Question about Kenmore Dryers
Kenmore 1106408840 blower assembly noise
Hub axle moves back and forth and fan blade rubs against housing
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
The bearings in the hub are worn out. You will need to replace the hub.
I replace a couple of these a month in the field. They made a slight design change to this hub so the new ones last quite a bit longer.
Here is the part to order.
The part comes with a 365 day, any part, any reason return policy.
Posted on Nov 09, 2012
  • Sandor Lipschultz Nov 12, 2012
    This seems to be the problem. However, the original part has no bearings but many of the components are damaged and I'll replace the part.
4 Suggested Answers
Healeyman
  • 1198 Answers
SOURCE: Maytag dryer model MDET336AYW making
Check for a center bearing worn out.
Posted on Apr 22, 2009
  • 126 Answers
SOURCE: The blower wheel on my dryer has begun to rub against the panel
your blower is held onto shaft with 2 clips,inner and outer.loosen bolt slightly and you should be able to push blower back a little be careful not to loosen too much ,they can be a pain to realign.Hope this helps,please rate my solution.:)
Posted on Jun 25, 2009
heatman101
  • 43501 Answers
SOURCE: maytag dryer model MDET236AYW drum rubs against
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Posted on Feb 21, 2011
Loud noise coming from top of Rheem Power Vent gas water heater started this afternoon-- possibly a fan issue?
The "whisper quiet" blower could have a bad bearing, bad bushing, or the blade might be rubbing against part of the cowling. If rubbing against metal, you might be able to realign where it no longer rubs. Careful, it may be very hot!
Jan 21, 2018 | Rheem Water Heaters
Minka f502 is noisy - how do you tighten the screws that attach the fan blade to the motor hub?
With a screw driver? And perhaps you also clean all blades. Sorry if you already did that.
Mar 16, 2015 | Minka Aire Ceiling Fans Gyro Traditional...
Frigidaire dryer blower fan keeps getting stuck.
Since you didn't leave a model number, I will have to give you a generic answer, instead of one with a part number of the most likely replacement part. Normlly the problem you discribe is a result of the blower motor bearing wearing out and letting the fan blades rub against the housing. And since the bearing is internal to the motor, you have to replace the entire motor.
Dec 30, 2011 | Frigidaire Dryers
My 1988 Ford Tempo's heater fan is not working. I can feel heat at the windshield vents,but the fan wont come on. I have jumped the fan speed switch with a paper clip--and blew a fuse--and checked the...
your circuit is simple--I will paste it below. suspect the blower has shorted and caused the switch to burn up. remove the blower and hotwire it to the battery to see if it works. If not, replace the blower. Then run continuity tests on the swoitch and replace switch if bad. If you have questions, please let me know. Here is procedure for taking blower out:
REMOVAL & INSTALLATION With Air Conditioning
  1. Disconnect the negative battery cable.
  2. Remove the glove compartment door and glove compartment by removing the retaining screws and bolts. Push the sides of the glove box in to free the drawer from dash panel.
  3. Loosen the instrument panel at the lower right hand of the glove compartment opening. This is on it necessary if the panel is in the way of the motor housing.
  4. Remove the retaining screws securing the ducting around the blower motor.
  5. Remove the clip securing the blower motor fan blade to the motor arm. Remove the fan blade from the motor.
  6. Remove the blower motor mounting plate from the evaporator case by unscrewing the retaining screws.
  7. Rotate the motor until the mounting plate clears the edge of the glove compartment opening and remove the motor.
  8. Remove the wire harness from the rear of the motor.
  9. Inspect the fan blade for broken edges or cracks. Replace if needed.
To install:
  1. Connect the wire harness to the rear of the blower motor.
  2. Install the motor into the case and secure with the retaining screws.
  3. Position and fasten the fan blade to the blower motor arm. Secure with the clip.
  4. Secure the blower motor outer housing to the duct assembly with the retaining screws.
  5. Install the instrument panel at the lower right hand side if removed earlier.
  6. Install the glove compartment door and glove compartment.
  7. Connect the negative battery cable.
  8. Run blower motors to make the motor works correctly.
Without Air Conditioning
  2. Remove the right ventilator assembly.
  3. Remove the hub clamp spring from the blower wheel hub. Pull the blower wheel from the blower motor shaft.
  4. Remove the blower motor flange attaching screws located inside the blower housing.
  5. Pull the blower motor out from the blower housing (heater case) and disconnect the blower motor wires from the motor.
To install:
  1. Connect the wires to the blower motor and position the motor in the blower housing.
  2. Install the blower motor attaching screws.
  3. Position the blower wheel on the motor shaft and install the hub clamp spring.
  4. Install the air inlet duct assembly and the right ventilator assembly.
  5. Connect negative battery cab
  6. Check the system for proper operation.
Oct 21, 2010 | 1988 Ford Tempo
I have a model 5BS520C. The light works but when I pull the chain for the fan, I hear the sound of three speeds but the blades do not turn. ed.pfohl@gmail.com
Here some toubleshooting:
Problem 1. Fan will not start.
Probable Cause
1. Fuse or circuit breaker blown.
2. Loose power line connections to the fan, or loose wire connections in the switch housing.
3. Reversing switch in neutral position.
Suggested Remedy
1. Check main and branch circuit fuses or circuit breakers.
2. Check line wire connections to fan and switch wire connections in the switch housing.
3. Make sure reversing switch position is all the way to one side.
WARNING: Make sure main power is turned off.
