Question about GE JVM1650 1000 Watts Microwave Oven
No power my micro wave has no power and we replaced the fuse...what else can be the problem???the vent doesnt work
  • mandikivui Jan 09, 2009
    yes team...the microwave has no power , no buttons working it just went dead.Model # is LMVM2055SB and has a serial # 601KMPF00792
  • William Miller
    William Miller May 11, 2010
    Is it dead, meaning no
    display, no light when you open the door and no beeps when you press a
    pad on the keypad?
    Is the outlet working?
    Please reply back with your brand and model number so we can help you.
  • GE Master
  • 9,098 Answers
The three items I would suspect are the 20A fuse on the filter board near where the power cord comes in, the magnetron thermostat, or the oven thermostat.
If those are good, would then you have a problem on the control circuit board, which
we regularly repair for customers nationwide by mail for $39.95 postpaid in about a week with a one-year guarantee.
We have the service manual for this model and have uploaded it to our site here to help you.
You will need the
free Acrobat Reader to view or print it in case you don't have it.
Accessing the oven thermostat for testing will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
L.G. / Goldstar owner's manuals can be downloaded here. If it doesn't show up in the search, I would call or e-mail them via the CONTACT US link at the top right.
Posted on Jan 10, 2009
Microwave sometimes heats up food and sometimes it does not.
usually when you kill the power and then when you put power back on the machine works it's the computer board that's bad.all you're doing is resetting the board just like your house computer,if something happens to it you shut it down and reboot it,that's what you're doing with the micro wave just rebooting the board.here's the funny thing about micro waves sometimes the part you're gonna change is almost the same price as a new micro wave so i would first check how much the board is,i went on sears and they have the board for 115.00 repair clinic for 235 part number WPW10216347 they don't make this model anymore but you can get a stainless micro for around 290 to 300 dollars and if you buy the same brand all you should have to do is remove the bolts up above that hold it in place and remove the micro wave and the same brand should mount the same way so you won't have to drill new holes or replace the back metal panel.if i were you i would replace the unit instead of the board repair clinic shows most of the parts for this model out of stock so it might be a while before you can get any parts for this model but this is up to you.good luck with your micro wave.one more thing when you were in there did you see alot of grease,this is usually the cause of no heat,the grease from cooking on the stove top gets into the micro wave and on the mag tube and damages it,if there was grease in there i would just replace the unit
Dec 15, 2017 | Whirlpool WMH2175XVS Stainless Steel 1000...
My Emerson microwave is about 2 years old. I washed it just like I do every week and the power went out on it.
you mean it want power up or want work when you press the star buttom?
1. check the fuse if no power.
2. If it doesn't work when closing the door after setting timer it is the micro switch that the metal lach hits when the door close.
3. unpluge the micro wave unscew the scews to the cover of the microwave remove the cover. up front by the door you will see the micro switch maybe (brown,black,white,red/white ) what ever color it is disconet it take it to the hardware store buy a new one and replace it,themreasemble your micro wave.
Oct 30, 2010 | Emerson Microwave Ovens
Acts as if there is no power but power at the outlet. Neither micro nor vent fan nor light work. Please advise.
Their is a fuse insite the body behind the control panel. You need to replace the fuse.
Sep 29, 2010 | Sanyo EM-S8000 Microwave Oven
My microwave starts however food does not heat up.
Micro wave as the name suggests produces heat when the micro waves aimed at an object causes the water molecules inside the object to vibrate hence producing heat.The gadget responsible is the magnetron. If your magnetron is not receiving ht voltage or receiving but faulty, then your micro wave wont work please take precaution when opening micro wave due to high voltage caps that remain charged sometimes even when it is off.check the high voltage fuse/ diode and capacitor if they are fine and the step up trans former o.k then the only option is to replace the magnetron
Aug 02, 2010 | GE JVM1790 1000 Watts Convection /...
Micro wave simply quit. How an I check to see if
The fuse is located inside the microwave. You will need to remove the front panel to get to it. It will be located on the black power wire inside the microwave and installed inline. Make sure that the microwwave is unplugged before removing the front panel. Once you locate the fuse inside you will need to remove it and test it with a continuity tester to see if it is blown. If it is make sure you replace the fuse with the same amp rating you found. If the new fuse blows again then there is an electrical short somewhere inside the microwave.
Dec 24, 2009 | Emerson MW8778 Microwave Oven
Amana aco 1840 over stove micro wave. heating not working .
FIK IT THE HEATING ELEMENT IS STRIGHT FORWORD AND COST IS CHEAP, GO FOR IT .
Oct 24, 2009 | Amana ACM1580 Convection Microwave Oven
HOW DO WE VENT THE EXHAUST OUT THE TOP OF OUR MICROWAVE when we turn the exhaust fan on it blows out the front but we thought it went out the top so we could vent through a cupboard, attic to the outside
You will have to remove the micro wave from it's mount. Once you have it down, look at the top of the micro wave. There will be a panel that you will have to move from one place (where it is now) to another. This panel will either be on the top of microwave or if the mounting kit has a top plate, it will be on it. The panel normally has two screws holding it in. When you remove it, you will need to re-install it so that it blocks the air flow from coming out of the front. There should already be screw holes where you are to install it. When you have it moved, re-install the micro wave.
I hope I didn't confuse you. The only reason it's not blowing out the top is because whom ever installed it didn't move the panel. All over the stove micro waves come with this movable panel so you can vent it either way you want. If you have the installation papers, it will explain this better. Good luck.
Oct 17, 2009 | Frigidaire Microwave Ovens
Oven appears to function normally but doesn't cook at all.
With micro waves, this could be a number of things. They are hard to diagnose using this forum but I'll try. There are three things you can check. One being the thermal fuse. On some models, when it goes bad it put some things out. with others it puts every thing out.
if it's good, check the mag tube (Magnatron). Most of the time, it will be burned on the end if it's bad. tube. The last thing would be the fuse. It is made of ceramic and is a 20amp. It looks like a old round car fuse but it's not. It's made just for micro waves. Honestly, if the thermal fuse and the round 20 amp fuse is not the problem, you may be able to replace the micro wave cheaper than replacing the parts.
Thermal fuse $28.99.
Round 20amp fuse $1.53
Transformer $100.00.
Mag tube $87.00
Capacitor $45.00
Go to www.appliancepartspro.com and enter your model number. This will pull up every part in the micro wave and their prices. Then you will ba able to decide if you want to replace the parts. With yours being one that's built-in over the stove. These cost more and are worth putting more into. If I can help any more comment back and I'll do what I can.
Please rate solution
Sep 07, 2009 | Maytag MMV5186A Microwave Oven
No Power
HI, there is a inline fuse located inside the microwave ion the power supply board. check for continuity. replace the fuse if necessary. if the fuse is OK, replace the power supply board.
Jun 01, 2009 | Kenmore 62702 Microwave Oven
GE JVM1650 1000 Watts Microwave Oven Logo
113 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
