Are you using the charger that came with the phone? I ask because I've run into in the past that if you try and use a different charger it may not work on your phone. you should use the one that came with the phone. having said that, you might want to try a different usb charger if that doesn't work it's probably the battery. Li-Ion batteries have charging circuits built in that can fail and also prevent the battery from charging if it's gone bad.
