Question about Garden
Cant open water tank for sc1202 karcher - Garden
On my Karcher 2600, I filled the detergent tank but as I was washing the bus none of it was coming out, it was still full when I finished, any suggestions Ted?
I see this lots of times , the detergent tank will only mt in the low pressure mode of nozzle , this is the only way a siphion will develop inside the soap tank and then high pressure can be used later to wrinse the item off well using just water
Nov 06, 2015 | Karcher Garden
Karcher K2 seams to be directing pressure to soap
If you use the wrong tip when trying use pickup tube, you will force water into the tank. You can only use the low pressure suds tip. There are typically 4 tips- 0 deg, 15deg, 40 deg and a soap tip. You cant pressure wash and use soap at same time.
Oct 04, 2014 | Garden
Water coming out of detergent pipe from top for karcher 3030 b jet wash
DISCONNECT HYDRO OR WITH ENGINE NOT RUNNING DISCONNECT SPARK PLUG THEN RE-LEAVE WATER PRESSURE BEFORE SERVICING the detergent pipe plugs into a pipe on the pump, under which is a spring and ball bearing (stuck open, debris) WEAR YOUR SAFETY GLASSES
Apr 01, 2014 | Karcher Garden
Karcher vaporapid 1105 manual
there should be a labeled fill line on the clean water resavore
Mar 26, 2014 | Karcher Vacuums
I purchase a new water intake fitting for my karcher 395 and can not figure out how to swap it with the broken fitting
I think there are 4 bolts you have to take out, they are at the end of the pump,, but i think the intake and output are on that part,,,also if you ever cant find a karcher pump a king will fit
Jul 28, 2010 | Karcher 2500 PSI Pressure Washer
What to do found water in gas tank of pressure
have you drained the tank, and disconnected the fuel lines from the carb. so that the carb will drain? if not you need to get the water out of the carb. the put some rubbing alcohol in the new gas and this should get rid of any residual H2O
Apr 17, 2010 | Karcher 2500 PSI Pressure Washer
Hi,karcher hds hot pressure washer now pressure when you pull trigger and pulses.
what you need to do is, take the screw fitting which goes to the water tank off, then the one that goes from the water tank to the pump head .
then put the one that was in the first place going to the water tank on to the pump and force feed with water.
see if you can see water leaking from any where seals hose.
try running the machine to check the pressure.
if water leaking from pump head you need seals.
Mar 21, 2009 | Karcher Garden
Wont heat up
I know that Karchers steam cleaners have had issues with the thermal overload. I have repaired Karcher machines that got turned on with no to little water in the tank and it would heat up really fast and trip the thermal overload. The thermal overload is to reset it self when it cools down but the problem has been the thermal overloads get stuck and dont reset. When they stick, they will give the same signs you have said. In those cases the thermal overload has needed replaced. The thermal overload did its job to trip, but it fails when reseting. I understand you don't want to throw more money into it, but that is the only thing you can do. You can get the part and do it your self, but they are tricky machines to get into and you dont want to break something trying to get in. Hope this helped.
Mar 25, 2008 | Karcher DE4002 Steam Vacuum
Karcher 620M not drawing water
my 620m has a problem when i press the switch on it has no pressure and the pump sounds like it is not kicking in .... plese help !!!
steve ..
Jan 08, 2008 | Washing Machines
Garden Logo
37 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
