Question about Clymer Marine Maintenance and Repair Manual '99 '02 Yamaha 115 250 HP 2 stroke Outboards
115hp 1985 yamaha outboard 6e5 AETO running at low revs as if on 3 cylinders,on low revs only when i accelerate it goes well and fast without issues,when i slow to trolling speeds it runs a bit rough and at idle it will misfire or cough.had the carbies done twice.problem still there.mistified,and also noticed greater increase in petrol consumpsion.
    Novelist:
  • 184 Answers
Sounds like a bad coil or trigger. Find the offending cylinder with a timing light and physically move the coil to a good firing cylinder. If the problem follows the coil, you have it, if not you need a trigger,
Posted on Nov 29, 2012
  • mario martins Mar 27, 2013
    i do not have a timing light but i have an oscilloscope can i use it to find the misfiring cylinder
  • Mike Vhx
    Mike Vhx Aug 21, 2014
    better use a stethoscope
90 hp 2001 Mercury outboard runs with no power
Hey Robert,
This is not enough info for a decent diagnosis.. but here goes....Will the engine rev up cleanly and fast in neutral? Yes.. proceed - . No.. take it to a professional mechanic...
1. Does the no power mean it will not accelerate in the water? when in gear will the engine rev up and then still not go? ..YES-maybe a spun hub in prop.
2. Will the engine try to take off but not pull the boat and not rev when trying to take off? Take it to a professional mechanic for a compression check.
3. The spun hub is about the only thing you can fix if its not a serious engine issue!!
Jun 06, 2017 | Mercury Boating
Find year by serial number06272499
I come to an R/MR/Alpha One drive from 1983...
Maybe specify make/model number
Aug 19, 2014 | Seloc Mercury Outboard ONLY, 40-115HP...
Yamaha v4 1991 115hp outboard fuel pump failure
remove fuel pump and check the diaphrams have not perished and valves are seated on housing ! But first try while engine is running if you prime the bulb does it keep running , if yes then pump not priming fuel !
Feb 15, 2014 | Boating
I need a carb diagram for yamaha tzr 250 cc motor cycle year 1988 it will not rev with out choke on . blocked jets?
Hi, Rolandwhitfo and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Vacuum line from the petcock to intake manifold cracked.
5. Float needle and seat sticking.
6. Float level too low.
7. Carburetor bowl vent line clogged/blocked/pinched.
8. Idle adjusting screw set too low.
9. Air/fuel mixture screw set too lean.
10. Idle port, transfer ports, slow air jet clogged.
11. Slow fuel jet clogged.
12. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on the blue links below. Good luck and have a wonderful day.
TZR 250 WON START
Will start but wont stay running without choke Yamaha Outboard Parts Forum
Yamaha TZR250 1987 Service Manual
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-tz-owners-manuals
Aug 08, 2011 | 1988 Yamaha TZR 250
My Yamaha Outboard 115hp 1994 motor starts but wont keep its revs up for very long. I've had issues with water in the fuel recently and had all old fuel and water flushed out of my tanks and motor. After...
Not enough information, but there are two things I didn't read about you checking. Make sure the fuel quick connection on the engine (and possibly the fuel tank) is locked all the way in first, Then see if your fuel pump is working. Disconnect the fuel line from the carb and, holding it in a gas can, have someone turn on the ignition. If It's an electric pump, it should start running fuel, if mechanical, they'll have to crank it a little to get fuel going. If you get plenty of fuel that way, your float in the carb could have gotten stuck, or something in the line got into it.
Mar 25, 2017 | Yamaha 40N/50N 40 and 50 HP Outboard Motor...
1986 Yamaha FZ750 - engine will start and idle - won't rev up. (engine quits)
Hi, Carefree22 and the usual suspects are:
1. Idle circuit and transfer ports clogged.
2. Air fuel mixture adjustment too lean.
3. Pilot jet clogged.
4. Faulty accelerator pump.
5. Float level too low.
6. Float bowl contaminated old fuel, water, dirt, rust, etc.
7. Float bowl vent or overflow tube clogged.
8. Fuel flow to carburetor restricted.
9. Intake manifold leak.
10. The gas cap is not venting properly or fuel tank venting system blocked.
11. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
12. Needle and seat stuck closed in the float bowl.
13. Multi carburetors not in sync.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Bayou 300 idles but won rev
my bike starts runs idles perfectly but will not rev
1985 1988 YAMAHA Genesis FZ750 Service Manual Repair Manuals AND Owners... $10
http://mybikemanuals.com/yamaha/yamaha-fz-owners-manuals
Sep 20, 2010 | 1986 Yamaha FZ 750 TV (Europe)
Yamaha 115hp 2 stroke Outboard Boat Motor. Went fishing and the boat ran great on the way out there, and when I cranked up to come in the boat wont go over 2000rpm's without bogging down. Fuel Starvation/...
is it carbureted or fuel injected? are your warning horns working? if it iscarbureted then a few easy test can be done to find out. if its fuel injected then its a little harder but not impossible.(1) check compression. without the year model I'm giving you a average numbers. all cylinders need to be over 100 lbs and equal each other within 5 lbs.(2) check spark. use a spark gap tester all cylinders should jump a half inch gap. if you have good compression and good spark fuel is the problem nine times out of ten. clean fuel lines replace primer bulb and replace all fuel filters. Yamaha has a gravity filter under the engine coul. take it to the lake if no improvement. clean carbs. same test to be and fuel system service used of fuel injected engines. if no improvement in engine preformance then you will have to take it to a dealer to test with computer.
Oct 22, 2009 | Boating
Blocked speedometer tube on 1988 yamaha 115hp MODEL 6e5
Blew air & water through the tube after inserting a thin a wire, problem was sand in line
Jun 18, 2009 | Watches
Clymer Marine Maintenance and Repair Manual '99 '02 Yamaha 115 250 HP 2 stroke Outboards Logo
481 people viewed this question
Top Clymer Boating Experts
Fabrice Wolters
Colin Stickland
Colin Stickland
Are you a Clymer Boating Expert? Answer questions, earn points and help others
