Question about ASUS K52F Notebook
New charger makes cursor jittery during use.
I had to replace the charger for my laptop. For some reason while using the touchpad in AC Mode now causes the cursor to become jittery and extremely inaccurate. I've read that a BIOS update fixes the problem but I cannot find any update for it, and no information on a driver update either.
  • ASUS Master
  • 7,627 Answers
Try the sensitivity adjustment on your touchpad. I have never heard of a AC cord replacement doing that, will, you live and you learn, I suppose.
Posted on Nov 18, 2012
  • 12 more comments
  • Vinnie Ferraro Nov 20, 2012
    I read a little bit about it from what i could find, and saw that bios could need to be updated to fix the issue. It just doesn't make sense to me that the touchpad is 100% fine while not plugged in. During charging it works here and there but while fully charged it's constantly jittering around when I'm trying to do something. This is my 3rd charger, and it started happening as soon as i started using this one.. I know it's odd and I've never seen it before either but I don't see what else it could be, I've tried all of the other solutions offered here
  • max carson
    max carson Nov 20, 2012
    As i'm sure you know the BIOS is like a minefield, one wrong step and........well you know. Have you searched the ASUS website for this issue, do they suggest a BIOS update? 3rd Charger? If you feel comfortable, and you get the BIOS update from ASUS website, usually computer manufacturers will put out updates/patches for issues like yours,It may be your answer. My advise is to only use ASUS WEBSITE BIOS Updates. Check and double check, and re-check the check before flashing the BIOS. As you know, it's almost impossible to put the toothpaste back in the tube!
  • Vinnie Ferraro Nov 21, 2012
    Yeah I've heard BIOS can be rough if you aren't sure what you're doing. I did a little bit of research and didn't find any type of update involving the problem I'm having, which is why I didn't go straight for the BIOS update. Probably less risky to spend the little bit on a new charger, specifically for my laptop rather than the "universal" one I have now that fits multiple laptops... maybe It's sending too much or too little power or whatnot, just doesn't make sense that it would work to charge it without some kind of error and having only the touchpad being a problem.. Don't understand what else it could be while it works fine without the charger and while I was using the old charger.
  • max carson
    max carson Nov 21, 2012
    Do you have multimeter to verify DC voltage output is correct at the plug in for laptop? Usually the universals have a switch you can change DC voltage output. I have a backup ac cord/charger like that. You said this is your 3rd. charger? Seems like a lot, AC issue or damaged? I have been working with computers a long time. There is an old saying, "Stranger things have happened". Have you looked or asked about this issue on a ASUS forum or help site? I would suspect someone somewhere has come across this issue. I haven't, sorry I can't help, but when you resolve the issue, I would be interested in the outcome.
    I think I may have one around somewhere, but I don't see a switch to change the DC output. Yes 3rd charger.. First one had the wire pull out of the stem on me, was old and moved it around more recklessly than not most of the time, and second one was eaten by a dog. I haven't checked into any ASUS forums as of now, as I came across this site while looking for a solution, and figured I'd give posting it a shot. Odd enough thing to have happen I'll admit though, I've never had or seen this type of problem before either, which makes it that much harder to fix!
  • max carson
    Dog ate my cord? That's a good one! As you know ,everything points to the Cord/charger I'm sure you matched the DC output of cord/charger to the input of the laptop. So ,the question is are the specs on the cord/charger correct? Did you purchase the cord/charger from a computer store?
    Haha typical excuse! Yeah, input on laptop is +19V -- 3.42A, 65W, whereas charger's output is 19V --- 3.42A/4.74A
    It's an ASUS K52F laptop, and the charger is model: 90W-ACI010, in case you were interested. I bought the charger online, rather cheap actually. Surprisingly cheap, which I guess is the "Surprise! Your mousepad won't work!"
  • max carson
    Yeah, I have learned, the hard way, "they are cheap for a reason". Laptop batteries for example. Without verifing the actual output voltage, you can't eliminate that possibility. Troubleshooting 101. Eliminate all the possibilities, and what ever is left.....
