Question about Electrical Supplies
Pull rope repacing on honda em 350 generator
Replacing broken pull rope
  • 1388 Answers
SOURCE: honda generator em 1800
Honda generators are very reliable and are easy to adjust. The best way to check for proper output is to use a meter that can check cycles and voltage. Set meter to htz or freq and adjust the engine governor to 60 cycles. When the engine is turning 3600 rpm it is at max power and the generator may be producing ac voltage ranging from 115 to 125 at 60 cycles. When you draw power from the generator the engine governor will try to overcome the stress and maintain 3600 rpm. The engine must be well maintained to produce full power. Service oil, filter, plug and valve adjustment. Some engines have a spark arrester installed in the muffler that may become blocked with carbon. If engine is producing full power and voltage/amps is low then check brushes, capacitors, and/ or voltage regulator. Most problems occur when too much power is requested from rated generator. Example, trying to connect an 1800 watt air compressor to generator. The compressor may draw double the stated wattage upon starting and cycling. For longest generator life, It is best to use only 75% of rated output. On an 1800 watt generator use max wattage 1350. If you actually need to use 1800 watts then the best generator would be a 2500 watt. enjoy
Posted on Nov 30, 2008
CarlGehrke
  • 169 Answers
SOURCE: Honda EM 2500 Generator
I posted a general tutorial on troubleshooting this problem here.
Rate me?
Carl
Posted on Dec 05, 2008
  • 154 Answers
SOURCE: Honda EM 2500. What oil does it require and does
30 weight
Posted on Jun 14, 2009
SOURCE: i need to replace a broken pull cord on my
just remove pull cords housing the rope is right ther.
Posted on Jun 15, 2009
jan mczeal
  • 632 Answers
SOURCE: generator starts but does not generate power
  1. Check for any blown fuse and replace. It can be traced directly from the output lines.
  2. Check field excitation. The field excitation is supplied by the battery to the excitation coil through a pair of carbon brushes. If the brushes are worn out, no excitation field is supplied and no output is generated. Replace carbon brush if found worn-out.
  3. Use an analog multitester to check the continuity of the carbon brush and the field coil.
Posted on Sep 25, 2009
How to change recoil rope
How To Replace The Starter Rope On Your Recoil ...
? 4:47
www.youtube.com/watch?v=Q3NjVomUQJM
Feb 25, 2009 - Uploaded by craig1974 Me showing you how to replace your starter rope on your recoilassemblies.
Sep 11, 2015 | Honda EU6500iS Inverter Generator
Dewalt gasoline generator ..rope does not pull
Try taking the spark plug out and see if you can turn it over.
Feb 16, 2015 | Dewalt Generator. 6000 Watt Portable...
How do i replace the starter rope on my 3000
Remove the rope housing, wrap the new rope on by hand, replace the housing.
Jan 11, 2013 | Honda 3000 Watt Portable Generator
The start pull handle is out , how to fix it
The pull start cover rope & spring will need to be removed. it may be bolted on or riveted on if rivets drill them out when off you'll see the problem spring dislodged or broken rope broke repair & reassemble. watch as spring is tricky to wind up..
Apr 08, 2011 | Champion 2.4 HP Gasoline Generator
I have a honda generator but i change the cordon starter and now i dont now how ensable it, i need a diagrama of this
What you need to do is first remove the new cord that you installed.
(This next process is best performed by 2 people)
Pre-wind the spool gently COUNTER CLOCKWISE until the spring prevents further winding. Have the 2nd person grip the spool so that it does ot unwind. Back off the spool until the re-wind rope hole is aligned with the outer cover rope guide. Insert the new rope through the outer cover rope guide hole and into the spool hole. Pull the new rope through the spool hole and tie a single small knot. Pull the knot into the hole. 2nd person releases the spool and the rope will rewind into the re-coil assy.
Aug 04, 2010 | Honda 3000 Watt Portable Generator
Generator Armature Removal Honda EMS 4500
Sorry, I don;t have a solution but do you have a good coil from one of those you would like to sell?
Nov 27, 2008 | Kitchen Appliances - Others
Electrical Supplies Logo
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
