Question about Kenmore Dryers
Need`illustrated parts diagram for kenmore electric dryer 1106408840
Need `illustrated parts diagram for kenmore electric dryer 1106408840
  • 1 more comment
  • Anonymous Mar 18, 2014
    need parts diagram
    need parts diagram for kenmore dryer 11060982990
    Need illustrated parts diagram for kenmore electric dryer 11060982990
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
Here is a link to the parts and some diagrams.
Posted on Nov 09, 2012
4 Suggested Answers
docjohn174
  • 943 Answers
SOURCE: Kenmore Series 80 electric dryer
hi. i will send you to .repair clinic. go to dryers and belt diagrams. sorry i cant send you one. if you have any trouble, get back to me the appliance doc
Posted on Oct 02, 2008
kachbibi1
  • 979 Answers
SOURCE: Kenmore 90 series electric dryer blowing cold air only
1st check the breakers
2nd check wiring in back to see connections are secure.
3rd check element. It would be burned in two.
4th check thermal overload switch which is located underneath top of dryer. Easy to remove top. Probably 4-6 screws.
Posted on Jan 15, 2009
jsrock516
  • 5911 Answers
SOURCE: Kenmore electric dryer model 110.60942990 no
If the dryer runs, but does not heat, the following link explains how to troubleshoot an electric dryer with a no heat problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
First, begin by unplugging the dryer and verifying the voltage at the wall receptacle. You should read 220-240VAC across the two Hot terminals (left and right slots). If the voltage is incorrect, check to make sure you don't have a breaker tripped. Some homes use 2 separate 120VAC breakers to provide power to the receptacle vice using one 240VAC breaker.
If the voltage IS correct, leave the dryer unplugged and remove the cover plate on the terminal block in the back of the dryer (this is where the power cord is installed). Plug the dryer back in and take a voltage reading across the two hot (RED and BLACK) wires at the terminal block. You should read 220-240VAC. If the voltage is good, you have an internal heating problem. If the voltage is bad at the terminal block, but good at the receptacle, you have a bad power cord.
NOTE: If the wires at the terminal block are not color coded, the outer two wires (left and right) are the hot leads. The center conductor is neutral or ground.
The reason a dryer will still run if the input voltage is incorrect, is because the drive motor only uses a portion of the 220 service. The motor runs off 110-120VAC, while the heating circuits require 220-240VAC. So, if you are missing 1/2 your input voltage due to a tripped breaker or bad power cord, your dryer may exhibit these symptoms.
If you determine the problem to be internal, the heating circuits will either be located in the rear of the dryer on the right hand, or under the dryer drum on the right hand side. Usually, an easy way to determine is by the location of the lint screen filter. If the filter is on top of the dryer, the heating circuits are in the back of the dryer. If the lint screen is in the door, the heating circuits are located under the dryer drum.
All dryers are not constructed the same. However, the Heating Element is located inside a heater box. The Thermal Cut-Out (TCO) will be located on the outside of the heater box on the end opposite the heating element terminals. The Hi-Limit Thermostat will be located adjacent to the heating element terminals.
If either the TCO or Hi-Limit Thermostat are determined to be bad, replace BOTH components at the same time. That is why these components are commonly sold as a set. Failure to do so may result in premature failure of any parts you replace.
If the model number you have this listed under is correct, the part numbers are as follows:
Heating Element - 279838
TCO/Hi-Limit Thermostat Kit - 279816
All these parts can be found at appliancepartspros.com, searspartsdirect.com, pcappliancerepair.com, or repairclinic.com. The average cost of these components varies, so shop around for the best price.
All your heating circuits are accessible by removing the lower toe panel dire the rear of the dryer by removing the back panel. Just remove the screws around the perimeter of the back panel and the heating circuits will be located on the right-hand side. Refer to the exploded view diagrams at the websites2.gif I mentioned for reference. The heating circuitry is located under the "Bulkhead Parts" section.
If you have any questions, or require additional assistance, please let me know. I hope you find this helpful.
