Aircon split system not responding to remote, switches on and off only manually.works good but without remote
SOURCE: MANUAL OPERATION OF SPLIT SYSTEM AIRCONDITIONER
In every model there different location of manual button. Some manual button are located in front of the indoor and some are at the back of the front grille near the control board.
SOURCE: Westpoint split air conditoner remote contol unit
I want to locate a Eolia West Point A/C remote
SOURCE: samsung aircon cuts off. lights green/yellow flashing
lg air cond.multi split led lamp blink power 1 times,good sleep 2 times
SOURCE: Need Remote Control for Lennox A/C
Try Heatcraft as they deal with lennox a/c units. Go to their web site is www.heatcraft.com.au and you will be able to find your nearest store.
SOURCE: LG Ductless Mini Split System LAN125hv: Heat pump doesn't run.
First check your circuit breaker or fuse that supplies power to the outside unit. It's probably separate from the inside unit. Then try to turn unit on. If the fan and compressor just make a humming sound then turn it off and check the capacitor if you have a multimeter. You can also look at it and see if the top looks expanded. That's a good sign its bad, but not all bad one's look expanded. Tomorrow I will have access to an LG service manual and can let you know what the code means. Sorry I can't get it sooner. Let me know what you find.
