Question about Toshiba 32HL83 32 in. LCD HDTV
Power comes in and out, now no picture green light goes on and off
I think the PSU is kaput. The tv does does not power on anymore
  • Taz Taz
    Taz Taz Jun 12, 2007
    well i still need help here people!@!
  • Anonymous Apr 25, 2008
    Same...used to be able to unplug unit for a few minutes and plug it back in and the TV would turn on again. Now it does not turn on at all.
  • 67 Answers
If the set isnt doing anything then yes probably the power board theres not many boards in a lcd set
Posted on Jul 05, 2007
Compaq FS7600 Computer not turning on
what tower? model, the monitor has nothing to do with power and dead fans in the tower.
'Sounds, (and silent to) means the PLUS in the PC is dead.
all things can be repaired, that is what technicians do.
here is the chain of events, ! to get noise (fans)
power in the wall 120vac , usa
power to the PSU,
the power button goes to the MOBO, and standby power is there
now and pushing said button the MOBO commands the PSU on
if the PSU is happy (PWROK) thinks PSU IS safe the PSU tells the PC its ok, and power stays up.
and fans run.
so my guess bad PSU, its easy to test with anyf $10 voltmeter,
ask.
tower PSU, 101
http://pcdied.com/power.html
May 21, 2017 | HP Compaq FS7600 17" CRT Monitor
BUSH 42" plasma no picture or sound?
You have a power supply problem, replace the Module.
What you ear is a click relay No juice to activate the relay
Some cups may be dried.
Nov 01, 2012 | Bush Furniture Bush My Space Rhea 42 in....
Is it a Fuse or the Power Supply
It's not the fuse. Chances could be your PSU
Oct 13, 2017 | Akai LCT3201AD 32 in. LCD Television
I have a RCA L32WD22. When I push power on, the green light comes on then goes amber and the TV shuts off. Takes about 4 seconds and never get a picture.
I would resolder the inverter chips about five of those on the inverter board first. If that doesn't fix it, try the Power Supply unit (PSU), order this capacitors http://www.ebay.com/itm/Repair-Kit-RCA-L32WD22-LCD-TV-Capacitors-/230637983468?pt=LH_DefaultDomain_0&hash=item35b31856ec
or better if you can get a new PSU altogether, but doubt you can find one right now.
Oct 27, 2011 | RCA L32WD22 32 in. LCD HDTV
I am currently working on a Sharp Lc37sb24u. I was originally thinking it had a bad inverter board but now I am not so sure. When I turn the tv on the picture comes up with audio for about 2 seconds the...
Did you check the service manual troubleshooting guide yet. You can try disconnecting the power to the inverter board and see if it will stay on and have sound.
Service manuals:
http://elektrotanya.com/?q=showresult&what=Sharp%20LC37SB24U&kategoria=&kat2=all
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Oct 27, 2011 | Sharp LC37SB24U 37 in. LCD TV
When i turn my tv on the red light goes to flashing green it comes on then immediatly it goes off but the light is on green... can you help
Tries tv unplug,replug it back about an hour later.The tv,now should reset itself back to factory setting.The tv should work now,not than the power supply board is dying,not giving the right voltage to the rest of the tv anymore.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Sep 10, 2010 | LG 42LG30 42 in. LCD HDTV
No Picture, Indicator Light Green
If your TV is a year old or more, chances are that the power supply is starting to fail on your TV, causing all kinds of erratic behavior up to the point of not turning on anymore.
I service these power supplies since it does not look like there are many service parts available anymore. The only way to get this TV functional again is to repair the power supply to the component level.
May 11, 2008 | Protron PLTV-32 Television
NO PICTURE
Bad power supply. The light is green when it is not plugged into the monitor because there is no load on the power supply. When you plug it in the monitor tries to draw current, nothing the PSU can handle now, so the light blinks. The PSU can not provide the amps that the monitor needs.
Get a new power supply, you can find them on ebay. Just make sure the voltage and amps match. It is ok to buy a power supply with a higher amp rating, the monitor will only take what it needs. Also make sure the power plug that plugs into your monitor matches.
Nov 16, 2007 | Neovo SX-19A (Black) 19" LCD Monitor
Sanyo vizon dp42746 problem
Anyone have a suggestion for this? This thing is a year old and is kaput.... anything????
Oct 01, 2007 | Televison & Video
Toshiba 32HL83 32 in. LCD HDTV Logo
83 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
