Question about Car Audio & Video
Does the light always on (on the pioneer deh-45dh)
Hi, when i turn off the key and i step out of the car i notice my pioneer deck is still on, and i was wondering does this usual for this deck. is there a way to turn the light off? and does this drain my battery?
  • 2 more comments
  • yang313 Jan 05, 2009
    no the radio does not turn off any time and i install it myself. okay, i'm saying the light in the deck still lights up, like it not off. but when i turn the key off and out of the igntion the deck still lid up... that's the question is that usual for this deck?
  • yang313 Jan 06, 2009
    no. it just lid a light around the face deck...
  • lee r
    lee r May 11, 2010
    one more question. after you turn the car off and get out will the radio still play and function as if the car where on?
  • lee r
    lee r May 11, 2010
    does the radio turn off at any time. and where did you get it installed?
    Sergeant:
  • 152 Answers
Them yes, it is normal. the small light around the deck is just a feature to make it look nice. it wont hurt the battery, it uses no more electricity than it does to save the presets in the radio. your good:-)
Posted on Jan 06, 2009
Wiring diagram pioneer deh 45dh
You can try to obtain a diagram from Pioneer
Mar 23, 2013 | Car Audio & Video
Need service manual for pioneer DEH-45DH
Send your email address to me, and get a copy of the service manual by return mail.
Jun 23, 2012 | Pioneer Audio Players & Recorders
Does anybody know where i can find the receiver harness for the pioneer deh p3700mp got the thing of a friend for free but didn't come with its own harness
Any Local Car Audio Shop that does installs. Check with the guys in the install bays. They always have spares. Many decks from Pioneer use the same harness. Hope this helps
Jul 02, 2011 | Pioneer DEH-P3700MP CD Player
How do you remove the Pioneeer DEH-1600 radio from the dash of a car is there a special tool or do you have to get up behind the dashboard
remove the trim plate(thin plastic strip around your deck) you will see on the center of each side slots for two thin deck keys these always come with a new deck. you you dont have them ask a friend who has recently bought a deck(any make should be fine) or go to your local best buy and ask for a set MAKE SURE YOU ASK FOR THEM FOR FREE unless the installer you asked has purchased his own universal keys they will give you them.
Aug 26, 2010 | Pioneer DEH-1600 CD Player
How to
Please follow the following instructions 1)Use a wiring harness equipped with an adapter plug for faster connection and installation.Disconnect the car battery while installing electronic equipment.
2) Make a note of the wire colors and connect the power supply wires to the DEH-45DH as follows:
Orange wire to the constant 12Volt
Yellow wire to the switched 12Volt
Black: ground wire
3) Connect these wires to control display functions on the DEH-45DH:
Attach the gray wire to the wire marked control panel illumination.
The brown wire connects to the dimmer.
4) Make the front speakers connections following this color scheme:
Left front positive (+) tan wire
Left front negative(-) Gray
The light green wire connects to the positive (+) terminal of the right front speaker.
Connect the dark green wire to the negative (-) terminal of the right front speaker.
5) Make these rear speaker connections:
Brown wire to the left rear positive (+) terminal
Yellow wire to the left rear negative (-) terminal
The dark blue wire attaches to the right rear positive (+) terminal
The light blue wire connects to the right rear negative (-) terminal
Hope this helps
Thanks
Smith.
Sep 09, 2009 | Car Audio & Video
Pioneer deh-2000r wiring
Pioneer usually use:
red - 12 volt batt. ignition/acc
yellow - 12 volt batt. memory
black - ground
blue - power ant.
blue/white - amp turn on
orange - illumination ( 12 volt light ) ( not all deck )
orange/white - dimmer ( not all deck )
gray - right front +
gray/black - right front -
white - left front +
white/black - left front -
violet - right rear +
violet/black - right rear -
green - left rear +
green/black - left rear -
Is this what your looking for?
Dec 01, 2008 | Pioneer DEH-1600 CD Player
Pioneer DEH-14 display not lighting up...... help?
The display only lights up when correctly wired to the lighting system.
Jan 11, 2018 | Pioneer DEH-14 CD Player
Pioneer Premier DEH-P730
Pioneer follows standard color coding for stereo/headunit wiring. Pioneer car stereos needs two wires plus the ground wire to be activated. The yellow is connected to the always on B+12 such as the positive terminal of the battery, the red goes to a switched B+12 such as the ACC of the IGN switch while the black of course goes to the chassis/body ground.
Should the above been done correctly and problem persist, then perhaps the fuse may have blown, there is a loose connector at the rear of the head unit or a probable internal electronic defect has developed.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 11, 2008 | Pioneer DEH-P730 CD Player
Pioneer DEH-P640 Car CD Player
Does the player has the 12v needed on the rem side to light the player? If so then there maybe a short in the lamp area, if you tapp on player do light come in and goes out?
Sep 10, 2007 | Pioneer DEH-P640 CD Player
Car Audio & Video Logo
133 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
