Question about Canon EOS-5D 12.8 Megapixel SLR Digital Camera w/ EF 24-70mm Zoom Telephoto EF 70-200mm f/ Autofocus L
With fully charged battery 5D has power but will not take shots
I removed the CF card the other day to put another one in - have done this many times. However now, there is power (can see on display) but camera will not zoom or take images. I replaced old CF card to double check in case new one was faulty - but nothing. Can someone help please...? Battery is fuly charged, CF door is closed. I even changed the lens just to try something different - nothing!
  • 36 Answers
This sounds like your release switch is faulty. I have repaired several of these 5D cameras with similar strange symptoms. Basically what happens is the first switch on you release assembly cracks and breaks thus making continuous contact. When this happens it basically locks up your camera. The solution is to replace the release switch assembly. The repair should not cost you more than $150.
Hope this helps.
Wes Kauffman
Posted on Jan 06, 2009
The battery runs out everytime when i forgot to remove it from my camera.
How old are your batteries? Try a brand new (I mean a new in the package, not one you think is new) battery and see if this works OK. If it does then your batteries are worn out and should be replaced (a very common problem I see almost every day). If a freshly charged brand new battery does this then you have a short - probably in the DC to DC power board. You may also have a short caused by a loose screw that is floating around inside.
Feb 26, 2012 | Canon EOS-5D Digital Camera
My Canon 5D mkI turns on ok, will focus, displays top and back, but it will not take a shot. I have two batteries, both which I have charged to full and tried (display shows full charge). I have also...
hicould you tell me the amount of shot number when you put memory card in? If yes, please move to manual position from auto on the side of lens. And try to press release button.there is other one thing you have to chack selftime release working or not. just let me know.
Jun 04, 2011 | Canon EOS-5D Digital Camera
Error 99 keeps coming up I reload the battery turn on off but after a few shots it comes up again and the red shows indicating that it is still processing the shot.
Here is the diagnostic process, allegedly from Canon themselves. It's quite old, a newer camera probably has a SD card rather than CF.
To isolate the cause of the issue, we [Canon] suggest that you do the following:
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the "ERR 99" message appear? If it does, then the camera should be serviced. If it does not, then please proceed to the next set of steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the "ERR 99" message appear? If so, then the CF card is the most likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser or soft cloth. Be careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the "ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the "ERR 99" with a different Canon lens attached, then the camera should be serviced.
Jan 19, 2011 | Cameras
Canon eos 400d error 99, shooting not possible. turn the power swithch on off again or re-instal the battery. It has been doing this for a long time and nothing is working to fix it! Thank you,
1.Remove the battery, lens and CF card. Allow the camera to sit without power for 20 minutes and then reinsert a fully charged battery.
2.Turn the camera on and push the shutter button as if you were taking a picture.
3. If you don't get the error message reattach the lens and insert the CF card.
4. Check the below canon eos 400d service manual link:
http://goo.gl/LHYVAy
it will help you to save a lot of money
Hope it helps, Thanks
Oct 22, 2010 | Canon EOS 40D Digital Camera
Canon 5d cannot format cf care
Hi there, did you check the card itself? SD cards have a locking switch on the side. Move the switch from locked to unlocked. Put it back in the camera and see if that helps.
Rob
Mar 02, 2009 | Canon EOS-5D Digital Camera
I have a Canon Power Shot s400 and am having a problem formatting the CF card. I have three different CF cards that I have been using for some time and have formatted them before but they are now not...
you most likely have damage in the card socket. you might be able to look into the card slot anf see if any of the contacts are bent, but most likely the socket will need to be replaced.
Nov 06, 2008 | Canon Cameras
Minolta Maxxum 5D
The P-channel MOSFET switching the CF power is dead. It is on the little board directly above the battery compartment. SOT23 package, the marking is 338 or something like that. Replace it and it will work.
Mar 04, 2008 | Konica Minolta Dynax 5D / Maxxum 5D...
No take picture!
Hi John,
Try using the AC Adapter as your battery.
atdlee@netzero.com
Jan 06, 2008 | Canon EOS-5D Digital Camera
NO POWER
I would have to agree sounds like a motor or gear that the motor turns.
Dec 10, 2007 | Canon Digital Rebel / EOS-300D Digital...
Canon EOS-5D 12.8 Megapixel SLR Digital Camera w/ EF 24-70mm Zoom Telephoto EF 70-200mm f/ Autofocus L Logo
102 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
