Question about Baby Lock BL1556
How many foot for Baby lock E5280 like flat, blind, rolled hem?
My baby lock E5280 only works for rolled hem but could not flat hem.
How will I adjust for that? Please help me and I do not have instruction book.
Thanks,
Anna
  • Anonymous Mar 21, 2014
    How do I adjust the pressure on the presser foot?
  • Anonymous Mar 23, 2014
    trying to do a blind hem for first time
    Problem Solver:
  • 19 Answers
I dont have a baby lock but on my machine i change from rolled hem to flat needle plate
or change setting to n from r also loosen lower looper tension as rolled hem requires a tight lower looper tension.
hope this helps you
mary h
Posted on Jan 05, 2009
Metal blind foot hem 6217c
The 6217C doesn't have a blind hem foot. You need the General Purpose (low-shank) foot, the General Purpose Needle Plate and the blind hem guide (part number 381213). The guide gets secured by the screw that holds the presser foot shank. This site, http://cart.jennys-sewing-studio.com/index.php?main_page=product_info&products_id=473 , has the blind hem guide available. This metal foot might fit your machine: http://cart.jennys-sewing-studio.com/index.php?main_page=product_info&cPath=530_73_101_164_168&products_id=463 .
I hope this helps.
(who has a similar blind hem stitch guide for my Singer Touch & Sew. I haven't gotten the hang of it yet.)
Feb 10, 2014 | Sewing Machines
How do you do a blind stitch on a Viking Fresia 415? What foot do I use?
You need a foot like this one so you can guide the folded edge of the fabric hem along against the white plastic foot. This is a generic style snap on blind hem foot, your machine should have one in the accessories that looks like this if your machine has a blind hem stitch included in its functions.
You fold the fabric into a upside down Z shape and run the top folded edge along the white guide with the fabric under the foot, hard to explain but once youve done it once, it makes sense.
You need to select the stitch on your machine that looks like 3 small zigzags, then one bigger one, or 3 straight stitches, then one zig zag to the side. This is the blind hemming stitch. You'll possibly also have a blind hemming foot to use, which helps with guiding the fabric fold into the machine and keeping it even. But if not, you should be able to buy one from your Huskqvarna dealer or a generic one from www.sewingpartsonline.com may well fit.
You'd be best served by visiting http://sewing.about.com/od/techniques/ss/machineblindsti.htm for photos and intructions if you've never done blind hem stitching before.
Blind hemming works best when hemming straight edges of fabric such as a ruffle on a full skirt - if there is any curve in the seam, it gets much harder and the result won't look so good. In essence, you press the fabric hem up, then fold the hem edge back under so you have a "S' shape, then sew along the single layer with the folded edge sitting against the foot guide. Then when the machine takes the 4th wide stitch, the needle swings to the left and catches a small stitch into the upper folded layer, then back onto the hem. The trick is adjusting the stitch so that the wide stitch doesn't show much on the right side of the garment
Sep 06, 2011 | Sewing Machines
Which needle do I take out to do a rolled needle
left one, rolled hem is usually a narrow seam so you remove the left needle, change the needle plate or flick a switch that changes the position of the thread finger under the foot and tighten up the looper tensions. You want the top looper thread to go around to underneath and the bottom looper thread to disappear against the needle stitching. You also need to close up the stitching density, by decreasing the stitch length.
Mar 02, 2011 | Baby Lock Eclipse Serger
What does the blind stitch foot look like????
If you mean a blind hem foot, you can go to www.brother-usa.com and look at their accessory catalog. It is just a presser foot that has an adjustable screw to set for an edge guide. You don't have to have a Brother any low shank blind hem foot will fit. You can order from them, 1-877-276-8437 or any online sewing machine parts place, ie. www.sewingpartsonline.com.
Jan 08, 2011 | Brother XL-2600I
Which food sood i use to make an invisible hem
blind hem foot is good if you want to machine stitch a hem but not have a seam showing. it will have an adjustable piece you can move left or right with a screw. but blind hemming works best on straight grain and not on a curve like a skirt hem unless its a knit fabric that gives. to make a blind hem press the hem allowance up then turn the main garment piece back to form a Z shape. you then stitch along the hem side with your blind hem foot guidr running along the top fold and use the blind hem stitch which looks like three little zigzags then one big zig far to the left onto your folded piece taking a little 'bite' - this stitch shows on the right side when you press the top of the Z back flat. so you need to adjust the foot position and how wide the needle swings to minimise this stitch showing. hope this makes sense and helps you with your sewing.
Dec 19, 2010 | Elna 2007 Mechanical Sewing Machine
I have a Baby Lock 5280E. Can you tell me how to set the machine for rolled hem?
Assuming you mean a narrow rolled edge:
  1. Remove the left needle and thread.
  2. Open both the front and side covers.
  3. Raise the presser foot and the upper knife to the highest position.
  4. Clear the stitch fingers.
  5. Push the stitch with former release lever and remove the stitch former from the lower knife base. (Don't lose it!)
  6. Turn the stitch with adjusting dial until the "M" on the dial matches the red indicator on the needle plate.
  7. Set the stitch width length to "M".
  8. Close the covers, lower the presser foot and the upper knife.
This gives you a narrow edge. To roll the edge, increase the tension of the lower looper (the green knob) about three numbers higher than normal.
Nov 03, 2010 | Baby Lock Evolve
Juki baby lock EA 605 'rolled hem'
No way to rolled hem, machine as much as 40 years old
Aug 26, 2009 | Sewing Machines
Baby Lock Imagine
Here are rhe directions from the manual of "Image" model BLE1AT: 3 Thread Rollled Edge
With the stitch selector set on "D", a narrow edge can become a rolled edge. Remove the left needle and the corresponding thread. Clear the stitch fingers. Turn the stitch length adjusting dial clockwise into the rolled hem range and set the dail at 1.5 Set the stitch width to 3.5
Hope this will be of some help. Good luck and have a great day! Lisa
Oct 06, 2008 | Baby Lock Imagine
Elna 2007
If you want to do blind hemming you need to find the stitch on your machine that looks like 3 small zigzags, then one bigger one, or 3 straight stitches, then one zig zag to the side. This is the blind hemming stitch. You'll possibly also have a blind hemming foot to use, which helps with guiding the fabric fold into the machine and keeping it even.
As the previous poster said, blind hemming is a little difficult to explain. You'd be best served by visiting http://sewing.about.com/od/techniques/ss/machineblindsti.htm for photos and intructions, getting a copy of a manual for your machine (if it doesn't have this stitch, then you're going to need to find another way) or getting a ibrary book out.
Blind hemming works best when hemming straight edges of fabric such as a ruffle on a full skirt - if there is any curve in the seam, it gets much harder and the result won't look so good. In essence, you press the fabric hem up, then fold the hem edge back under so you have a "S' shape, then sew along the single layer with the folded edge sitting against the foot guide. Then when the machine takes the 4th wide stitch, the needle swings to the left and catches a small stitch into the upper folded layer, then back onto the hem. The trick is adjusting the stitch so that the wide stitch doesn't show much on the right side of the garment.
Sep 07, 2008 | Elna 2007 Mechanical Sewing Machine
Sewing Machines Logo
371 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Jon Piercy
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