Posted on Nov 01, 2009
I need to replacement fuse for Kenmore electric dryer. model number 110.62212101
Sears Parts Direct lists all of the parts for the 110.62212101 here: www.searspartsdirect.com/model-number/11062212101/0582/0151200.html . If you need the dryer thermal fuse (3392519), that is part 9 on the Bulkhead diagram. The direct link to the part is http://www.searspartsdirect.com/part-number/3392519/0026/110.html?modelNumber=11062212101&categoryName=Residential%20Dryer&brandName=KENMORE . They also sell thermal fuse kit, http://www.searspartsdirect.com/part-number/3977393/0026/110.html?modelNumber=11062212101&categoryName=Residential%20Dryer&brandName=KENMORE .
Other vendors will have the part since the dryer is made by Whirlpool. Whirlpool used the parts in many models.
I hope this helps.
May 16, 2017 | Kenmore Dryers
How do I replace the heating element in a 11063032101 dryer?
KENMORE Electric Dryer Parts Model 11063032101
Link shows the parts explosion. You can click on various diagrams and find your part.
Sep 13, 2014 | Kenmore Dryers
Kenmore 1106408840 blower assembly noise
The bearings in the hub are worn out. You will need to replace the hub.
I replace a couple of these a month in the field. They made a slight design change to this hub so the new ones last quite a bit longer.
Here is the part to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 09, 2012 | Kenmore Dryers
The belt on my dryer broke I need to know how to replace it
This site has a good illustrated procedure to follow for changing your belt. (The site says Whirlpool, but it's the same for Kenmore.) It's not a tough job if you're patient and comfortable with simple tools (like a screwdriver). The same site sells the parts, and you can usually find the belt locally at a well-stocked appliance parts store.
Good luck with the repair, and thanks for using Fixya!
Oct 07, 2010 | Kenmore 64882 Electric Dryer
I have Kenmore dryer, which was running fine until the last load. The hot air is coming inside, but clothes are not drying since it was not turning around. I cleaned the vent, please let me know, what...
The problem is likely the dryer belt . Here is a video on replacing a dryer belt. It may be a different model but the process will be the same. You can also enter in your model # for diagrams and illustrations. Not all models are available. All parts come with installation instructions.
Sep 19, 2010 | Kenmore 63942 Dryer
Need a diagram for a dryer belt
Welcome to FixYa.
Follow the illustration which refers to the whirlpool dryers, that is the most common of Kenmore.
Let me know how you make out or if it is not too clear.
Good luck.
Regards,
Macmarkus :)
Sep 03, 2010 | Kenmore Dryers
My dryer wont heat up
It could be several things the heating element , thermal cut out, thermal fuse. Most of these parts are very inexpensive and all are easy to replace. There is a video at http://appliancehelponline.com/edryerelementvideo.html that can walk you thru the troubleshooting of your problem. It may be a different model but the troubleshooting will be the same. You can also get diagrams and illustrations of your specific model by entering your model #. All parts come with installation instructions. Not all models are available. If you need help disassembling your machine there are videos of this also for most styles.
Jun 04, 2010 | Kenmore 62802 Electric Dryer
We have a kenmore 90 series electric dryer that has recently started to leave clothes damp after a full cycle requiring another cycle to ensure drying. what repair should we try first
First check your venting if all is clear it could be several things the most likely the heating element , thermal cut out, thermal fuse. Most of these parts are very inexpensive and all are easy to replace. There is a video at www.appliancehelponline.com/servicemanual.html that can walk you thru the troubleshooting of your problem. It may be a different model but the troubleshooting will be the same. You can also get diagrams and illustrations of your specific model by entering your model #. All parts come with installation instructions. Not all models are available. If you need help disassembling your machine there are videos of this also for most styles.
May 06, 2010 | Kenmore 62602 Electric Dryer
Need a wiring diagram for Kenmore 110.63102101 dryer
Here you go, this is for both gas and electric units, since your unit is electric use the top diagram
Kenmore 6210 Dryer wiring diagram
May 01, 2010 | Kenmore 400 6942 Dryer
Diagram
That's a model "110" followed by a whole series of numbers. The 110 prefix identifies the manufacturer as Whirlpool. You need the rest of the number which is usually located on a nameplate along the door opening. Once you have the model number, any of the following repair sites are excellent sources for parts:
repairclinic.com
All these sites offer great service with competitive pricing, with the first two offering better exploded view parts illustrations. Shop all of them for the best price.
If you need assistance, please let me know. I hope this helps you.
Jun 29, 2009 | Dryers
Dryers Logo
121 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
