Question about Elna Sewing Machines
My buttonhole foot doesnt move when i sew - Elna Sewing Machines
rizla
  • 1463 Answers
SOURCE: I need instrutions on how
hi hrkids
will anything thing here be of help XL-2600/2600i/2610:
riz.
Posted on Apr 21, 2008
  • 323 Answers
SOURCE: buttonhole
Dud you pull the button hole lever down so that it engages the foot?
sewman7
Posted on Jul 18, 2008
SOURCE: machine will not complete a buttonhole, keeps showing error code 6L. No error code listed in manual. Machine will only do first half of buttonhole and then shows code and stops.
I've been looking too and I found here http://sewing.patternreview.com/cgi-bin/sewingclasses/board.pl?t=18328that you need to put the bar behind the needle threader down. I think they call it a button hole stop? I don't know, but it worked. I didn't even know it existed. But it solved my problem. On my Kenmore it looks like a black lever and you pull it down. It tells the button-holer that you are at the end of the hole and it needs to backup. nifty, kind of.
Posted on May 27, 2009
  • 8 Answers
SOURCE: buttonhole problem
When doing the button hole....after installing the button hole foot and lowering the foot....and adding the button so the automatic button hole size is determined...you lower the button hole lever it will touch the back of the button hole foot. this holds the button hole foot in the proper position...if this lever is not all the way down...the machine blips at you...check to see that it is down all the way...I hope this helps you..It truly does all that it advertises and is a great machine...BBill01
P.S. you can adjust width and length of the stich also...see instruction manual. pg 28-30
Posted on May 30, 2009
SOURCE: I am trying to make a buttonhole using the
if you have a automatic buttonhole , then you should have a buttonhole lever that you have to pull down, before you start to do the buttonhole,, my machine will not let me do a buttonhole unless I pull down the buttonhole lever
Posted on Nov 17, 2010
Instructions for making a buttonhole
The method will depend on your make & model machine, although the vintage sewing machine buttonhole method will work on all zig-zag machines (just requires manually measuring and adjusting the stitch length & width during the process):
How to Use an Automatic Buttonhole Foot
Sew Buttonhole in 4 Steps on your Singer Sewing Machine
Sewing Buttonholes Without Buttonhole Foot
How to Sew Buttonholes with Regular Foot Sewing Tutorial with Alison Smith
How to sew buttonhole with an old machine
How to Sew Button hole tutorial
Sew Buttonhole without Buttonhole Foot by Create Kids Couture
Be sure there is a stabilizer between the fabric where the buttonhole is located so the fabric will not stretch or tear.
Jan 09, 2017 | Sewing Machines
When using buttonhole attachment, machine does not move instead sews in one spot and collects thread coming up from bobbin. Any ideas?
make sure the buttonhole option is chosen
and then pull down the buttonhole lever
it should come down against the buttonhole foot
Apr 25, 2016 | Singer 5400 Sew Mate 60-Stitch Sewing...
E1 flashes on the message window of my brother sewing machine
Brother Computer Codes
  • E1: Make sure the presser foot is lowered before sewing.
    E2: You chose a stitch other than a buttonhole stitch or a bar tack stitch and you tried to sew with the buttonhole lever in the lowered position. Raise the buttonhole lever.
    E3: If you selected the buttonhole or tack bar stitch and start to sew with the buttonhole lever raised, you will get the E3 code. Lower the buttonhole lever.
    E4: You hit the reverse button while the bobbin winder shaft was moved over to the right. Move the bobbin winder shaft to the left.
    E5: On automatic sewing machines, the start/stop button was pressed while the foot controller was plugged in. Unplug the foot controller if you are using the automatic function.
    E6: This code tells you that the motor locked up because the thread is tangled. Untangle the thread, make sure the machine is threaded properly and that the proper tension is set before continuing.
Oct 03, 2012 | Brother CS-6000
I get a E4 code whan I turn on machine and I can't figure out what is wrong.
