Question about Roland Boss Gt-10 Guitar Effects Processor Gt10 Open
My boss gt-10 takes long to load, flashing lights are at a irregular rythm and slow response while using wah pedal
This problem is temporary. even got that before. does anybody has a solution for that???
3 Suggested Answers
  • 5603 Answers
SOURCE: I am looking for an instruction manual for a Boss
Google is your friend... it found:
http://www.bosscorp.co.jp/products/en/_support/om.cfm?ln=en&dsp=0&iStcd=4&iCncd=50
Download your own.
Posted on Feb 09, 2011
  • 5603 Answers
SOURCE: will the Behringer fcv100
Put it between the GT10 and your amp and it should work fine.
Posted on Jun 19, 2011
Blue light Slash Wah pedal. After a few weeks the blue light has stopped coming on (I run it on official 18V adapter). Rest of pedal works fine, as before. Would love to have those blue lights working...
First thing to ty is to try it using two 9 volt batteries as a test to see if lights work.
I ASSUME that you are NOT trying to use the pedal in the external effects loop (send and return) as the levels are not compatible. The pedal must be between the guitar and the inout of the amp.
Beyond this I would open the unit and look for something loose or broken where the blue LED is located.
Sep 18, 2011 | Dunlop Manufacturing Dunlop SW-95 Crybaby...
Hi there, i got a 5150 half stack amp and the evh wah pedal, my problem is when i engage the pedal comes a terrible hum, i already change the cables, 9v battery and the ac adapter and the big noise...
WHY are you using a battery AND a 9 Volt adapter? This is an either/or thing. Chances are you have a defective ground someplace. Use just the battery and try it... If the hum is gone, the adapter is NOT compatible with the pedal. A lot of hum problems occur because the guitar is near a source of magnetic fields, such as an amp. An embarassing thing is for a musician to reverse the in and out connections to the pedal... it will have the symptoms you have mentioned.
Apr 24, 2011 | Dunlop EVH Wah Wah Pedal Wah
Ive got a delay ,chorus , wah ,distotion and compressor . how would i aet them in which order . thanks
Generally speaking, other than having hte compressor first to provide a consistant level to the other pedals, the order is personal preference. You need to experiment and determine the types of sounds you want. There is no "standard" order.
Dan
Feb 03, 2010 | BOSS AUDIO SYSTEMS Boss Dd-3 Digital Delay...
When i select the wah pedal funtion, it does not make the wah
You are apparently talking about an FX pedal with a built in wah function. Which pedal and model number? The Digitech RP350 for instance has a special procedure for initializing and recalibrating the pedal. Is that the problem or is it maybe the opto isolator ?
Jan 21, 2010 | Music
How to set up foot switch in order
Personally I recommend the following set up:
Distortion>Effects>Compression/Noisegates/Sustain
This will ensure that the signal won't have any odd hiccups due to an odd pedal setup. But if you play around with different orders, you can end up with some very interested sounds.
Nov 24, 2009 | Boss Mt 2 Metal Zone Effects Pedal
The correct order for Effects pedals.
Personally, I like to have all "tone effects", such as wahs, distortions and equalizers in front of "time effects" such as phasers, chorus, flangers and delays. See my set up in the photo. Guitar input is from right to left, starting with the wah pedal.
Tom, 30yr player
May 15, 2009 | Fender Hot Rod Deluxe Guitar Combo...
Ibanez Weeping Demon WD7 Wah pedal is not working properly
Sounds like a problem with the optical sensor. Your best bet would be to try to get a replacement from Ibanez or take it to a repairman. They are a resistor just like a pot but work by having an LED on one side and an optical "eye" on the other reading the amount of light passed thru transparent film. Morley has replacements for their wahs....not sure if its the same resistance. An audio repairman should hook you up.
Apr 14, 2009 | Music
Roland Boss Gt-10 Guitar Effects Processor Gt10 Open Logo
35 people viewed this question
Top Roland Music Experts
Vito Vacirca Jr.
Rabbit Brains
Rabbit Brains
Matthew Spark
Matthew Spark
Are you a Roland Music Expert? Answer questions, earn points and help others
