Question about Sharp AL 1631 Copier
Copy quality is poor. Replace toner, drum and transformer?
Sharp AL-1631... quality of text is poor after replacement parts
  • dakatt57104 Jan 05, 2009
    Copies are lite. I did shake the toner cartridge didn't help.
    what should I do with the photoreceptor?
    Novelist:
  • 148 Answers
When you say the quality of the text is poor I am assuming that your are describing the line print
FIX
IF FUZZY remove corona wire and clean with q tip diped in alcohol
If IMAGE OFFSET check fuser rollers emove pad and ad fuser oil
IF copies lite remove print cartridge and shake back and forth to get toner distributed
also examine photoreceptor sounds the shutter is not closing and causing image distortment
Posted on Jan 05, 2009
How do I prevent excess toner from spilling out of cartridge and affecting copies?
If you 'replaced' or refitted the original cartridge, then I would suggest that the toner cartridge has failed. If this is the case, please try a new one.
If the original has not done a fair (check manufacturers specification) number of prints, you may be able to ask for a replacement.
If this was a new cartridge, and printer uses separate drums and toner cartridges. Then it could be a faulty drum. Above replacement path could be tried.
Aug 01, 2015 | Sharp AL-1631 Laser Toner Cartridges
Toner cartridge spreads toner all over inside
If the toner cartridge is dumping toner it is defective and needs to be replaced.
Dec 08, 2014 | Sharp AL-1631 Drum Unit - 18000 Pages...
Sharp al1631 copier, copys are too Dim settings don't help ?
Check the toner supply, it may be running out of toner. Check the bottle or cartridge for correct install. Turn the machine on and let it warm up, Recheck the copy quality. If it is still light run a dozen blank copies, then a test copy if it is improving the toner is depleted and need to catch up, if it isn't there may be a problem with the toner add system.
Hope this is of some help.
Ed
Apr 27, 2009 | Sharp AL 1631 Copier
Sharp AL 1631 ---- Getting blank copies
Hi, you can stop a copy half way to see if it image is on the on the drum if not check and make sure toner unit is turning. if not main charge. thanks dale.
Jan 22, 2009 | Sharp AL 1631 Copier
Poor quality copies
Hi, this is most likely caused by a worn or faulty drum.
Jan 20, 2009 | Sharp AL 1631 Copier
Sharp AL-1631 coper - toner problem
the problem in your machine is on the drum unit there is a arching on the mc unit.located in the upper portion of the drum unit.if you have an old drum unit try to install it again just for testing.and check if ther is a dumping toner again.
Nov 05, 2008 | Sharp AL 1631 Copier
Sharp AL-1631 - would not copy.
Your unit definetly needs a new drum. The usual yield for this consumable is upt ot 15,000 pages, so at the stated rate, the unit yielded more than average. AL-1000 series share the same toner and drum, so finding remanufactured (or recycled) drum units should be no problem. In Puerto Rico, they are sold for about $79.00.
Oct 05, 2007 | Sharp AL 1631 Copier
Sharp AL-1631
Several things can cause this problem; The drum cartridge is not being cleaned properly or there is a problem with the toner cartridge . Take out the drum cartridge and inspect it for any signs of the defective image. If that doesnot solve the problem, then Call a tech.
Apr 20, 2007 | Sharp AL 1631 Copier
Sharp AL 1631 Copier Logo
303 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
