Question about Baby Gear
Who has good methods to select a good coil spring mattress?
Recently I want to buy a coil spring mattress. So please give me some idea.Thanks
When should I replace my mattress?
Depends how often you flip your mattress? I suggest it be flipped every 6 months use so I've used Daylight savings time is a good reminder to turn it over and also rotate the Head to the Feet as well....Here's a good video
Jan 07, 2016 | Furniture
What is the best "value" mattress
The best value mattress is that which would provide you a comfort and high-quality sleep without causing any disorders like body and muscles pain.
I would like to suggest you some most used high-quality mattress:
a. Needle and Tuft Mattress
b. Zinus Green Tea Mattress Memory Foam 12 Inch
c. Independently-Encased Coil Mattress Signature Sleep Contour Inch 10
d. Signature Sleep Memory Foam Mattress 12 Inch
e. Mattress 10-Inch Memory Foam Mattress, etc.
If you also want to get these high-quality mattresses, you can buy them directly from Best Rated Mattresses at best deals..
Apr 03, 2013 | Furniture
What is an innerspring mattress?
Innerspring mattresses consist of rows of tempered steel coils layered between insulation Firmness and durability is based on the thickness of the wire and number of coils. The higher the coil count, the firmer the mattress. This mattress is considered by many as the back injury fixer and it is my favorite to.
Aug 20, 2012 | Furniture
For how long should my mattress last?
It depends on the quality of the mattress you are using. If you are using a high-quality mattress it will last for a long time and if you are using a low-quality mattress, it will damage soon.
Some of the best quality mattresses are given below:
a. Best Quality Needle and Tuft Mattress
c. Independently Encased Coil Mattress Signature Sleep Contour
e. Memory Foam Mattress, etc.
You can get these high quality mattresses at best deals on Top Rated Mattresses.
best-top-rated-mattress-and-best-for-side-sleepers-reviews-2016-4-zkk23coppyxusifxa33qbsew-5-0.jpg
What type of mattress is best to buy for a sofa-bed?
The best type of sofa bed mattress are:
1. Latex Mattress
2. Spring Mattress
3. Foam Mattress
4. Pillow Top Mattress, etc.
It is really a tough task to choose a mattress for a sofa bed. You can consider color combination and several factors of the mattress to buy the best one for you and your house.
Aug 16, 2012 | Furniture
I'm pregnant. Will my mattress be ok or do I need to get something different?
If your mattress is not more than 8 years older, feeling uncomfortable, not waking up with pains. you can continue with your old mattress.
please know more about orthopedic mattress and its benefits at Wakefit. Buy Memory Foam Mattress For Back Pain Online In India Wakefit
Jul 25, 2012 | Furniture
What are some of the top brands of mattresses?
Some of the more popular and highly purchased mattress brands are: Tempur-Pedic, Sealy, Simmons and Serta.
How to prolong the life of my mattress?
In order to prolong the life of your mattress you should try and keep the following.
1) Using a mattress pad or a protective cover will help you avoid stains.
2) Use a good and quality bed frame
3) Try to avoid jumping or standing on the edge of your mattress in order to eliminate bends
Jul 18, 2012 | Furniture
The bolt type frame that holds the mattress broke and we need to know where we can get or order another one for this crib
Products America carries several different styles of mattress spring frames. Visit our website at www.productsamerica.com to review our selection of mattress spring frames.
You can contact us by calling us at 800-205-9642 or 800-772-1041. You can also email us at parts@productsamerica.com.
Apr 04, 2012 | DaVinci Kalani M5501 Crib
Childesigns Bellmont Crib
Do you mean the spring mattress? No. Spring mattress doesn't come with this product. The mattress sits on a mattress board.
Jun 30, 2007 | Childesigns Bellmont Crib
Baby Gear Logo
116 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Baby Gear Expert? Answer questions, earn points and help others
