Question about JVC TH-M505 System
I need a system cord, it goes from the receiver to the sub woofer
    Problem Solver:
  • 9 Answers
Go to the manufacturer website for your speakers and you should be able to find what you're looking for there. If not, leave a comment with the manufacturer and model number and I'll see if I can find it for you. You can also check your user manual for connection types and it should show you what you need to get.
Posted on Jan 05, 2009
4 Suggested Answers
marsrover
  • 682 Answers
SOURCE: Sub-Woofer
you must replace the board with new one.
Posted on Jun 02, 2008
SOURCE: help with SB-WA920 sub woofer PLEASE!!!!
Sure, you can use transition between SB-WA920 system cable with other output. So, you use them as speaker. That's it.
Posted on Aug 21, 2008
AfroDZac
  • 67 Answers
SOURCE: I am looking for the
The part you are looking for is a DIN/System cable.
you can order one from jvc directly
http://store.jvc.com/product.asp?Model=6200044901
or search DIN/System cable in google, theres a few cheaper ones.
Posted on Feb 02, 2011
RCA RT2770 Sub-woofer sound doesn't come
The sub should generally have its own power supply, is it plugged in ???
Feb 16, 2016 | RCA RT2770 Theater System
I am attempting to reconnect my home stereo but do not see a cord or wire to connect the bass to the system. is there supposed to be a connective cord for the bass speaker? it is a 530 watt MHCGX99 model...
Hi from one Lakers fan to another 8^) - Yes you do. You need a cable to plug into the
sub-woofer out port on the receiver to the connection on your sub-woofer.
If you can't find the original cable, get a short (three ft.) standard stereo cable (one that has two cables, a white and red). Just plug one of the cables (the red or the white but it has to be the same color on both connections) into the receiver and the sub-woofer.
You'll be ready to pump up the bass.
Enjoy and thank you for using Fix Ya
Mikeywaf
Mar 12, 2011 | Audio Players & Recorders
QUESTION ABOUT SPEAKERS. SPRCIFICALY WOOLFER. WHAT KIND OF WOOLFER SHOULD WORK BEST WITH THIS AMP?
hi,
Do you mean sub woofer. Then you can select any brands Active sub woofer ( active means built in amplifier) to connect with your system. They comes in different power (watts). you can use an active sub woofer with 100W output.
connect the sub woofer pre out of you amp to the pre input of sub woofer.
ok
Feb 05, 2011 | Technics SA-EX500 Receiver
The cord /with the pin on both ends that plug in the back of sub woofer & dvd player, i need the female ,plug that on the back of sub woofer
The part is called a Din connector. You may be able to find it at www.jvcservice.com You will probably need to use the sub-woofer or the system model #, it is not listed under th-c30
FYI replacing it is not very easy.
Mar 26, 2010 | JVC TH-C30 System
Programming a Denon AVR-1907 to activate the sub-woofer
In the setup menu on your denon receiver make sure the subwoofer setting is set to ON or YES.
Feb 28, 2010 | Denon AVR-1907 Receiver
Subwoofer.......
Please check your model number, I can not find it on the JVC service website.
This is a powered sub-woofer I think. You need to have a thick black cord that connects the sub to the head unit. Then the satellite speakers get connected to the speaker jacks on the sub-woofer box. The sub-woofer should also be plugged into an A/C outlet on the wall.
The speaker outputs are labeled right there where you connect the speaker wires. You should see a red and black connector for each speaker and they are labeled "front right" "front left" "center" "rear right" "rear left".
If you do not have the thick black cord you need to connect the head unit with the sub-woofer, you can not use this system.
If you look at the head unit and give me the model number on it, I may be able to find the part you need. But I must have a good model number to work with, preferably from the head unit.
Dave
Nov 10, 2008 | JVC SPPWA670 Subwoofer
Hi I own a Technics Hi-Fi system (Model SC-EH780) and would like to attach a subwoofer to it. I cannot find the subwoofer unit that is supposed to go with this system. Can you help?
Any powered sub-woofer will work with it. Check the back of the Technics, make sure there is an RCA output labeled "Sub-woofer" or "Woofer" or "Sub". If so, you can get any brand of powered sub woofer and it will work. A powered sub-woofer is one with an amplifier for the sub built into the box and you will need to plug it into an A/C outlet as well. The only exceptions to what will work with this unit is to make sure you are not buying a sub-woofer that is made to only work with the companion unit it is originally sold with. Many Panasonic and JVC sub woofers are like this. Just look for a sub-woofer that is not part of any system. Velodyne makes some really great sub-woofers that would work nice with yours, but they can be a little expensive, but they are very good.
If your Technics has no RCA output for the sub-woofer, you will need to make sure that whatever powered sub-woofer you buy has a speaker level input for it. Most powered sub-woofers have this feature, so that you may just run the front speaker outputs of the receiver into the subwoofer and then the sub-woofer will have a set of speaker outputs right below the speaker inputs so you can still have your front speakers connected to that and not loose anything from your system.
I hope I have explained this in a manner you will understand easy, if not just post whatever questions you may have right on this thread and I will get back to you as soon as possible.
It would also be appreciated if you could rate this solution if you no longer need any help from me. If you do require more help, please wait to rate this until we are finished. That way I do not get an undeserved bad rating when we have not even finished our communications.
By the way, A "Thanks for trying" and "Helpful" rating are really not good, they always end up lowering my overall score.
Dave
Nov 09, 2008 | Audio Players & Recorders
RCA Sub-Woofer
Did you try making sure the subwoofer is turned on under the set up menu on the Sony Receiver?
Press Set Up, Press the left or right button above the scroll wheel until you get to SW. It should say SW: ON or SW: OFF. If it says SW: OFF, use the Scroll wheel to scroll right until it says SW: ON. Also, make sure you aren't in 2CH mode, try A.F.D or surround sound.
Jul 26, 2008 | Sony STR-DE445 Receiver
Sub-Woofer
Jun 01, 2008 | Panasonic SC-HT930 System
Help with SB-WA920 sub woofer PLEASE!!!!
Sep 07, 2007 | Panasonic SC-HT920 System
JVC TH-M505 System Logo
41 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
