1) while cleaning out the closet, and searched for someone online who needs them - instead of posting on eBay and waiting. Are you still interested?
Aug 21, 2008 | Black & Decker SV3000R FloorBuster Upright...
I have a 7.2V Dust Buster Black and Decker cordless vaccuum and we have lost the little filter inside it. Where can I buy it?
I have a 7.2V Dust Buster Black and Decker cordless vacuum and we have lost the little filter inside it.
Where can I buy it?
Please include the brand name and model #
A lot of your local vacuum cleaner dealers carry the Black and Decker filters depending on the model #’s and I will post a few phone #’s listed below so you can order a filter. But 1st always check with your local vac dealer. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Black & Decker
101 Schilling Road
www.A-1Vacuum.com 1-800-657-1874 If you cannot find a local dealer near you they can ship you the parts UPS.
Don – The Vac Man
Go Ahead. Use Us.
Apr 30, 2008 | Vacuums
Black & Decker
101 Schilling Road
Go Ahead. Use Us.
Apr 28, 2008 | Vacuums
How do I empty this dust buster?
Most of this type have a bag filter that you take out, it is just insie the front part that you take off , then you can empty and clean it.
Dec 23, 2007 | Black & Decker CK1300 Dustbuster Wet/Dry...
Vacuums Logo
91 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