  • max carson
    I fried my universal on a laptop I was trying to repair that had some serious power issues, $50.00 up in smoke! Did you know electronics work on blue smoke? release the blue smoke and......
    Yeah.. Only way to really get the right one is to buy directly from the manufacturer of that brand laptop usually. Think i found this one for $20 or so? Maybe even less! At first I thought "what a great deal!" guess i deserved that one! Think after christmas I'll just have to buy another one and junk this one, as I get rather irritated when the laptop is dying and I'm still using it with the mouse bouncing around a little on me. Sucks when you're trying to click something like the address bar and you're clicking something on the menu bar instead! I'm about to post on the ASUS forums and try to find a solution, although I don't actually see a section in the forums relating to this type of issue.
  • max carson
    max carson Nov 22, 2012
    Are you using a USB Mouse? Or is the issue with the Touchpad? Have you tried a USB mouse? say a Logitech, mine is a http://www.amazon.com/gp/product/B003HC2... I know it doesn't solve your problem, but it would be another way to isolate the problem. Personally I dislike using a touchpad, I find it a pain, but that's just me.
  • Vinnie Ferraro Nov 23, 2012
    I haven't tried using a USB mouse, but there's one in house I'll have to give that a shot. I normally like using a mouse as well but most of the time I'm on the laptop I'm in bed and it's easier to just use the touchpad. I can't find anything about this anywhere, and was hoping someone would have heard something about it on here. Think the plan of attack is going to be buying a new charger, and if the problem continues I'll just return that one, and look further into this, but if it works I'll touch base, cause I don't see what other way to fix this at the moment! Thanks for your help with it though!
  • max carson
    max carson Nov 23, 2012
    Do let me know how it turns out, hope I was of some assistance.
4 Suggested Answers
  • 13 Answers
SOURCE: When using touchpad, cursor jumps all over the
sounds like the touch pad is playing up, plug in a usb mouse, and if that works, then it is the touch pad itself
Posted on Sep 12, 2010
jonags3
  • 83 Answers
SOURCE: Laptop display only works when video driver disabled
Hi! Your Video Card can be replaced, You just need to check it in the BIOS setup if your video card is still working. Try installing a new driver just download from Nvidia website. Maybe your driver for the said video card was corrupted.
need more help just email me jonags3@mail.com
Posted on May 07, 2012
  • 6771 Answers
SOURCE: disable asus laptop touchpad
Thank you Camie, hope we can be of service in the future.
Posted on Jun 09, 2012
I have problem with my touchpad cursore fricking if I touch my touchpad
try on battery.maybe the charger is the problem. the capacitors inside the charger or the filtering is whit problem. u may need a new charger--->>>if on battery runs well<<<---
Oct 11, 2014 | Acer Aspire Computers & Internet
Charger causing cursor jump
AnswerMake sure you're not touching the touchpad
Because the touchpad often is close to where the palms of your hands and thumbs lay, it's possible that you may be touching the touchpad without realizing it. An easy way of determining this is to see if the cursor moves without touching anything on the keyboard.
Dirty touchpad
Oils, lotion, and other substances from your fingers can cause the touchpad to not work properly. Make sure the touchpad is clean by dampening a cotton cloth with water and rubbing the touchpad surface.
Disconnect other external input devices
It may not be touchpad that's causing your issue. If you have other input devices such as an externalmouse, graphics tablet, keypad, etc., try disconnecting these devices to make sure they're not the cause of your issue.
Disconnect from docking station
If your laptop is only encountering this issue while connected to a docking station, it could be the cause of your issues. For this issue we suggest the below solutions.
Update drivers
Because the drivers control how the touchpad interfaces with the operating system, if the drivers contain issues, any number of problems can occur. Including the cursor moving improperly. Make sure you have the latest drivers from your laptop manufacturer for your touchpad either by visiting their website or contacting their support.
