Question about Dryers
It over heated now it won't come back on
    Top Expert:
  • Dryers Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Nov 09, 2012
Oven won't heat.
Good Afternoon Gwen - Try reprogramming the range by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn the unit back on. If issue persists, then the unit could possibly be experiencing an issue with a wiring failure, EOC (electronic oven control), sensor probe and/or faulty bake or broil element. I would strongly recommend consulting a professional to narrow down the precise issue before investing in parts that may or may not be the root cause.
May 15, 2013 | Frigidaire Gallery 30" Self-Cleaning...
Heater fan on electric fireplace not working, so heat shuts off and won't come back on. The manufacturer is Southern Enterprises, Inc., model no. FA515500TX.
Was having same problem, found the fan needed a little oil on bearings. Was not spinning up to full speed so heater was cylcing on high limit
Jan 21, 2013 | Southern Enterprises Luxembourg Ivory...
I have a montgomery wards furnace model srm54013a. won't shut off, keeps putting out heat
SOUNDS LIKE A BAD THERMOSTAT OR THE RED & WHITE WIRES IN BACK OF STAT ARE TOUCHING ONE ANOTHER COMPLETING THE CALL FOR HEAT.
Dec 25, 2012 | Heating & Cooling
Reset frigidaire dishwasher model FDB1100RHC
I had the same issue. I unplugged the dishwasher and plugged it back in. Bam! It's working fine now.
Oct 16, 2012 | Frigidaire Dishwashers
Cook top won't work and oven won't heat
check the plug it sounds like the plug is not secure only getting one leg of current push in firmly
Jul 29, 2012 | Maytag MER5775Q Electric Kitchen Range
I am trying to take off the struts on my 98 Buick Lesabre and the bottom studs won't back off. Are they're any tricks of the trade anyone knows of? I tried soak'n em in WD40 and torching t
if they won`t come out by soaking them or using a torch you may have to put the nut on the bolt so its flush with the end of the bolt and hit it with a big hammer or use a air hammer to move it.not sure where you heated it but heat the strut where the bolt goes through it and you have to use an acetelyne torch not a propane torch as the heat is hotter with a acetelyne torch.be aware that you may have to replace the bolt and nut if damaged.
Apr 02, 2012 | 1998 Buick LeSabre
Kenmore 80 series dryer won't start.
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. To determine if the door switch has failed, watch this part testing video.
On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Aug 21, 2011 | Dryers
My iron won't heat. it has electricity but won't heat
Here is a tip that I wrote about Electric Irons and why they do not heat....
Electric Ironnot Heating Up or not Working Right heatman101
Jun 25, 2011 | Rowenta DE-480 Iron
I can't get the control panel to reset. The wash cycle light comes on but it just beeps and the dishwasher won't start. I press the start button and it stops beeping for a minute but it still...
II might need the actual model number. However, you can go to page 9 on this manual and check if the flashing options can fix the problem. I am assuming you have already tried to turn the power off and back on.
The ohter thing to try is the reset sequence. Within 6-7 secs press High Temp/ Heat Dry/ High Temp/ Heat Dry/ High Temp/ Heat Dry. All lights should light up, press Start button to exit.
Jun 24, 2011 | GE Nautilus 24" Built-in Dishwasher
Dryers Logo
Top Dryers Experts
