Question about LG LRSC26980 Refrigerator
Whirlpool icemaker dripping water - LG LRSC26980 Refrigerator
    Top Expert:
  • LG Master
  • 9,472 Answers
Fit he ice maker is dripping water, then you have a problem with the "water valve" solenoid not closing completely. Here is the valve to order.
The part comes with a 365 day, any part, any reason return policy.
Posted on Nov 09, 2012
How do I remove the ice maker unit from my Whirlpool GD5SHAXMT00
You need a new water solenoid valve, this should be located on the lower left hand side as you face the fridge. You should be able to change it after you shut off the water. It just unplugs and there are just a couple of screws that hold it in place. The reason it is leaking is the valve is leaking through and it is causing the tray to overfill.
Jan 24, 2013 | Refrigerators
Have Whirlpool 19TFA manufactured 02-06. Water somehow drips on top shelf just below icemaker. Can't tell if from icemaker or not. Icemaker does not fill properly because ice cubes are very thin and...
Hi and welcome to FixYa. I am Kelly
Yes the inlet can be frozen. You can most of the time feel is with your finger if there is and ice build up by reaching all the way to the back and top of the icemaker where the inlet funnel is. Even if you can not feel it there can be ice build up.
There is a quick remedy for this if you have a hand held blow dryer.
1. Unplug the unit
2. Use the blow dryer on the ice maker for about 10 minutes or until it is warm to the touch.
3. Plug the unit back in and the dripping should not re-appear. It may take 12 hours or more before you know if cured the dripping problem.
Thanks for using FixYa!
Kelly
Feb 09, 2010 | Refrigerators
Icemaker keeps freezing up after a couple of weeks of using then it becomes clogged with frozen ice int mechanical part of the icemaker
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
Feb 06, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
My ice maker has quit working. The water is not filling the tray.
Pour 1/2 cup of water into icemaker . If it dumps the cubes when frozen , then check the fill tube going into the icemaker , to see if it is frozen solid . If it is , remove and clean and replace water valve ( drip seeping ) . If not frozen , replace the wqter valve anyway . If the icemaker doesn't dump the cubes , and holds the frozen ice , replace the icemaker , after making sure the coils under fridge are free of dust , lint , pet hair etc.The icemaker needs to be 5 degrees to operate , and , dirty coils could bring the temp up to 6 or higher in the freezer section .
Aug 27, 2009 | Whirlpool Refrigerators
Why water is dripping, i do not use the ice maker, it's either freezes everything or dirpping water
If you have no desire to use the icemaker, simply turn off the water supply by following the supply line to the valve. (the valve you're looking for has a tiny little "T" handle) The refrigerator has a solenoid valve at the back that admits water as needed for the icemaker. If the valve gets a contamination such as rust, it will leak. Replace the valve, or have it replaced if you wish to use the icemaker.
Jul 15, 2009 | Whirlpool Refrigerators
Water leaking from icemaker on outside
If this is your water dispenser leaking
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
Jul 08, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
GE PSS23mstcss Icemaker not working
icemaker will need replaced, < only other concern with description is water dripping> would not address this unless problem did not go away after replacing icemaker, < could be leaking water valve>.
Apr 23, 2009 | Refrigerators
Whirlpool Ice Maker Won't release ice
Jetguy77,
I have a 1993 year (16 years old now) Whirlpool side-by-side with icemaker, Model ED22PW. I have had similar problems with the icemaker - water goes in, freezes, but ice does not eject from tray. It has happened to this unit 2 times since 1993. It turns out the problem is not the thermostat. It is the icemaker motor module. The icemaker has a small synchronous (clock) motor that rotates the ice ejector. When it goes bad, the ejector does not rotate, either because the module timer had failed or the motor itself has failed. The solution is to go to your nearest applinace parts dealer and by a new "icemaker motor module" for Whirlpool Model (your model here). Mine cost $58.85 the last time I replaced it in 2006. To install the new module, you will need to remove the icemaker from the refrigerator. Mine has 3 screws that attach it to the side. Also unplug the power & control cable. The water tube slides out when you pull the unit forward. When you get it out, it is then easy to remove the motor module and insert the new one. You may have to reset the timer on the module to get the tray to fill completely.
Jan 18, 2009 | Whirlpool GS6NBEXR Side by Side...
Water drips from underneath icemaker and freezes in bucket
If you find the offending part of the ice maker, I've had good luck with these guys when ordering spare parts. Here is a link for your model:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5133512
Jan 01, 2009 | Whirlpool ED2FHEXN Side by Side...
LG LRSC26980 Refrigerator Logo
16 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
