Question about Pinnacle Studio Plus Version 11
Studio 11 want allow me to burn my project to dvd
I am using studio 11 to do a neighborhood reunion, I finished and went to burn it to a dvd and it will not burn so I let it sit over night and came back to it again today and now the voices have changerd up on me the voices are and its not playing right what can be done about this.
  • 50 Answers
I suggest to render the project to a video file first avi conversion to isolate the case. Once you have finish import the AVI file in the pinnacle did try to create now the dvd disc so that the rendering process will be fast since that you already have the file not the project.
Posted on Jul 08, 2009
I can not play my dvd on sony dvd player i get message canot play.i have a sony dvd recorder in which my laproscopic surgeries are recorded.if i play my unedited dvd on player it runs or plays very well...
My guess is the Pinnacle software isn't writing correctly. Read this from the Pinnacle support site.
Use this FAQ to troubleshoot any problems where Studio is failing during the process of burning the DVD.
  1. INSTALL THE LASTEST PATCH:
If you have Studio version 12, download the latest version here.
If you have Studio version 11, download the latest version here.
Note: Studio 11 patches will only patch a previous install of Studio 11.
If you have an older version of Studio (Studio 9, 10, or 11 etc), it is advised for you to update to the current Studio software. The current version is Studio 12. Click Here to go to the Studio 12 Upgrade page.
How to download and install a patch:
  • When downloading the patch make a note of where it is being saved to. We recommend saving the patch to the desktop.
  • Before installing the patch, make sure that you do not have any other programs running. Studio must not be running.
  • Once it is fully downloaded, double-click on the patch to begin the installation.
  • Follow any on-screen prompts to complete the installation. Reboot the computer after applying the patch.
  1. MAKE DISC SETTING, SAFE MODE BURN OPTION: In Studio, click on Setup -> Make Disc. Under the box marked Burn Options, select "Safe Mode: create disc content and then burn" by clicking on the radio button in front of the setting and then click OK. While troubleshooting this problem, always use this setting.
  1. RESTART STUDIO: Shut down Studio, then relaunch it. Try to create the DVD again using the safe mode setting above.
  1. RESTART THE COMPUTER: Try opening the door of the DVD burner. If it won't open, then shut down Studio, then restart the computer. Launch Studio and try to create the DVD again using the safe mode setting.
  1. MEDIA:
BLANK MEDIA IN THE DRIVE: Make sure that there is a blank, write-once media or rewriteable media in the DVD burner.
TYPE OF DVD: Make sure that your DVD burner supports the media you use. As for any problem with burning a DVD, we recommend customer use rewriteable media to reduce the number of wasted DVDs when they have to troubleshoot a failure while burning DVDs. In this case, if you have only used rewriteable media, (RW) we would also recommend trying to use a write once (-/+ R) DVD and erasing the RW media.
BRAND OF DVD: Pinnacle recommends using a name brand of DVD, i.e. Sony, Apple, Memorex, etc. Also we recommend trying a DVD from a different manufacturer to see if the problem is related to the brand of DVD that is being used.
NOTE: Check with the following site to find information on the media being used.
http://www.videohelp.com/dvdmedia
  1. LOWER THE WRITE SPEED: In the Make Disc settings try lowering the Write Speed to the lowest possible setting.
  1. GET THE LATEST FIRMWARE: Ensure that the DVD burner being used has the latest firmware update from the burner manufacturer.
  1. CHECK DISC SPEED: Make sure that the disc media speed (printed on the media or on the media box) is compatible with the DVD burner. Some burners may not work with media that has a higher maximum supported burn speed. For example, if the burner being used supports 4x disc media, do not use 16x disc media.
  1. DELETE AUXILIARY FILES: Try deleting the Auxiliary Files for the current project. To do this, go to File -> Delete Auxiliary Files and select "Delete auxiliary files for current project." Press OK and try to re-render and burn the project.
  1. ALWAYS RE-ENCODE: Go to the Make Disc settings and check the box called "Always re-encode entire movie".
  1. SAFE MODE: Try burning with the safe mode option selected. To do this, go to the Make Disc settings. In the Burn options are select the option called: "Safe mode: create disc content and then burn.". This step does not apply if you are using Studio 12 since this is the default burn method.
  1. CREATE A DISC IMAGE: In Studio, click on Setup -> Make Disc. Under the box marked Burn Options, select "Create disc content but don't burn" by clicking on the radio button in front of the setting and then click OK. Then click the Create disc button in the Make Movie section to begin the image creation process.