Brother Computer Codes E1: Make sure the presser foot is lowered before sewing.
Sep 21, 2012 | Sewing Machines
I have a 9960 singer machine and am trying to use the buttonhole presser foot for the first time and I can not get it to sew T
the buttonhole foot snaps on to the presser bar, there's a little lever at the back of the presser bar that releases the foot, then put the buttonhole foot down on the needle plate & use the presser foot lifter (number 11) to lower the presser bar down onto the buttonhole foot & you'll hear a click sound when it snaps on & make sure to use the buttonhole lever(number 31) because the machine won't sew a buttonhole unless that lever is pulled down.
Apr 26, 2012 | Singer Sewing Machines
I am trying to sew buttonholes with the one step button hole function on my Singer 3116 - Simple. I have been using the function with no issues, but now for some reason, the machine is stopping short and...
There doesnt seem to be a reason - you are doing everything as it should be - lever down to stop the foot according the the button size is the most overlooked step.
I would take the buttonhole foot off and see it is moving as it should. Don't force as the plastic parts can break and then try again to make the buttonhole.
If you still cannot make the buttonhole, the problem may be the control switch and this would have to be checked by a Singer Sewing Machine Tech.
Check your warranty - faulty switches are covered for two years, but you pay the labor.
Mar 29, 2010 | Singer 3116 Simple
My automatic buttonhole attachment won't make
This is not the problem of the thickness, but of the softness. Fleece will pull unevenly, causing the dogs to simply tug at layers of it in place, instead of moving it. You will have to (GENTLY) assist the dogs in moving your fabric, if your fabric is this soft.
The cause of this is 90% on the fault of the fabric, and 10% on the way the buttonholer foot works. The foot is built to hold the fabric fast in place, with sliding action only permitted by the buttonhole guide. However, this is assuming the dogs can get enough purchase to move the fabric around. Simply put, again, you will have to help the dogs along with this one(you will be able to clearly feel the difference and which way the dogs "Should" be moving at the time when you attempt to, as once it catches in one direction, it is likely to keep going in that direction until the dogs stop.)
Jan 24, 2010 | Singer 7444 Mechanical Sewing Machine
Need instructions on button holes
Move the width bar to between 4 and 6, the higher number makes a wider buttonhole. Move the length bar to the middle or right of the buttonhole icon. Set the selector dial on #1, snap on the buttonhole foot with a button snugged up in the back slot. Pull down the button stop lever behind the needle threader and make sure it is lower than the edge of the buttonhole foot, and behind the little tab on the left side of the buttonhole foot. Position the needle over where you want the bottom of the buttonhole to be. It will bartack, sew backwards, bar tack and sew forward based on the size of your button. When it is finished it will stop sewing. Turn the stitch selector dial to #2 to reset, then back to #1 to sew the next buttonhole. Practice on scraps until you are happy with the stitch length and width.
Apr 07, 2009 | New Home MX-3123 Computerized Sewing...
Buttonhole instructions needed for Singer 7422 Advance
These are the exact instructions from the Manual. 1. Select one of buttonhole patterns.
2. Replace the presser foot with the buttonhole foot. (Install presser foot with little red mark towards the front)
3. Insert the button into the buttonhole foot. (the part located in the back crescent shaped)
4. Lower the buttonhole lever (to the left of the needle) so that it drops down vertically between the stoppers A and B.
5. Carefully mark the position of buttonhole on your garment.
6. Place the fabric under the foot. Pull out the bobbin thread underneath the fabric to a length of about 4 inches to the rear.
7. Align the buttonhole mark on the fabric with the mark on the buttonhole foot, and then lower the buttonhole foot.
8. While holding the top thread, start the machine.
*Sewing will be completed automatically.
9. When sewing is finished, use a buttonhole opener to open up the frabric in the center of the buttonhole. Be careful not to cut anyt of the seam thread.
I hope this helps.
Mar 28, 2008 | Singer 7422
Sewing Machines Logo
119 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