Try a third-party utility
Download and install Touchpad Blocker, a fantastic free program that can be used to help prevent any mistaken touchpad movements.
Bad hardware
If you've completed all the above steps and continue to have issues with your touchpad, it's possible you may have a physical hardware issue either with the touchpad or interface connected to the touchpad.
If your laptop is out of warranty and you do not wish to spend the money it takes to repair the laptop, we suggest disabling the touchpad and using an external USB mouse. Many touchpads can be disabled by pressing a button above or around the touchpad.
Additional information
Sep 10, 2013 | Computers & Internet
Dell Inspiron N5040 touchpad not working while charging
If battery works and ac adapter has problems that means electrolytic capacitors maybe dried up(not supplying the current needed to run the laptop) and has to be cured by using the laptop more often.
Apr 13, 2012 | Dell Inspiron Computers & Internet
Cursor in the mid-screen and does not move
Does this behavior repeat in safe mode? If so, the issue is the touchpad assembly in your laptop. If it does not- the issue is with the driver for your touchpad. In order to boot to safe mode, when you see the bios splash, start tapping F8. Select safe mode or safe mode w/ networking. The reason is that in safe mode, windows uses the default driver for a mouse. If the behavior repeats in safe mode- you've eliminated the driver as the source of the problem.
Oct 03, 2010 | Acer Aspire 1200XV (LX.A0105.011) PC...
Jumpy cursor , while typing the cursor jumps to another line and adds the newly typed letters somewhere else on the page
The reason this is happening is that as you are typing; you're resting some weight on the thin plastic above the touchpad...which then makes contact and registers a 'click'; thus moving your cursor around. Or you're brushing your thumb against it when hitting the space key.
Some laptops are more susceptible to this than others. Some more modern laptops come with a button to turn the touchpad off to solve this very problem.
The only thing you can do about this is to disable the touchpad through the touchpad driver (down by the clock, usually) and use a mouse instead. Depending on how you use your laptop, this will be more or less inconvenient- if your laptop never leaves the desk; disable the touchpad and use a mouse...no problem. If you go mobile a lot, you'll have to enable and disable the touchpad all the time.
The other thing you can do is adapt your typing style so you don't put any weight on anything but the key you're pressing. This is quite difficult and uncomfortable, and is not recommended for long sessions.
Mar 22, 2010 | Acer TravelMate 2303LCi Notebook
Touch pad isstP Pavilion cursor starts drifting uncontrollably
try removing your battery and replace it back. its like resetting it.
May 16, 2009 | HP Pavilion dv4000 Notebook
Erratic Touchpad on Toshiba M50 Notebook
if the touchpad is working fine with the battery and if it is not working with the ac adaptor then in this case u can try with the different ac adaptor and still if it does the same thing then uninstall and resintall the toouchpad driver and restart the computer and still if it does so with the ac adaptor then u need to open the laptop chasis and then u need to fix up the power supply connector in the motherboard where the power supply from the ac adaptor is not getting the adequate response from motherboard.
Dec 21, 2008 | Toshiba Satellite M50 Notebook
Replacement AC Adapter causes touchpad problems
OK here is the problem your laptop use a certain amount of power to is parts to operate too much power from the adapter causes glitches where as the mouse pad would freak and stuff or certain keys not functioning so you have to look at the old acer adapter u have and make sure it has the same amount of MA = mili ampage to the universal one your thinking of purchasing also the same amount of imput and output voltage and if not too certain carry your laptop to the store and try the one that they have
Sep 11, 2008 | Acer Aspire 5100 Notebook
Replaccement AC adapter charger issue
If you used electrical tape and firmly wrap the tape around, your cable should be secure enough to continue use. Just be careful around your dog.
I hope this helps address your problem.
Sep 11, 2008 | Acer Aspire 5100-5022 Notebook
Cursor jumps all over the screen
Try uninstalling and reinstalling the touchpad driver from device manager
Dec 03, 2007 | Logitech Wireless Access Duo Optical...
ASUS K52F Notebook Logo
241 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