    If the image is not created, it is likely that the problem is a Render problem rather than a burn problem. Click Here to see the FAQ on Render problems.
    If the disc image file is created successfully, burn the disc from the new disc image by selecting "Burn from previously created disc content" in Burn Options.
    NOTE: When troubleshooting all burn or playback issues, it is recommended to use rewritable media to avoid wasting discs.
Nov 04, 2010 | Sony DVP-NS530 DVD Player
I burned a dvd in Pinnacle Studio Plus 11. I know stuff burned to the DVD, but it won't play on the computer or in the DVD player. Does Pinnacle not finalize the DVD, could that be why it's not playing? ...
Be sure to check if there is a file written on the DVD disk. Try to install a player like VLC and see if the .VOB file is playing.If not the DVD is not burned properly then try to recheck your settings on the Studio 11 Make Movie
Sep 13, 2010 | Computers & Internet
Whenever I try to burn a disc on Pinnacle 12 Ultimate the burn fails. Then it tells me that I need to use an empty or re-writable dvd. I then used an empty re writable dvd and still the burn failed, and it...
The new Pinnacle Studio 12 includes more than 25 new features and more than a ... This is an upgrade. so you need Pinnacle studio 11 first. ...... could you tell me if u have tried that on a different computer with out ..... of data of the Pacific and burn it then because a compact disc and then the ...
thepiratebay.org/.../Pinnacle_Studio_12_Ultimate_-_by_Mick_(Full_Version)
Jul 18, 2010 | Pinnacle Studio Ultimate 12 for PC
I cannot open my saved pinnacle studio 14 project because i have upgraded my os (windows xp to windows 7) please help.
New project stated in Pinnacle14 Ultimate. I have windows vista:
My project contained 900images. I burned to a dvd, all went well.
Next day, I opened the project and 3/4 of it was missing ! I alway's
save the projects after editing. This project has taken several months.. It is to be viewed next week at a grad party. Please, I need your help.
Thank you
gl
May 16, 2010 | Computers & Internet
CorelVideoStudio proX2,there is no burn option!!!
Check out the Corel Support website and download the patches and updates for Corel Video Studio Pro X2
http://www.corel.com/servlet/Satellite/us/en/Content/1153321224268?pid=1217273776985
Feb 28, 2010 | Corel Video Studio Pro X2 for PC
Pinnacle studio 12 .stx fil
Hi and welcome to Fix yah,
I would suggest to you to finished edit your project and after that click on make movie tab or the number 3 tab of your Studio then do this procedure.
Disc Type : DVD
Audio Compression : PCM
Video Quality : Automatic
Use Progressive Encoding : NOT checked
Always Re-encode Entire Movie: Checked
Burn Options: Create Disc Content and then burn.
Current Media : Should show what DVD Disc should be used.
Target Media: DVD 4.7 GB
Copies : 1
Write Speed: lowest possible
Let me know what happen.
Feb 14, 2010 | Pinnacle Studio Plus Version 11
When I add CD music to my photo-story it sounds
I went into Pinnacle homepage and downloaded on of the upgrades for Studio 11(cannot remember the name but it had to do with drivers). And that solved the problem!! It now works just fine!
PI
Feb 08, 2010 | Computers & Internet
Pinnacle 11.1 user dvd drive went bad /replaced dvd drive . since
Hi and Welcome to Fixyah,
What do you mean by this? what is the error message when trying to burn your project using Studio 11? Please reply back here.
Jan 04, 2010 | Pinnacle Studio Plus Version 11
Hi, The music added to my projects does not sound ok after burning them to DVDs. It sounds ok when played directly from the project file in Pinnacle Studio on my computer, but when burned to a DVD it...
Click on set up>video and audio preferences>unchecked background rendering>click on "used this codec for background rendering>click and choose MPEG2 for best output to disc. Now click on project preferences>click on delete button and then choose delete auxiliary files for all project and then click okay. Try burning your video again.
Nov 08, 2009 | Pinnacle Studio Plus Version 11
Creating a Disc project
Loaded a patch Studio 11.1.2 solution is valid for Pinnacle ultimate Ver 11
Jul 09, 2008 | Pinnacle Studio Version 9 for PC
Pinnacle Studio Plus Version 11 Logo
210 people viewed this question
Top Pinnacle Computers & Internet Experts
AL Schehr
AL Schehr
Level 1 Expert
Alun Cox
 Ian Kayhan
Ian Kayhan
Are you a Pinnacle Computer and Internet Expert? Answer questions, earn points and help others
