Question about Brother GX-6750 Typewriter
I do not know how to load the correction tape...can you help me?
    Scholar:
  • 183 Answers
The easiest fix, is to take the machine to a repair shop that sells corr. tapes and ask them to install it. watch how it's done. look in the yellow pages. if you can't find a shop close, - - - first, take the ribbon off, then you put the supply side on the post on the left of the printhead. above the tape and right in front of the cardholder there is a guide for the tape that is black and has 2 fingers pointing to the left. turn the tape so that the part that is facing down as it comes off the spool is facing to the left, put he tape in the guide, between the two metal fingers and the card holder, then into the black guide on the right side and then put the take up spool on the post and turn to take up the slack. put the ribbon back on
Posted on Jan 06, 2009
  • 3 Answers
Is there a diagram showing how to put correction tape in?
Posted on Feb 18, 2009
VHS tape will not eject and unit shuts down
It's not loading correctly. You need to open the cover (unplug first) and get familiar with the loading mechanism. You can get the tape out by rotating the loading motor wheel.
Mar 22, 2015 | Magnavox ZV427MG9 DVD Recorder/ VCR
Tape will not load
Assuming that it's not damaged. The carriage might be out of it's correct position to load the tapes. You need to be certain that it is set up right and not damage. This might require a service manual.
Apr 19, 2013 | Panasonic AG-4700 VCR
Cannot get tape to eject
It could be a couple of different issues. These things could help.
(1) Power OFF the camera, remove battery then replace the battery, power up the cam and try to eject tape again. Nothing? try...
(2) Gently press inward on the tape cover with both thumbs a few times. Then, while pressing gently inward with one hand, press the release/eject-tape function until you hear a click or release sound. Then, if it doesn't open automatically, gently "help" open the hatch.
If it remains stuck, after follwing these steps a few times it would be my guess that perhaps the camera has been dropped in a way that jammed the mechanism controlling the eject function.
TIPS that may prevent having eject problems: When loading tape, be sure to insert the tape correctly and slowly, makeing sure the tape is placed properly. Gently press on the specific location indicated to close the tape holder, and wait for the tape to "seat" properly before closing any other part of the tape cover or hatch mechanism. Taking a few extra seconds when loading the tape can save extended frustration later.
May 16, 2011 | Samsung SC-D363 Mini DV Digital Camcorder
When I attempt to insert the mini tape into my Sony Handycam dcr-hc21 ntsc, it doesn't load the tape in all the way and an error message reads that it was loaded incorrectly and to please re-load...
Tape mechanism problems can be quite complicated but they can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Feb 20, 2011 | Sony Handycam DCR-HC21 Mini DV Digital...
Tape will not load; Error code 31:23
You may try the following troubleshooting steps:
Remove the battery of the Camcorder for one minute and re-insert the battery to check whether it works.
You may try resetting the Camcorder by pressing the RESET button located on it.
You may also check whether the issue occurs for all the tapes.
If the issue occurs with all the Tapes then it seems that internal parts of the Camcorder are malfunctioning.
Hence, the Camcorder requires service.
Jul 14, 2010 | Sony Handycam DCR-PC1000 Mini DV Digital...
Sony Cam DCR-PC100, "eats" tapes and when ejecting, pulls tape
The take up spool is not working upon ejecting. I would take it to a Sony Service Centre for service.
Jun 03, 2017 | Sony Handycam CCD-TRV43 Camcorder
Tape hanging up and will not record.
There is a threading arm that has gummed up inside the unit. I suspect that the tape is not being loaded correctly. This is a common problem with the Sony units and requires the removal of that loading arm to remove gummed up grease. Once that is completed, the unit will function correctly. Please note that the height of this swing arm is critical to the correct loading of the tape. I would not suggest you attempt this repair because the tape height adjustment needs to be exact. A local shop should be able to resolve this for you with NO parts required.
Dan
Mar 11, 2009 | Sony SLV-N750 VHS/S-VHS playback VCR
Installing correction tape
This tape comrs in two small cassettes the full one loads on the L. side of the printer the tape goes across lower than the ribbon and wraps on the R. cassette.
DickyO
Aug 28, 2008 | Office Equipment & Supplies
Tape ejects immdediately when I load tape.
I own a Sharp VL-Z1 DV video camera. I had this same problem and thought it was from using the ME Maxell tapes. I took the battery out of the unit and let it reset. Worked fine after that.
May 05, 2008 | Canon ZR85 Mini DV Digital Camcorder
How can I remove a stuck video tape from out of a VCR?
You will have to take the cover off. ( un-plug the AC cord)
Look for the loading motor at the back right side.
Rotate the motor and you will see the tray moving thru its cycle to un-load the tape, it does take quite a few turns, its slow.
Let me know if you run into a problem?
Apr 08, 2008 | Panasonic PV-V4523S VHS VCR
Brother GX-6750 Typewriter Logo
91 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
