Question about Whirlpool DU840CWD Dishwasher
Whirlpool Dishwasher - water collects at the bottom after use.
I have a Whirlpool Dishwasher (DU840CWDB5). The unit is not draining properly after use. Does the dishwasher have a pump to pump out the water or does it only use gravity to get the water out?
watugot
  • 290 Answers
SOURCE: whirlpool dishwasher stopped working...
It sounds like the thermal fuse in the control console has blown.
Turn power off to unit.
Remove the outer door panel and then the console.
Remove the black plastic cover from over the circuit board if it has one.
You should see the thermal fuse clipped to the circuit board housing.
If you have an ohm meter, check for continuity across it, it should read closed.
If you don't have a meter, unplug the wires from it and and hook them together.
Turn power back on to unit, hold door switches down and cancel cycle. The washer should drain the water.
If this doesn't work, check your door switches to make sure they are closing properly.
Posted on Nov 17, 2007
  • 351 Answers
SOURCE: Whirlpool dishwasher not draining
blockage in the drain hose somewhere
Posted on Mar 20, 2008
SOURCE: bottom of dishwasher leaks even after the last rinse water has been drained
need a dwg on how to plumb a dishwasher
Posted on Jun 04, 2009
SOURCE: Water didn't drain, left in bottom of washer tub
I had similar problem and it ended up being a clog at the point where the drain hose meets the garbage disposal. I had to unhook the hose and clean out the food that had accumulated (horrible smell). You may have to stick a screwdriver into the garbage disposal hole where the hose fits and clean the food out there also. Then put the hose into a bucket and run a few cycles to ensure the hose is free.
Posted on Aug 05, 2009
  • 64 Answers
SOURCE: Whirlpool dishwasher 2966 draining failure
take the airgap apart. located on top of sink. clean out and reassemble.
Posted on Aug 26, 2009
DU943PWK model, water is sitting in bottom, won't drain
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter. Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn't overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn't working properly, the drain pump isn't working correctly, or possibly there is a plumbing problem in your home's drain lines. First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. If you have checked the drain hose and can't locate the problem, then it is an issue with the drain pump of the dishwasher. Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Oct 27, 2010 | Whirlpool Dishwashers
My dishwasher is draining properly.
yes there is cleaners.Check filters at bottom of machine fiirst,then buy an cleaner.adrian,,,,
Jul 15, 2010 | Whirlpool 24 in. DP940PWP Free-standing...
The door on my dishwasher everytime you open it is making a loud creaking sound and there is water at the bottom of the dishwasher always. what to do?
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter. Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Mar 03, 2010 | KitchenAid Dishwashers
Not draining at all. water collected at bottom of unit. tried "cancel/drain" numerous times and water remains at bottom of unit.
Possible blocked waste pipes or cycle pipes. but some specialist de-greaser and let it soak in dishwasher over nite - put dishwasher on in morning, repeat until its flushed.
Feb 16, 2010 | Kenmore Dishwashers
Water fills in bottom of washer when off
The fill valve has failed. You can get a rebuild kit for the valve.
Also clean the tiny straainer in the valve.
Dec 30, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
My Whirlpool Quiet Partner III is collecting dirty water after the garbage disposal has run. Is this problem the dishwasher or garbage disposal?
The drain hose under the sink needs to be tied up,above the point where it enters the drain pipe or disposal,water is feeding back into the unit,run the disposal more often also this helps prevent this from happening.
Aug 19, 2009 | Whirlpool Dishwashers
Standing water in bottom of dishwasher...didn't drain.
hit the cancel drain cycle. Often times the dishwasher drain hose is not installed properly. It must be routed up as high as the dishwasher as soon as it comes out of the unit. May be also that there was a little regular soap or something that made it sudds up. vegetable oil poured into the dw tub will remove the sudds. Try to wash again after cleaning out the sudds and run it again. Thanks
Apr 03, 2009 | Whirlpool 24 in. GU1200XT Built-in...
Water not draining from dishwasher
1.attache the drain hose to the bottom of contertop.
2. drain back valve is not work properly.
Dec 20, 2008 | Whirlpool Dishwashers
It collect water after I use kitchen fosset. I have to push button "cancel/draine for emty it. may be nee to see outlet back valve? Thank you in advance.
Make sure the dishwasher drain hose loops to the bottom of your countertop and secure it there with a strap or a piece of wire. This will prevent water from running backwards from the kitchen sink drain to your dishwasher. This will solve your problem.
Dec 20, 2008 | Whirlpool 24 in. DU1100XTPS Built-in...
Dishwashers Logo
129 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
