Hi everybody! This is a Xerox c2636 copier. As you can see in the video, all cables seem to be plugged in correctly. The control panel and the display don't power up, but I can hear the fan in this mo
  • 3 Answers
Most likely you have a bad screen panel. Reconnect all connectors to your main board. Also check the connector to your panel. Hope this helps
Posted on Dec 17, 2012
  • jardekorde
    jardekorde Feb 10, 2014
    You need a usb cable to get some picture to display ;)!
5 Suggested Answers
checkitright
  • 1362 Answers
SOURCE: U4 error code - Xerox 5328 copier
U4-2 Low fuser temp problem U4-3 High fuser temp problem U4-4 High fuser temp problem U4-6 High fuser temp problem
replace thermistor in fuser unit
Posted on Oct 06, 2008
SOURCE: copies are very dirty from xerox c2636. Really
1) magenta drum has already reach life span.
2)poor cleaning of magenta drum process unit.
3)recommended to replace the mageta process unit.
Posted on Sep 12, 2009
  • 2072 Answers
SOURCE: change belt cleaner?
You have to move or remove the finisher, depending what finisher you have.
Open the door on the right side of the machine . It is about 4 inches high and 14 inches wide.
Open the front cover and move the black bar to the down position as if you were replacing a drum.
Then on the right side, you slide the transfer unit out about 4 or so inches. On the front of that unit there are 2 torx screws held together with a black plastic strip. Remove those 2 screws, remove and replace the cleaner.
Posted on Dec 31, 2009
  • 241 Answers
SOURCE: Xerox Docucolor 12 not recognizing network controller
check ur fiery card that connect to copier
remove card clean any dust at the pins / slot lines then try
Posted on Mar 29, 2010
Power up a Xerox 8860 MFP printer
if the control panel display is completely blank but the printer works, you have a faulty panel. I can order it, feel free to contact me, its possible xerox will still cover this under warranty. Call xerox tech support, tell them the issue and see if the control panel would still be covered under warranty eventhough your machine is out of warranty. instructions come with replacing the part.
Mar 04, 2014 | Xerox Phaser 8860MFP Printer
Xerox work centre pro c2636 start up
Did you try turning power off at source and after a minute plug it in?
Jul 24, 2013 | Office Equipment & Supplies
Change k toner cartridge
The machine is asking for a Black Toner
If you have already changed it, double check that they ordered the correct part number, 006R01175.
It is also possible that there is something wrong with the toner you've gotten, if it's 3rd party or rebuilt etc.
Whit
Item, Inc.
Sep 10, 2010 | Xerox WorkCentre Pro C2636 Color Copier
Need to remove the finisher from a xerox 2636
Open the front door, there is an opening to the left under the transport . You reach in that opening and there will be a plastic block about 3 or four inches in the finisher. You pull that latch toward youself and that will inlatch the finisher from the machine.
Unless it is an office finisher in which you would have to remove thumb screws under a plastic cover on front, disconnect the plugs from the finisher to the machind and then lift the finisher up off the rails .
Aug 19, 2010 | Xerox WorkCentre Pro C2636 Color Copier
Change belt cleaner?
Dec 31, 2009 | Xerox WorkCentre Pro C2636 Color Copier
Copies are very dirty from xerox c2636. Really dark cast of magenta on each copy.
Sep 09, 2009 | Xerox WorkCentre Pro C2636 Color Copier
Xerox 6360 control panel blank
If your Xerox Phaser 6360 has either garbled characters, inverted or upside down display, or no display, the control panel is most likely bad and must be replaced. Here's a video on how to do it and where to get it. Hope it helps!
Mar 30, 2009 | Xerox Phaser 6360 Laser Printer
Display on Xerox Phaser 6350 not working unable to network printer
Defective Control Panel. In early 2006 a defect was found with some of the Phaser Control Panels. This has been corrected in manufacturing and new versions of the control panel placed into inventory. Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. Try the Engine Only test print on the rear of the machine. If the print is successful, the display is defective and needs to be replaced. Using the Centerware IS (CWIS) and using the Support Tab will connect you to Knowledgebase for any procedures on how to change this control panel. Contact Product Support, 800-835-6100 for any other questions regarding this issue.
May 01, 2008 | Office Equipment & Supplies
242 people viewed this question
jasbo
jasbo
