Question about EA - Electronic Arts Word Whump Deluxe for Windows
I have two Polk Audio speakers connected to my HP computer ... but there is either no sound, or low sound. Right now, no sound. I don't know how to properly connect them, so I don't know what I am looking for. Help! Thanks, Carole
  • 164 Answers
Go to control panel, sounds and advanced, make sure desk top speakers is marked.
Also if they are not** computer speakers, your computer may not have the power to drive the speaker. Do you use a sound card or built in? get the drivers for then as well.
make sure you defragment your computer monthly.
Posted on Feb 19, 2009
I have windows xp, my speakers are Polk Audio HP-3, I am not getting any sound, but they play in other things..can you help me please?
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Apr 09, 2011 | Polk Audio AMR50 Computer Speakers
I have polk audio speakers that came with my old hp f50. I just purchased a new hp but can't get my speakers to work
The old speakers are not compatible. Your new computer is looking for an external power source for the speakers, the older polk speakers that came with Hp computers have none.
Sep 15, 2010 | Polk Audio AMR50 Computer Speakers
Sound is too low
Go to START>Control Panel>Sound HQ/Sounds and Audio Devices or something similar. Make sure your speaker volume is up (Move the sliding tab to the right). And that your Speakers Volume is up(A tab on the bottom area of sounds, in advanced tabs, or properties. Slide the tab to the right for louder, left for quieter) and make sure your Mute button is UNCHECKED.
Have a good one :)
Jul 24, 2010 | Polk Audio AMR2 Computer Speakers
I just upgraded from a hp pavilion to a dell computer with windows xp.I have polk speakers but they do not work. Don't know their model no. They worked fine on the H.P. HELP!
Hi , make sure you have correctly , installed the drivers for the sound card or Motherboard you are connecting into your laptop...and make sure it is compatible with XP
Happy new year
Hope you come right bud :D
Dec 27, 2009 | Polk Audio AMR50 Computer Speakers
Changed computer but using same speakers but no volume
Hello there:
if the volume controle is not on the taskbar try to go under controle panel and go to sounds and the adjustments for the speakers will be there. than click on add to taskbar and click apply when finished ok?
best regards mike
Aug 18, 2009 | Polk Audio Audio Players & Recorders
I have had a set of Polk Audio SDA1 speakers that I had attached to an old but great Pioneer SPEC-1 pre-amp and SPEC-2 power amp. The old speakers had one connection for the right speaker positive and...
bi-wiring requires the removal of the copper jumpers between the hi and low speaker terminals. you can use two wire pairs twisted together at amp out connections and the four separate ends at each speaker, but the quality of sound will not be as good as buying quality bi-wire cables. But a pair of quality single set of wires at each speaker would be fine, but put jumpers back on and attach to the top terminals, they are designed that way. bi-wiring does allow the crossover to put out a little better sound. Hooking up four sets of wires to the a and b speaker terminals sounds bad. i have had alot of trouble with my rti10's and learned the hard way that it is best to pay more for wires with quality terminations.
Jun 21, 2009 | Polk Audio RTi A7 Main / Stereo Speaker
Polk audio ext speakers on hp pavilion no sound, worked fine the other day?
OK... I was just going crazy looking for the same solution. I had let the Verizon guy hook everything up for me (It's a desktop) after I changed offices. He hooked up the plug to match the color of an input on the computer, but he had plugged it into the WRONG one.. heheh... If you have access to the back of your computer - be sure it's plugged in correctly there. (Other plug ins I tried gave me very low sound) My computer - an HP pavillion has two orange inputs - not near each other - but the other one has a little pic of speaker. (LOL).... or (CQ - chuckle quietly)...
Mar 25, 2008 | Toshiba Portege 4010 Notebook
Low sound from speakers.........polk audio speaker
Hello Minikish
well, some DELL models, have an internal audio, and it is cheap sound card, others have problems with this sound cards, and must be replace. or if you want to buy a PCI X-FI from creative, really Rocks the sound to a new level 5.1 surround sound, up to 7.1
Dec 06, 2007 | Audio Players & Recorders
Polk Audio Speakers
hi Hubbell2008
And Happy Holidays
well, as you can see depending on your audio card, and output power, and sound settings on control panel, if is all up, or down.
you can try that first. But if not work is and Audio Card, type of power output, that case you can change your audio card, if an onboard audio, place a PCI and will be ok, Creative labs models makes diff.
Dec 04, 2007 | Audio Players & Recorders
EA - Electronic Arts Word Whump Deluxe for Windows Logo
74 people viewed this question
Top EA - Electronic Arts Video Game Consoles & Games Experts
James Wishart
Adam Jasar
Level 1 Expert
Nikki  Mclean
Nikki Mclean
Are you an EA - Electronic Arts Video Game Console and Game Expert? Answer questions, earn points and help others
