Question about Whirlpool GH4155XP Microwave Oven
Microwave too hot
Recently all the food cooked in the microwave comes out in containers that are extremely hot, even the inside of the microwave is hot to touch why is this?
  • William Miller
    William Miller May 11, 2010
    It may be that the stirrer (if so equipped) has failed, the turntable system may not be working, or the magnetron may be failing.
    Please reply back with your brand and model number and how long you've had the oven so we can help you.
4 Suggested Answers
IrishDruid
  • 2712 Answers
SOURCE: Microwave heating problems
Many over-the-range microwave ovens suffer from intermittent problems caused by excessive moisture from the range/stove entering the microwave cabinet and collecting on the circuitry. Often the problem is with one or two simple connections that may need tightening or soldering. But, to repair these components, the microwave cabinet needs to be opened. So we recommend that you seek the assistance of a qualified appliance repair technician.
Posted on Oct 03, 2008
MicrowaveSvc
  • 9086 Answers
SOURCE: Microwave heats bowl but not food
First of all, you must be sure you are using a microwave safe container. If it is not marked as such, it is not.
Try heating a cup of water in a clear glass container. If it still does not work right, your stirrer may be bad.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
LIGHT BULB
I have a diagram at my site which helps you find & replace many GE cooktop and cavity light bulbs. It's at http://207.234.249.73/mwd/ge_lamp_replacement.jpg
If there's no obvious removable cover over the bulb (most often on the rear or side) and the owner's manual doesn't address it, then disassembly will be required.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Nov 27, 2008
  • 8909 Answers
SOURCE: Our new microwave heats the containers but not the
Check on the material the containers are made of. If they are not microwave friendly then they will cause problems.
Some materials are designed to "Roast" the contents by absorbing the energy.
Check with a Pyrex glass container and water. The glass should stay fairly cool.
Posted on Feb 01, 2011
What is convection cookong
A convection microwave is a combination of a standard microwave oven and a convection oven. It allows food cooked in the convection microwave to be cooked quickly, yet come out browned or crisped as in a convection oven. However, most cakes cannot be baked in a microwave oven - only those without an open grain structure, such as brownies. There are microwaves which contain electric browning baking elements. A true convection microwave has a high velocity forced air fan to circulate the hot air uniformly.
more about Convection microwave
May 28, 2016 | Microwave Ovens
Tip
Microwaves and how they work. ­T­he microwave oven is one of the...
Caption
--> ­T­he microwave oven is one of the great inventions of the 20th century -- millions of homes in America have one. Just think about how many times you use a microwave every day:
Caption
­You're running late for work, so there's no time to fix breakfast at home. On your way to the office, you stop to gas up your car. Inside the quickie-mart, you grab a frozen breakfast burrito and pop it in the microwave on the counter. Later that day, you have to work through lunch. By 3:00 p.m., you're starving, so you grab a snack-pa­ck of microwaveable popcorn from the vending machine and pop that in the break-room microwave. That night, after a really long day at work, you're simply too tired to grill out, so you dish up last night's lasagna and heat it up in the microwave...
As you can see, microwave ovens are popular because they cook food in an amazingly short amount of time. They are also extremely efficient in their use of electricity because a microwave oven heats only the food -- and nothing else. In this article, we'll discuss the mystery behind the magic of "meals in a minute" with microwave cooking.
­A m­icrowave oven uses microwaves to heat food. Microwaves are radio waves. In the case of microwave ovens, the commonly used radio wave frequency is roughly 2,500 megahertz (2.5 gigahertz). Radio waves in this frequency range have an interesting property: they are absorbed by water, fats and sugars. When they are absorbed they are converted directly into atomic motion -- heat. Microwaves in this frequency range have another interesting property: they are not absorbed by most plastics, glass or ceramics. Metal reflects microwaves, which is why metal pans do not work well in a microwave oven.
Microwave cooking ­You often hear that microwave ovens cook food "From the inside out." What does that mean? Here's an explanation to help make sense of microwave cooking.
Let's say you want to bake a cake in a conventional oven. Normally you would bake a cake at 350 degrees F or so, but let's say you accidentally set the oven at 600 degrees instead of 350. What is going to happen is that the outside of the cake will burn before the inside even gets warm. In a conventional oven, the heat has to migrate (by conduction) from the outside of the food toward the middle. You also have dry, hot air on the outside of the food evaporating moisture. So the outside can be crispy and brown (for example, bread forms a crust) while the inside is moist.
In microwave cooking, the radio waves penetrate the food and excite water and fat molecules pretty much evenly throughout the food. No heat has to migrate toward the interior by conduction. There is heat everywhere all at once because the molecules are all excited together. There are limits, of course. Radio waves penetrate unevenly in thick pieces of food (they don't make it all the way to the middle), and there are also "hot spots" caused by wave interference, but you get the idea. The whole heating process is different because you are "exciting atoms" rather than "conducting heat."
In a microwave oven, the air in the oven is at room temperature, so there is no way to form a crust. That is why microwavable pastries sometimes come with a little sleeve made out of foil and cardboard. You put the food in the sleeve and then microwave it. The sleeve reacts to microwave energy by becoming very hot. This exterior heat lets the crust become crispy as it would in a conventional oven.
on May 07, 2010 | Microwave Ovens
930w /27l. How do I use easy cook?
put food inside it in a glass container NeVer metal set time and temp and press start button .
