Question about Dyson AM04 Hot Cool Fan Heater White
Dyson hot and cold fan only works in hot mode
Works fine in hot mode, will not operate in temps below 25c
  • Official Brand Answer
  • 2,572 Answers
Hi there, it's Jack at Dyson.
When you adjust the target temperature of your Dyson Hot fan heater (shown on the LED display on the base), you're setting the target temperature you would like the room heated to. The actual temperature of airflow produced by the fan heater will not vary.
If the heater won't run below 25 degrees, this is likely to be because the temperature of the room you're in is equal to or warmer than 25 degrees. The heater will only turn itself on if the temperature drops below 25 degrees, and once the room temperature reaches this target once again, the fan will turn itself back to monitoring mode.
I've attached our Getting started video below which shows how to adjust the temperature, using the remote or the controls on the base.
I hope this makes sense. It sounds as if your machine is working correctly, but if you'd like any further advice from our experts you can reach us at 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Posted on Mar 11, 2014
  • 1 more comment
  • William Funk
    William Funk Jun 07, 2014
    Why does it not give off cool air? It is supposed to be a hot/cold machine. How do you get it to function with cool air???? Thanks
  • AskDyson
    AskDyson Jun 11, 2014
    Hi William, it's Jack at Dyson.
  • AskDyson
    When you lower the target temperature until the LEDs display '0', you'll notice the on/off light turning blue to indicate the heater is now running in fan-only mode. It will then circulate unheated air to cool you, and you can use the remote or the control on the base to adjust the power and oscillation to suit your needs. I hope this helps.
2000 caddy Seville ...after starting and engine warm turn on the heater and it blows cold air. Fan works / waiting for hot air and then all the sudden it kicks in. Engine at normal temp
Low coolant, if there is an air pocket in the engine it will make it to the heater core. Once there , the air coming out is cold/cool. Once the coolant fills the heater core, it gets hot. If the coolant is fine hot or cold, then have the HVAC system scanned.
Oct 09, 2016 | 2000 Cadillac Seville
Hi. I have a Dyson AM05 fan heater purchased July 2014. Whilst the cold air works brilliantly the hot air doesn't work at all. It shows an error message E8. Any advice?
I suspect that the microprocessor detected an overheat fault and is keeping it in E8 mode to prevent fire. The code needs to be cleared somehow. If it has some buttons on the front then try holding one whilst plugging it in. This may reset it. The reset will be something along those lines. Don't open it because if you can't fix it that way you need to take it back to the shop.
Dec 29, 2014 | Dyson Inc Am05 Hot Cool Fan Heater -...
Dyson hot and cold
It sounds like your heater is shutting off because the ambient temperature is higher than or equal to the target temperature you've chosen (shown on the LED display on the front of the machine):
The heater's intelligent thermostat is engineered to turn the machine on only when needed when the ambient room temperature drops below the target temperature. However, we're happy to help you make sure your heater is working as intended. Please give us a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Jul 17, 2014 | Dyson AM04 Hot Cool Heater/Table Fan -...
My dyson hot fan will not give out air under 24 degrees?
Hi Charlie, it's Jack at Dyson.
If the heater won't run below 24 degrees, this is likely to be because the temperature of the room you're in is equal to or warmer than 24 degrees. The heater will only turn itself on if the temperature drops below 24 degrees, and once the room temperature reaches this target once again, the fan will turn itself back to monitoring mode.
Aug 01, 2013 | Dyson Hot Heater Fan AM04 - Blue
AM04 ONCE TERMOSTAT TEMP IS REACHED, UNIT POWER SHUTS OFF AND HAS TO BE MANUALLY RESTARTED
Hi Jeanette, it's Jack at Dyson.
It's normal for the fan to revert to monitoring mode once the target temperature you've selected (shown on the LED display on the base) has been reached. But the machine should automatically turn itself back on again once the temperature drops below the target.
If you feel it's not doing this as rapidly as it should be, or if it seems to be shutting itself off completely, we'd encourage you to get in touch. If a repair or replacement is needed we can confirm if this is covered under your machine's 2-year guarantee.
You can reach us on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Dec 23, 2012 | Dyson Hot Heater Fan AM04 - Blue
DONT KNOW WHAT SIMBLES ON REMOTE CONTROL ARE EG HOT COLD ETC
Symbols:
1. fan leaves - Fan only
2. Rain drop- Dry mode
3. Snow flake-Cool mode
4. Sun- Heat
5. A or AU- Auto mode.
Mar 20, 2011 | Mitsubishi MSZ09UN Air Conditioner
Keeprite 2300 sx a/c w/ 2 speed fan never seems to go high speed .should I be able to hear it change and how do I dainose the problem ? and does this cause poor cooling ? the compressor unit line is cold...
I need more info. I can't seem to find your indoor unit. Is this a 2 stage cooling unit or just 2 speed fan? Please send the model number of your indoor unit.
Apr 11, 2017 | Heating & Cooling
04 Bonneville, GXP. Blower Motor not Function Properly
sounds like the sensor is becoming questionable or a hi resistance ground in this part of the blower sensor circuit
Oct 05, 2009 | 2005 Pontiac Bonneville
Heater only blows hot (well, warm) on full speed of fan
Replace the temp control on this car, it should be electrical control not cables.
Dec 03, 2008 | 2000 Ford Escort
Dyson AM04 Hot Cool Fan Heater White Logo
411 people viewed this question
Top Dyson Dryers Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Timllfixit
Are you a Dyson Dryer Expert? Answer questions, earn points and help others
