Question about Xerox WorkCenter PE120i All-In-One Laser Printer
Xerox WorkCentre PE120i - Paper Jam 1
While printing an envelope, I pushed it back and tear it.
I removed the part of the envelope I was pushing and the teared part from inside. There is no paper anywhere to be seen inside.
The machine reports persistently a "Paper Jam 1" ("Open/Close Door"). Even after opening/closing the door, turning it off, disconnecting from power.
I have seen your answer regarding some sensor on the bottom of the machine. I can't find it, or know what is its' visual appearance. Can it be a/the solution?
Xerox estimates this as an 130 € repair.
TIA.
  • pe120 Jan 28, 2009
    I have seen that suggested elsewhere, and solved it like that, with card stock. This Xerox doesn't [Print] with the jam, one has to force feed it.
    Thanks.
    President:
  • 8,637 Answers
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Jan 28, 2009
Try reseating the toner cartridge, especially if you have just replaced it.
Posted on Mar 17, 2011
I need need a picture on how to remove a paper jam in xerox 4118 machine right now please
Well open the printer where you can(the closest point to the jammed paper) attempt to remove the jam by attempting to pull the Jamed paper in the direction it would normally exit the machine.thats about as far as I can get you with the information I have--Good Luck.
Feb 01, 2013 | Xerox WorkCentre 4118 Network Kit - 1 x...
Need drivers for Windows 7 for my xerox workcentre pe120i
A Windows 7 driver is not available, but you may find that the Vista driver works OK. You can get it here:
http://www.support.xerox.com/support/workcentre-pe120-pe120i/downloads/enus.html?operatingSystem=winvista&fileLanguage=en
Feb 15, 2011 | Xerox WorkCenter PE120i All-In-One Laser...
My Xerox Workcentre PE120i screen says [no paper] "Add paper". but the tray is full of paper. What do you suggest I do?
This is a fairly common problem with most printers. It is generally caused by something confusing the sensor that detects the paper.
1) Remove all the paper from the printer.
2) Switch off the printer and unplug from the mains for 30-45 seconds
3) Switch printer on
4) Put in paper
5) Try and print!
Most of the time this will cause the printer to "reset" itself and should print fine.
Regards,
sjstore2
Dec 20, 2010 | Xerox WorkCenter PE120i All-In-One Laser...
Paper jam in a Xerox Comy Centre C20
A couple of things.
There is a bushing at the front of the exit transport that fall out of the frame. That requires removing the scanner and looking in the exit transport that way.
You may also have something stuck in that transport. Take the fuser back out and then take a minella folder and push it through from above the fuser to the output area and see if it disloges anything. If not, then you have to pull the scanner off and look in that exit transport area for problems.
Jun 26, 2010 | Xerox WorkCentre PE16 All-In-One Laser...
Unlock scanner
under the scanner where you retrieve you printed papers on the left side twords the front there is a slide lever (which is the lock for the scanner).
Apr 29, 2010 | Xerox WorkCenter PE120i All-In-One Laser...
My workcentre Pro 416 shows a jam, i have removed all jams that i could see. However it shows clear jam, and has 19 to dos on the screen, like open door, clean jam, close door, etc.. Is there a major reset...
On this 416 machine, there is one place you cannot see a jam.
Looking at the machine the right side doors need to be opened.
The lower trays feed paper and need to go up the by pass feeder area.
Just lower and behind the by-pass feeder the paper can get stuck, and you cannot see it.
If you try to push a card stock up from the bottom, the paper can be pushed out.
The other area is at the fuser. If the switch is worn it will not drop back into position. The tip of the switch wears and breaks off.
It is rare a sensor goes out on this machine, besides the fuser sensor. Each paper feed head needs to be checked to see if the paper sensors are bad.
Not seeing the machine, call Xerox for service repair if not resolved.
Jul 15, 2009 | Xerox WorkCentre Pro 416 All-In-One Laser...
Xerox WorkCentre Pro 215 E2 Error Code
Nov 19, 2008 | Xerox WorkCenter PE120i All-In-One Laser...
Can't print envelopes
Solution Title: How to print on COM10 envelops from the Bypass tray (PCL6) using a Windows 2000 O/S Resolution/
Solution
thumbsup.gif Fixed! thumbsdn.gif Did not fix. Resolution Role: Fix
Critical Message: The Envelope must be placed in the Bypass Tray face down (flap side up) and Long Edge IN. In Microsoft Word (Word 2000)
    1. Under the Tools tab, select Envelopes and Labels.
    2. Enter your Delivery and Return addresses.
    3. Click on Options
    4. Under Envelope Options; [Envelope size], select Size 10 (41/8 x 91/2 in)
    5. Under Printing Options, select Portrait (LEF) - Long Edge Feed
        • As Feed from, select Tray 5 (Bypass)
    6. Click <OK>
Within the WorkCentre Pro 123/128 print driver
After opening up the print driver [<Start>, <Settings>, <Printers>, double-click on the WCP 128 PCL6 driver], click on Printing Preferences under the General tab.
  • Under the Paper/Output tab
Set the following features as follow:
    • Job Type: Normal Print
    • Paper Size: COM10
    • Output Size: Same as Paper Size
    • Image orientation: Portrait
    • Image Rotation: OFF
    • 2 sided Print: 1 sided Print
    • Stapling: None
    • Output destination: Center Output Tray
    • Offset Stacking: None
  • Under Tray/Layout
  • Set Paper Source to Tray 5 (Bypass)
  • Click on Bypass Tray Settings
    • Paper Type: Heavyweight (1 or 2)
    • Feed orientation: Portrait
  • Click <OK>
  • " on Specify Paper Type and select Heavyweight (1 or 2)
  • " (Apply> and <OK>
  • " <OK> again
In Microsoft Word under Envelopes and Labels, Click <Print> to send the information to the printer.
Note: This setup represents one way of printing envelopes. Other ways setting up some features in a different manner will work as well.
Solution v1.3.20.0 312637.How to Print on COM10 Envelops From the Bypass Tray (PCL6) 2006-04-05 21:57:29
Nov 02, 2007 | Xerox WorkCentre PRO 128 Copier
Xerox WorkCenter PE120i All-In-One Laser Printer Logo
2,169 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
