Cycle does not begin
My machine switches on, the water is on yet it won't start the cycle. Also I notice that the door doesn't lock??
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
What is the model number of the unit?
Posted on Nov 09, 2012
Yozzer6821
  • 116 Answers
SOURCE: Door lock light flashing
More likely the PCB needs replacing - common fault, you could try a new door switch first cost £5 new PCB £65+ but is easy to replace.
Posted on Nov 09, 2008
  • 61 Answers
SOURCE: water runs into tub but does not fill?
be sure the drain hose is not lower than the wash tub this will caust the water to run out, 2nd be sure the drain hose is not pushed to far into the house stand pipe and the there is rome for air to go inbetween the drain hose and stand pipe eather of these will cause the machine to siphon mostly on rince cycle or on the 2nd and third loads you do. last your house drain could be starting to back up fill the washer with water and listen to it drain if you hear a gurggling sound in the house pipe you may need a plumber to cleanthis out for you.
Posted on Jan 20, 2009
  • 6277 Answers
SOURCE: I have a Samsung VRT
(You can drain the water by the following)-
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Apr 05, 2011
  • 6277 Answers
SOURCE: The washing machine will start
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT.
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jun 07, 2011
Daniel S
  • 4323 Answers
SOURCE: The washing machine goes through
Hi
The issue is with the drain pump that is clogged/kinked, as it won't drain the water the door won't unlock. If this is a front load washer then take the lower access panel out and clean the drain pump assembly. Hope this helps...please post back with its complete model no for further assistance.
Daniel
Posted on Jul 28, 2011
My Whirpool Duet front loader will begin a wash cycle, but stops when cycle switches to rinse with water in the drum. Door remains locked & light by the 'wash' flashes 9 times...
when the machine is stopped can you empty the residue water that remains by the programme selector? if not check for blockage in the pump(coin), the hose internal blockage ,or at the outlet under sink. I hope this help
Jan 15, 2015 | Whirlpool duet Washing Machines
Door won't lock / cycle won't start
Check if the lock is binding or the door switch is not being operated.
May 19, 2013 | Asko W6221 Front Load Washer
Beko WMP652W washing machine will start cycle but get stuck at end of wash, doesnt go onto rinse or spin any help please?
see the next steps and use the common sense: God bless you
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Aug 01, 2012 | Washing Machines
It keeps starting at the beginning of a cycle, won't finish, and can't open the door
1) YOU MUST test the TIMER for defective, test the contacts dirty, or oxide.Loose wire, or open or break.
see the diagram
2)see if the screen is clogged+ test the defective water inlet valve see how to test.
Jun 28, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Hi! We have Kenmore Elite he3t. We noticed water in the washer today after a complete cycle so we ran the rinse and drain command on it. I tried to begin a new load on a normal wash cycle and it will...
Hello and welcome to FixYa
DL f is a door lock error and is caused due to an issue with the door lock when it is unable to lock/unlock. Please check the door lock mechanism/door switch assembly and replace the part that has gone bad so that the issue is resolved. Please get back to me if you have any other questions.
Kevin
Aug 30, 2011 | Kenmore Elite 45986 Front Load Washer
My mother accidentally pulled the door open on the washing machine when it was still locked. Now it won't do anything. It would not even finish the cycle. We were able to get the clothes out and...
Due pulling of the door forcibly the door interlock switch has damaged. So the door cannot lock properly &r the door lock switch is not functioning. Replace the door interlock switch.
Aug 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
The "lock" light is not
Sorry but if it is not 'lock'ing there is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor requiring a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
John C
Jul 07, 2011 | Washing Machines
I cannot get my washer to release so i can open it up and switch clothes over.. It has finished its cycle i even made it do another cycle to try and get it to release but it wont.. any suggestions? Kat
There are many reasons why the door may be jammed shut -
1. The water hasn't pumped out properly and the washing machine has a pneumatic door safety lock (a rubber hose connected to the door interlock and connected to a pressure chamber bottle on the tub - water forces air up this tube and locks the door)
2. Washing machine won't empty water
3. The water has pumped out properly, but a blockage of gunge inside the pressure chamber bottle is trapping the air that's operating the door lock (if a pneumatic lock is fitted - not many have these days due to cost cutting)
4. Door interlock jammed
5. Door catch, handle, or mechanism broken
Try running Just the rinse spin cycle again,
Jul 05, 2011 | Washing Machines
Model fwt645rhso will agitate but won't drain out, on spin cycle washer spins one way, stops goes back the other way, but water will not drain out. Does not rapidly spin on final cycle. Any...
There's an auxiliary switch in the door lock.switch assembly that is activated at the end of the wash cycle for the machine to advance to the spin cycle. The machine will NEVER advance to the spin cycle unless the auxiliary switch is activated as a safety feature to prevent the door from opening during a high-speed spin cycle that may result in physical injury. The drum tumbles back and forth while the machine control checks the auxiliary if activated but since it's not, the control will not command the motor speed control to spin the drum at high speed. These symptoms may indicate a faulty door lock/switch assembly and may need replacement. Click on the links below for the detailed troubleshooting instructions and replacement of the door lock/switch assembly.
Electrolux and Frigidaire Washers Door Lock/Switch Assembly Troubleshooting
Replacing the Door Lock/Switch Assembly on Electrolux and Frigidaire Washers
Jun 18, 2011 | Frigidaire GSTF1670A Front Load Washer
Washing Machines Logo
14 people viewed this question
Top Washing Machines Experts
