Question about Konica Minolta magicolor 1690MF All-In-One Laser Printer
How to solve i/c life end, change i/c in konica minolta1690mf
I have crossed check i/c unit and found that i/c unit is ok. After that i have replaced PRCB but problem is same. After that i had checked i/c connector and it is also ok. Please give solution.
2 Suggested Answers
canontech
  • 1219 Answers
SOURCE: Hello, I just replaced my K toner in a Konica
it's probably fault in K toner chip. Try with new toner.
Hope that helps!
Posted on May 29, 2011
What is ic life end
Imaging unit life end.You must be change the developer and perform F8 to new developer.More info please the copier model.
Jul 18, 2014 | Konica Minolta Office Equipment & Supplies
Replacing picca fuse on Konica color 8020 fuser unit
Not recommended because the fuser unit has reached end of life, that is why its displaying the indication,
Feb 05, 2014 | Konica Minolta Office Equipment & Supplies
I have changed the setting of the dev unit of the Konica minolta C360 to No life But it still says replace unit. The printer is still giving excellent prints
it continue to showing this error and u have to press ok
just make prints till print are coming ok
after that u have to change unit
Aug 06, 2013 | Konica Minolta Bizhub C360
How can i settle the problem of magenta developer finishing so fast. Magenter developer for Konica Minolta Bizhub C550 is getting finished so fast.
If the message Change Imaging Unit Magenta displayed refer to imaging unit with contents a developer.The Imaging unit life is 80.000 copies.
The imaging units located after front door when is located the waste toner box.
If the message M toner end/change the M toner displayed refer to toner cartridge
The toner cartridge life 15.000 copies 5% saturation.In full color mode the color saturation is 80% and the color toner life is 6.000-8.000 copies.
I think your problems is a toner not the developer.
Apr 11, 2013 | Konica Minolta Bizhub C550
Reset image unit (Magenta) Konica Minolta Bizhub C352
Change the chip or enter in service mode and change the imaging unit life duration to long life.The copier displayed continuosly Please change the image unit,press OK and ignore.
Feb 13, 2013 | Konica Minolta bizhub Office Equipment &...
Ihave konica minolta bizhub 43 i replaced anew fuser unit but its still showing consumable error replace fuser unit how can i solve this
Enter in the service mode: press Utility key-Metercount-(Details if exist)-Stop -0 0 -Stop -0 1 select a special parts life or in the counter mode consumable and reset the fusing unit counter.
Feb 04, 2013 | Konica Minolta Office Equipment & Supplies
Imaging units for Bizhub C300
There is no setting you can extend the life, however, in the service mode ( utility->meter count-> stop, 0, 0, stop, 0, 1) then press stop, 0, c. There should be a setting in there that you can disable the "image unit life end stop" setting. You will get a message every 5 minutes telling you to change the unit, but your machine won't stop working. Otherwise you can just change the chip in the image unit.
Jul 26, 2010 | Konica Minolta bizhub C450P Laser Printer
My Bizhub C350 has locked due a imaging problem. There are solution without change the imaging unit?
once the machine locks you out for a imaeg unit you are done until the unit is replaced or reset chip is installed but there is new firmware that can be installed in the machine that wil not stop the machine from usage was the image unit has reached end of life so the next time a service tech comes out tell them you want the new firmwareand set image unit life to suspend
Dec 06, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta magicolor 1690MF All-In-One Laser Printer Logo
52 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
