(CHARGE IDICTOR)su-kam sonik home ups charge indictor doesn't off and yet it used to go off
Serial No;0903061202 B capacity;600va/12v modal No;hups-sonik mfg;09/03/06
jmassengill
  • 345 Answers
SOURCE: do I have a Serial Port on my acer window vista home premium mfg date 12-18-2007
Most newer computer do not have serial ports but there is such a thing as a USB to Serial converter that might work to load what you need to load. USB to Serial converters don't always work but they are worth a try
Posted on Nov 09, 2008
SOURCE: the in use/charge indictor light
Check your connections on hand set and base. Wiggle the handset on base to see if handset starts charging... If it does.. clean your connections or you have loose solder connections either in hand set or Base Unit.. Give that a try..
Chris
Posted on Sep 03, 2011
ercupa190
  • 12223 Answers
SOURCE: admiral dryer super capacity dryer won't heat up and light doesn't stay on. It happened when we first brought it home years ago and the repair may said to reset some button but I don't kn
see this causes and fix it. God bless you
Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Thermal Fuse / Thermal Cut out
On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel or behind the front panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing or is sometimes round and made of metal and plastic.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse this is the most common reason for blowing the fuse. (You can't re-set this type of fuse.)
Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Posted on Sep 29, 2012
  • 3662 Answers
SOURCE: how do i fix my su-kam 2.4kva inverter that stopped charging the batteries?
A 2.4 Kw inverter is serious equipment costing quite a lot of cash - rather too much cash to take a chance with. The very fact you have to ask how to fix it means you probably shouldn't touch it but should entrust the repair to a properly insured professional.
I suggest you check the literature provided or visit the manufacturer's website for advice, make whatever checks you can regarding external connections and wiring and then find a repairer.
Posted on Aug 01, 2016
gopakumarg43
  • 74383 Answers
SOURCE: Su -kam inverter model 850 is no out put supply for battery
"Parama Sukkam". Keep it always with you.
Posted on Oct 24, 2016
How do I find this manual?
Doesn't seem to be on line better call Beckman with serial number of the unit.
Nov 13, 2013 | Beckman Du Series 60 Spectrophotometer...
REPLACEMENT BATTERY VECTOR JUMP STARTER
Ebay lists over 150 of them. 12v 19ah will get you to a seller.
The jump starter won't have a problem with the extra ah capacity but there might be a problem with the physical size of the battery.
The jump starter's charge function may work a little harder though.
Oct 01, 2012 | JUMP START SYSTEM
Black & Decker Cordless Drill will not charge battery
Either the charging adapter is faulty or the battery is worn out.
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Jun 03, 2012 | Black & Decker Black and Decker 18V...
The battery doesn't work fine
If the cell phone battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
May 26, 2012 | Motorola Mobility RAZR V3
Charging problem of dell pp41L, it works as an ac online power bt it doesn't charge it.
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
May 20, 2012 | Dell Computers & Internet
My sukam sinewave inverter its output is less than 10volts
Hi rutabairu,
We are extremely sorry if you have been inconvenienced through a Su-kam product. However, we pride ourselves on prompt and effective customer service. Please provide us with your name, contact number and address. Please give us the complaint number and date as well and we assure you to look into the matter at the earliest. Mail us at custserv@su-kam.com, We would do our best to resolve your grievance at the earliest.
Hoping to hear from you soon.
Sarita
Su-kam Executive
custserv@su-kam.com
Jul 25, 2011 | Electronics - Others
I am using sukam 650 tourque inverter before 3 month . from 15 days fuse of inverer getiing fused again and again after 2 3 daus of replacing new fuse . waht can be the problem ?
Dear customer,
We are extremely sorry that you have been inconvenienced through a Su-kam product. However, we pride ourselves on prompt and effective customer service. Please provide us with your name, contact number and address. Please give us the complaint number and date as well and we assure you to look into the matter at the earliest. Mail us at custserv@su-kam.com, We would do our best to resolve your grievance at the earliest.
Sarita
Su-kam Executive
custserv@su-kam.com
Sep 01, 2010 | Kitchen Ranges
My sukam 800 VA inverter is dead
If the regulating circuits 78xx had blown it means that the input voltage which may be 18 - 35 VDC has been fed to all ICs. Some of them or all may have burnt. I did not understand which crystal did you change (the 2 - 20 MHz Quartz may be), but I think that rather the PIC was damaged.
If you have Oscilloscope on hand, check the oscillations on PICs clock.
Jul 18, 2010 | Inverter Pure Sine Wave 1500w Inverter
Computers & Internet Logo
David Payne
David Payne