Problem 2. Fan sounds noisy.
Probable Cause
1. Blades not attached to fan.
2. Loose screws in motor housing.
3. Screws securing fan blade flanges to motor hub are loose.
4. Switch housing binding against the blade hub.
5. Wire connectors inside switch housing rattling.
6. Screws holding blades to flanges are loose.
Suggested Remedy
1. Attach blades to fan before operating.
2. Check to make sure all screws in motor housing are snug (not over-tight).
3. Check to make sure the screws which attach the fan flanges to the motor hub are tight.
4. Check to make sure that the switch housing does not bind against the blade hub.
5. Check to make sure wire connectors in switch housing are not rattling against each other or against the interior wall of the witch housing.
6. Tighten screws securely.
Problem 3. Fan wobbles
Probable Cause
1. Setscrew in motor coupling is loose.
2. Setscrew in the hanger ball/downrod assembly is loose.
4. Fan blade flanges not seated properly.
5. Hanger bracket and/or outlet box is not securely fastened.
6. Fan blades could be out of balance.
Suggested Remedy
1. Tighten the setscrew in the motor coupling.
2. Tighten the setscrew in the hanger ball/downrod assembly.
3. Check to be sure screws which attach the fan blade to motor hub are tight.
4. Check to be sure the fan blade flanges seat firmly and uniformly to the surface of the motor hub. If flanges are seated incorrectly, loosen the flange screws and retighten.
5. Tighten the hanger bracket screws to the outlet box, and/or secure outlet box.
6. Interchanging an adjacent (side-by-side) blade pair can redistribute the weight and result in smoother operation.
WARNING: FOR YOUR OWN SAFETY TURN OFF POWER AT FUSE BOX OR CIRCUIT BREAKER BEFORE TROUBLESHOOTING YOUR FAN!!!
Hope helps.
Sep 02, 2010 | Monte Carlo Dryers
Weatherking heat pump sounds noisy but has a 20 degree air difference from intake to vents, is this normal?
Without hearing the "noise" it is difficult to diagnose via internet; however, I can tell you that the 20 degF temperature difference is a good sign.
If the noise is at the outdoor unit, try to determine if it is the casing or something else. Sometimes the casing can rattle and/or vibrate that can cause a sound. Sounds can also come from refrigerant lines rubbing against the casing. Other noise sources at the outdoor unit are the fan motor, fan blade assembly, and compressor. You can remove one of the fan motor wires from the contactor, tape off the end, and start up the unit for a few seconds to see if the noise is still present. Then you can replace the wire and remove the compressor wires from the contactor and repeat the test. This will help you determine where the sound is coming from.
If the sound is coming from your indoor unitl, the most common sources are loose tape, Blower wheel, blower motor, or blower housing. Also look for loose panels.
Without being onsite with toolbox in hand and being able to actually hear the sound, I hope you find this information to be helpful to you moving forward. :-)
Jun 07, 2010 | Weather King 12AJA4801AH Air Conditioner
Kenmore Dryer 110 is making a loud squeaking noise.
Only a few things will make that noise. The squeaking is caused by a moving part having trouble turning while rubbing against a fixed part.
  1. The idler pulley is worn
  2. The drum support rollers are hard turning on their shafts
  3. The felt seals at the front or back of the drum is worn allowing metal to metal contact while turning
  4. An article has fallen into the housing around the blower wheel and the wheel is rubbing on it.
Listen for the frequency of the sound. The drum rollers and drum felts will squeak at the frequency of the tub turning. The idler pulley turns much faster as does the blower wheel. Knowing this will help pin down the cause.
The following link has valuable information on taking apart your style of dryer:
Sears Dryer Disassembly
Sep 20, 2009 | Kenmore Dryers
Goodman GMT115-5B, loud noise when turned on
In the lower portion of the furnace you'll see where the blower housing is hung in the center of the furnace. There are two bolts you'll need to remove to pull out the whole housing. Depending on the size furnace you have you may have to unmount the control board and set it aside. Don't worry there is no need to remove the wires from the board. Once you have the housing out set it on its side (motor side down) and you'll see a shaft where the blower wheel mounts onto the motor shaft. There should be a bolt you can tighten. first loosen the bolt and put the housing right side up. after that center the wheel on the shaft so that neither of the sides of the wheel are rubbing on the housing once you find that spot where the wheel spins without rubbing tighten that bolt on the shaft and reinstall. should the problem persist you may need to replace the blower housing and/or wheel. I doubt the motor will have to be changed.
Aug 15, 2009 | Goodman GMS90703BXA Heater
Noisey fan
In my case noise was coming from the plastic blade rubbing against the sheet metal housing. I removed the motor and added 2 washers to the mounting screws. The washers acted as spacers and lifted up the motor/blade assembly with respect to the sheet metal housing. The blade no longer rubbed against the housing and the noise stopped.
Dec 08, 2007 | Broan-NuTone N-8664RP Combination Light...
Lous Noise
It could be the blower fan is loose and needs to be tightened. If so, and you're handy, shouldn't be too difficult. Depends on the specific design.
Jun 16, 2007 | Kenmore 72175 Air Conditioner
Dryers Logo
305 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
