Question about Akai Televison & Video
Akai pdp500611 will not turn on.
I replaced 4 capacitors on main board and 5 capacitors on other board.
  • 8 Answers
SOURCE: Akai LCT 328STA,Comes on Akai screen appears then goes off.
Akai LCT 3285TA (notice the "FIVE") uses the MLT169A Power supply. This is available from shopjimmy.com for about $100.
Posted on Sep 08, 2009
  • 50 Answers
SOURCE: Black screen on Zenith plasma tv's
Hello, My name is Dave and I can help you fix your Plasma TV. Give me a call. Feel free to give me a call @ 1-503-432-9904 or message me at pleasefixitdave@yahoo.com
Thank you!
Dave,
Posted on Jan 29, 2009
  • 3 Answers
SOURCE: Akai LCT42Z6TM still broken after replacing caps
You still need to replace C301. I can fix your mainboard if you need help.
Tom
Tommy@ruden1.com
Posted on Mar 21, 2009
eagle338
  • 4889 Answers
SOURCE: Insignia ns-pdp50hd-09 plasma hdtv will
Yes it is definitely a power supply board issue. The self-diagnostic error codes of the LEDs are self descriptive. The logic board led blinks when an OVP(OVer VOltage Protection) is detected and the LED then blinks on the source of the problem(power board). My money would be on failed voltage regulator ICs and/or blown resistors. If you are not good at component level repair, then it might be good idea to just replace the board.
Posted on Nov 16, 2010
  • 1274 Answers
SOURCE: Insignia ns-pdp50hd-09 plasma hdtv will not power
Hi red, My name is John. Welcome to FixYa. Go back and check your plugin connections. Make sure that they are making a good connection, some can be hard to make contact.....John
Posted on Dec 11, 2010
My flat panel tv has sound but no picture, its a Akai model pdp42z5ta. I replace the invertor board but its still the same, all 5 fuses and are good, at 1.0 ohms. What should I do now.
Hi, Check main power board for bad Caps. Replace caps with same rated or better caps.(Capacitors). Look for bulged or leaking caps. Good luck
Nov 21, 2016 | Akai Televison & Video
I have a 50" Akai TV - that will not turn on
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Jun 18, 2012 | Akai Televison & Video
I have an Akai tv, model KC09-b2. The tv shuts itself off after 4-5 minutes of it being on but only when i am watching tv through a digital box (motorla DCT6416 III). the sleep function is set to off.
While this suggests a power supply problem with the tv, the digital cable box should really have no bearing on the shutdown. The cable box only sends audio and video signals at an extremely low voltage to the main board. The issue is with the power supply. You might want to take the back of the tv off and see if there are any puffed up capacitors on the power supply pcb. This is the board where the power cord plugs into. If they are puffed, replace the capacitors with an equal or slightly higher value. The values are in mfd and voltage which are printed on the capacitors themselves. Keep me informed. Thank you
Apr 03, 2011 | Akai Televison & Video
How shrink picture size in AKAI 14" portable TV
Less power output from the internal SMPS; usually 110v, may less. Horizontal output capacitor may leaky. Horizontal output transistor fault may occur. In rare cases deflection yoke assembley fault.
If the picture is stamped size; suspect the power supply. If the picture is less in width, suspect the above said capacitor, and the lenearity coil fitted on the main board.
Oct 13, 2010 | Akai LCT0510 5 in. Portable TV
My akai dlp tv turns itself off then it flashes
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Feb 17, 2010 | Akai LCT3201TD 32 in. LCD Television
My samsung 46 LCD TV takes 5 - 6 tims to start?
Power supply board have dead capacitors.Know how to solders?Check these capacitors for puff up or burst open replaced these capacitors.Or buy and replaced the whole power supply board at Shopjimmy.com,Ebay.com.
Jan 27, 2010 | Akai LCT3201TD 32 in. LCD Television
Akai LCT42Z6TM Problems. Help?
I'm working on one now. So far, I've found two capacitors on the power supply board bad, both 1000uf/16V 105 degree caps location EC9 area. Still have mild interference on the screen which seems to change with the type of video being displayed.. Will look for C301 next, is it on the signal board?
Jan 08, 2010 | Akai LCT42Z6TA 42 in. LCD Television
Akai flat screen lcd tv.. turns itself off after about 10 min
had a very similar situation with my Phillips 42 in. LCD TV.
Here was my Problem. The Power Supply Board. I opened it up( Warranty was Expired) and found several faulty capacitors on the PSB. Its pretty common. Major Electronic companies were sold faulty capacitors that fail in 2-5 years instead of 10-20 due to a lack of preservatives. It wouldn't surprise me if you have the same problem. TV will work fine for a few years and then just fail completely or slowly deteriorate.
Here are the solutions
1. Have it Repaired
2. Check for faulty caps and if you find some(budged or leaking) you know you have located a problem
Remove the board and replace the whole thing.
3. If you have some soldering skills you can replace the faulty caps.
Caps are very inexpensive, under a dollar in most cases. I replaced 4 for about $5.00
Hope this Helps.
Good Luck
Jun 06, 2009 | Akai LCT2715 27 in. LCD Television
Akai 42" LCD TV - Bad Picture
there is a weakness in the power, this could be power board or the main av board. the capacitors would be the main problem as they control the voltage around the power board and also on the av board. you maybe able to see the problem if the capacitors caps have rounded at the top, but on the av board this is harder to notice as they dont go rounded at the top they need checking with a meter to see if the voltage is right coming out onto the board. these are called smd capacitors and are soldered to the top of the board and a lot smaller than normal capacitors. a visual look at the power board would be needed to see if there is a problem
Jun 29, 2017 | Televison & Video
Televison & Video Logo
32 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Radames Pagan
Radames Pagan
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
