Question about Coffee Makers & Espresso Machines
Gaggia Syncrony Compact led 29 blink! Help - Coffee Makers & Espresso Machines
    Genius:
  • Coffee Maker... Master
  • 1,669 Answers
Please read the attached manual...the English version is later on in the manual:
http://search.aol.com/aol/search?&s_qt=sb&q=gaggia+syncrony+error+code+29&tb_oid=07-01-2013&s_it=amonetizetest1-ie&tb_mrud=07-01-2013&tb_uuid=20130107163427450
also, try this to reset the machine to factory specs:
You can go through the menu and set the machine back to factory setting by pressing the menu button and using the up or down arrows(first 2 coffee buttons) until display reads Factory Settings, then press the menu/Ok button display will read No, use up or down arrow to select Yes then press Ok.
You can also turn off the rinse cycle using the menu.
Posted on Jan 14, 2013
mirran
  • 515 Answers
SOURCE: Gaggia Syncrony Compact
Try to make a cup of water, if you only can get a half cup then the flowmeter has to be replaced.
Posted on Jul 14, 2008
JohnnyBeans
  • 223 Answers
SOURCE: Gaggia syncrony compact coffee machine
It is very hard to say where the leak is coming from. If you can open the case of the machine a physically notice where the water is leaking from then we can tell you if you can repair it yourself or if you will have to find a service center.
Authorized Gaggia Repair Center
Cerini Coffee Services
New York, USA
www.cerinicoffee.com
Posted on Sep 12, 2008
SOURCE: Hi! Can you help me
What's the problem?
Posted on Apr 15, 2009
EsWorld
  • 1618 Answers
SOURCE: gaggia syncrony compact leaking water where
If you remove the tank, does it leak? If yes then check the spring loaded valve under the tank, also check the O-ring for damage.
Posted on Jun 06, 2009
EsWorld
  • 1618 Answers
SOURCE: GAGGIA syncrony compact coffee grinder motor is
Remove the brew unit and to the left of that is the the discharge area for the grinder, make sure that hole is clear, then adjust grind 1 number coarser, and check machine.
Posted on Jun 09, 2009
I have a Gaggia Syncrony Compact machine which I am trying to descale. I have added the descaler to the water in the tank. when you hold down the button (26) more than 5 seconds nothing happens.What is the...
To descale the appliance proceed as follows:
• Mix the descaler with water as specified on
the package and fill the water tank.
• Switch ON the appliance with the ON/OFF
switch (7).
• Press the button (26) for at least 5 seconds to
select the descaling operating mode; the LED
emits a fixed light.
I noticed you did not mention the switch ON before you pushed button 26. Try that should work.
Jan 12, 2014 | Gaggia Syncrony Compact Coffee...
The led 27 flashing no stop
Hi
If you are talking about the descale light, you must let the machine quit on its own. The pump has to stop on its own. Any interruption (you stopping the machine) will keep it in the descale mode. Once it stops on its own, the lights will change. Then do the rinse by replacing the water in the tank and closing and then reopening the steam knob and again letting the machine quit on its own. Again the lights will change. Then repeat the last cycle (putting water in the tank and closing and then reopening the steam knob)until all the red lights go away and you only have a green blinking light. Now your finished descaling a compact without a digital display.
Jan 06, 2010 | Gaggia Syncrony Compact Digital Espresso...
Jun 07, 2009 | Gaggia Syncrony Compact Coffee...
Water is leaking, while the machine heats water for steaming
The steam valve tap rod needs to be replaced, or check machine if it has a plastic steam valve, Gaggia designed a new Stainless steel steam valve for the compact machine.
May 23, 2009 | Gaggia Syncrony Compact Coffee...
Hi! Can you help me with a Gaggia Syncrony Compact Digital please?
gaggia syncrony ,The unit that goes into the side of the machine is jammed , can you help ?
Jan 17, 2009 | Gaggia Syncrony Compact Digital Espresso...
Gaggia Syncrony Compact Rote LED 28 blinkt
Try to prime your machine, if you only get a half cup of water then you have to replace the flow meter in the machine.
Jul 20, 2008 | Gaggia Syncrony Espresso Machine
Jun 22, 2008 | Gaggia Syncrony Logic 74884 Espresso...
Coffee Makers & Espresso Machines Logo
417 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
