Question about Marley Electric Hydronic Baseboard Heater, 58" 240V/1250 Watts
That were immersed in water from the recent Sandy storm now they din't work. can you tell me how to troubleshoot this problem, thank you, Patrick Taylor, valley 35@aol.com
  • Marley Master
  • 2,458 Answers
If they have been immersed in water then I would say that they are beyound repair now
Posted on Nov 10, 2012
3 Suggested Answers
doughigel
SOURCE: Marley B2451 wall heater
These are only 1500 watt heaters.
They 'could' heat a 20 x 20 foot room (with good, tight construction), with a slow temperture rise.
Check the company web site at http://www.qmarkmeh.com/
Doug
Posted on Feb 17, 2009
  • 192 Answers
SOURCE: Help with wiring. the thermostate
I think what you have is a 220 volt thermostat. That is why it isn`t making sense to you.
Posted on Feb 15, 2011
How do I freeze broccoli
preparing broccoli to freeze.
1. remove leaves & woody portions.
2. separate heads into sections & immerse in brine for 30 minutes(4 teaspoons salt + 1 gallon water) to remove insects. remove & rinse.
3.split lengthwise to no more than 1 1/2 inches across.
4. water blanch 3 minutes or steam blanch for 5 minutes. start counting as soon as you place broccoli in boiling water.
5. immediately immerse in cold or ice water to stop cooking action.
6. drain & package leaving no head space ( the less air the better, will keep longer with out freezer burn), seal & freeze.
two ways to freeze -
1. place in bags( I use quart size fro this method) remove as much air as possible & seal.
2. place broccoli on flat sheets in freezer 1-2 hours to freeze, then remove & place in bags( I use gallon size for this method, size & style of storage unite is choice of preference). with this method one can use as little or as much as needed for what you need. I use this method for my peppers & peas as well.
Sep 28, 2014 | Home
How can I fix a Sound Storm Laboratories DD405 in dash double din that the volume goes up and down by itself when I hit bumps in the road and the volume wheel seldom works
It sounds like the volume control itself has failed and needs replacement. Sometimes it is just a broken connection where it connectects to the circuit board.
Jun 16, 2014 | Ssl DD405 In-Dash Double-DIN Multi-Media...
TRAX single channel hot water 7 day 14 settings programmer instructions missing
1) Thank you for description:
Copy following links to identify possible match for TRAX timer, and download manual:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#TRAX
http://waterheatertimer.org/GE-timers-and-manuals.html#DIGI
2) Add comment March 2013 and say how closely this information matches your timer. Attach image.
Mar 10, 2013 | Hardware & Accessories
Need Owner 's manual
To the best of my knowledge these things only come with a general leaflet telling you not to immerse them in water and so forth.
It's a floppy disk drive. It should just work.
Feb 06, 2013 | SmartDisk Fdusb-b2 Usb External Floppy...
I have a Fisher stereo.The amp is a ca871 the eq is a ca871 the casset deck is a crw870. How do I connect these components up.
The amp has tape rc out and pb. The eq has line in, line out, tape rec out, tape pb. The casset deck has line in,line out.
Ok, hook the amps RC OUT to the eq's LINE IN.
amps RC Pb to the eq's LINE OUT.
The tape's LINE OUT to the eqs TAPE PB
the tapes LINE IN to the EQs TAPE REC OUT.
on the eq, there should be a button to toggle between tape and source.
let me know if that works.
Jul 01, 2011 | Audio Players & Recorders
Hello- My 332c will not show speed. It worked before.The spinner wheel is not damaged.Speed just flashes 0.00 mph Thanks, Jeff
Try setting up the speed in the overlay data menu again:
1. Press MENU, arrow down to OVERLAY DATA and press ENT
2. Highlight the option for speed (WATER SPEED or GROUND SPEED) and press ENT
3. Highlight the REMOVE button and press ENT
4. Highlight (PRESS ENT TO ADD) and press ENT
5. Arrow down to SONAR DATA and press ENT
6. Arrow down to WATER SPEED and press ENT, a check will be displayed in the box
7. Press EXIT twice
If the speed is still flashing, the data is still invalid. Try resetting the unit completely:
1. Turn unit off
2. Press and hold the PAGES and POWER key until the "DO NOT RELY..." alarm appears
3. Set up the overlay data for speed again: 1. Press MENU, arrow down to OVERLAY DATA and press ENT; 2. Highlight (PRESS ENT TO ADD) and press ENT; 3. Arrow down to SONAR DATA and press ENT; 4. Arrow down to WATER SPEED and press ENT, a check will be displayed in the box; 5. Press EXIT twice
If the speed is still flashing, good chance the speed sensor is bad even though the wheel still spins. Install the latest LMS-332 updates from http://www.lowrance.com/en/Products/Marine/Full-Size-SonarGPS-Chartplotter-Combos/LMS-332C/Downloads/LMS-332C-Software-Update/ and set up the overlay data again.
If it turns out that the speed sensor is bad, just use speed from the GPS. This can be set up from the overlay data menu as GROUND SPEED.
(note: the overlay data must be set up for each page individually. So if you set up speed to be displayed on the map screen, it will not also be set up on the sonar page)
Jul 12, 2009 | Lowrance LMS-332C GPS Receiver
Replacing a Blaupunkt Reno with Florida
Hiii...
This is a PIC mybe can be help you...
Thank's
Jan 27, 2008 | Blaupunkt PA4100 Car Audio Amplifier
Marley Electric Hydronic Baseboard Heater, 58" 240V/1250 Watts Logo
32 people viewed this question
Top Marley Heating & Cooling Experts
paulcarew
Ron Durham
Are you a Marley Heating and Cooling Expert? Answer questions, earn points and help others