Jul 10, 2015 | Microwave Ovens
Does the microwave rotate during cooking?
Most microwave ovens have a "stirrer" blade run by a small pancake motor to help avoid standing waves and hot spots inside the microwave cavity. And most modern microwave ovens have a turntable to turn the food, to provide even more even-distribution of heating.
Oct 15, 2014 | Microwave Ovens
Frigidaire Microwave heats everything except for food
Your fianc? employed a surefire method of killing a microwave oven. A simple perusal of the manual would have revealed the recommended cleaning method.
Feb 26, 2017 | Microwave Ovens
I have a Sunbeam SMO701A7E microwave and I want to permanently turn off all beeps ( food ready, food still ready, even start and stop) Is this possible?
Without physically cutting the wires to the sounder, no. If you remove the sounder, it will become possibly dangerous as one will not know, if not remembering, that the food inside is hot or cold and could cause an accident or food poisoning if not cooked properly.
Feb 23, 2011 | Microwave Ovens
Our new microwave heats the containers but not the food. Container is too hot to touch. Food "looks" hot, usually boiling - but food isn't even warm.
Feb 01, 2011 | Whirlpool MH2175XS Microwave Oven
My microwave is completely dead. I have checked the fuse in the plug and it is fine. Any suggestions?
What you are to do to solve the problem is to do a general troubleshooting on your oven below are instruction to follow.
The Microwave is a counter top model with a variety of preset cooking options, including timed cooking at a variety of power levels and sensor-cooking settings for popcorn, rice, beverages and single-serving reheating.
The sensor cooking and reheating features detect increasing humidity levels inside the microwave and automatically adjust cooking time for various types and amounts of food. This microwave also includes a turntable and an electronic control panel.
Instructions below are step by step solution for your oven
  1. Check to see if the microwave will start. If it will not start and the display panel is blank, you may have a power problem. Unplug the microwave and then plug it back in, making sure that all three prongs of the power cord are fully inserted into the wall outlet. If this doesn't work, check your home's fuse box. Reset the circuit breaker to restore if necessary.
  2. Ensure that the microwave door is fully closed. Press the Clear/Off button to cancel any previous cooking instructions. Re-enter your cooking program, including cooking time and food weight if necessary, and press Start.
  3. If "Err" appears on the microwave display, press the Clear/Off button and reenter your cooking program. The "Err" message will appear during the sensor-controlled programs (Popcorn, Rice, Beverage or Reheat) if the door is opened before steam is detected or if no steam was detected within the maximum amount of time allowed by the microwave. Be sure to leave the door closed during these programs, at least until time is shown counting down on the display panel.
  4. If your control panel will not work or if an "L" is displayed on the screen, press and hold the Clear/Off button for a full three seconds to unlock the control panel.
  5. If your sensor reheat program is resulting in under- or overcooked food, first try decreasing the amount of food in the microwave; the sensor programs are designed for single servings of food. The sensor reheat function works by measuring humidity inside the microwave--do not use a tightly-covered dish with this setting because no moisture will be able to escape and the food will overcook. Be sure that cooking containers are dry; moist containers will increase the humidity in the microwave and mislead the sensor, resulting in undercooked food.
  6. If your turntable is not rotating, first check to ensure that your food container is positioned so that it can freely rotate without hitting the microwave's interior walls; using a smaller food container can fix this problem. If the turntable still will not rotate, lift the turntable from its support and replace it carefully, ensuring that it rests evenly on its support.
Good luck.
Thank you and thanks for using fixya.
Nov 23, 2010 | Neff H5470N0GB Microwave Oven
My ifb microwave oven is getting hot outside while
Normally when u cook food in microwave the fod is cooked by microwaves, which means the heat is generated with in food. The temperature inside is never too hot and all the heat produced is absorbed with in the food.
On the other hand when the grill is switched on, a separate heatting element gets switched on. You can see this red hot element on the top side of inside of microwave. the heat from this element gets transferred to food through air circulation. But partof heat also gets transferred to the walls of microwave oven. This is the reason the wall feel hot during use of grill.
As i see ther is no problem with the microwave itself. Jut kep delicate thngs a bit away from the microwave.
Oct 17, 2009 | LG Microwave Ovens
When we first turn on the microwave there is like a mini-explosion and a fiery spark, but after that the microwave goes through its cycle and cooks the food. But we are afraid to try it again.
pls do not use any aluminum or metal material INSIDE the microwave, this can cause the problem
I assumed, but pls consider the ff info...
Be sure to use nonmetal utensils in the microwave.
For microwave cooking, cut meats and vegetables in uniform sizes to make sure that they cook evenly.
Paper plates, cups, and napkins can be used in the microwave. But don't use foil-lined paper products, paper towels that include nylon or synthetic fibers, or newspaper.
When using plastic roasting or cooking bags in the microwave, discard the wire twist tie and use a plastic fastener or a piece of string instead.
To ensure that food cooks fully and evenly in the microwave oven, stir food and turn dishes periodically while they're cooking.
Jul 25, 2008 | Microwave Ovens
Whirlpool GH4155XP Microwave Oven Logo
518 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
