Question about Kitchen Ranges
Whirlpool oven shuts off - Error Code F2
The oven will shut off when in use. It never reaches desired temperature. Occasionally Error code F2 (only two digits) comes up with constant beeping. Sometimes, rarely the code will be F3. Error code lists say F2 means oven temperature is too high. Not the problem, as it doesn't reach proper temperature. Both codes say Oven Sensor needs replaced. I have replaced it, twice. The problems persists. All sensors, including original one, read correct OHMS. What do I look at nexr?
    Top Expert:
  • Kitchen Ranges Master
  • 9,472 Answers
The "F2" error code for this oven means "one or more keys on the keypad are shorted". The correction is to replace the control panel because keypad does not come separate.
The part is not available but if you call the number of that supplier I'm sure they may find the part for you.
Here is the info.
Posted on Nov 10, 2012
  • Bill Center Nov 10, 2012
    Thanks for the response. Is there a way to check the control board? Especially some instructions I can follow. I hate to pay $250 to $300 on a hunch.
  • Richard Roth
    Richard Roth Nov 10, 2012
    I under stand that. There is nothing else it could be but the control board. I don't have any test information since the service centers use a proprietary diagnostic machine. You can order the part and if you feel it doesn't correct the problem the part has a 365 day, any reason any part return policy so you can't go wrong either way. Keep me posted! I am always here.
4 Suggested Answers
nucklebuster
SOURCE: error codes F2 and F3
Two months ago I asked fixya about a g.e. oven with a f3 code. that evening a reply suggested I replace the oven sensor. I took the old one to the parts place, told the repairman about the code,and he told me the sensor WAS the problem. I replaced it, and WOW it fixed it! Today it faulted out again. I will pull it again and check it. It was installed correctly.The problem for a f3 fault IS the sensor.
Posted on Jul 29, 2007
localwonder
  • 6784 Answers
SOURCE: f3 code
HI, You will need to check the oven sensor wires that link the actual sensor to the main control board. Make sure that the contacts are connected properly, and not loose, or corroded. If all the wiring checks out, test the sensor for the correct resistance readings.(you will need a multimeter for this test)
The most common oven sensor should be approximately, 1100 ohms when at room temperature. The others may be close to as follows:
100°F - 1143 ohms
200°F - 1350 ohms
300°F - 1553 ohms
350°F - 1654 ohms
400°F - 1753 ohms
500°F - 1949 ohms
If the sensor test is adequate, and the wiring is Ok at the control, this will lead to a failed control board. replace the control in this case.
Posted on Dec 06, 2009
rylee_smith
  • 8619 Answers
SOURCE: f3 error (sensor replaced) kenmore stove Oven
Hi
Thanks for using FixYa. Error F3 in your range/oven means oven temperature sensor circuit failure. To resolve this issue you'll have to check the oven temp. sensor circuit if the reading is more then 1100ohms then check the wire harness connecting the control & sensor (as you have already replaced the sensor) however, if the rating is fine then it is the Electronic Range Control (ERC) that has gone bad & should be replaced. Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks Rylee
Posted on Oct 07, 2010
91136669891 HAS ERROR CODE F2 F3
Are you sure about this error? The 91136669891 was made by Whirlpool for the Kenmore line. The 4 character codes for these ranges are F# E# (not two Fs).
Depending on which error you are actually have see below.
If the code includes F3 then you have a problem with the oven temperature sensor (F3 E2 would be temperature too high). You need to replace the sensor. Sears Parts Direct has the sensor for $74.12: http://www.searspartsdirect.com/partsdirect/part-number/Kenmore-Parts/Range-Parts/WB21X5301/0022/364/Model-91136669891/0582/0124250?keySuffixId=NA&pathTaken=partSearch&pathRender=modelComponent&documentCompId=P9040087&diagramPageId=00005&productTypeId=x&searchModelNumber=91136669891&subCompDesc=Body&brandDesc=KENMORE&modelDesc=30 . The complete diagram of the oven parts is available here: http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Range-Parts/Model-91136669891/0582/0124250/P9040087/00005?blt=06&prst=&shdMod= . The sensor is part 253.
If the code includes F2, then double check the second code. Whirlpool has no F2 E3 error that I know of. However, F2 errors tend to be a problem with the keypad. Check the wiring connection between the keypad and the control. This should be firm. Then press Cancel. If the error persists, you need to replace the keypad. See http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Range-Parts/Model-91136669891/0582/0124250/P9040087/00001?blt=06&prst=&shdMod= for the parts diagram and prices.
I hope this helps.
Nov 23, 2011 | Kenmore Kitchen Ranges
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
on Apr 24, 2015 | Kitchen Ranges
Tip
F5 - E0 Door Switch
Two digit codes:
Regards.
on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
F3 error code when warming up - the unit does one of two things 1) stops before reaching desired temp - 2) reaches the desired temp and then shuts off
Hello & Welcome to FixYa
F3 error code indicates a open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Jun 15, 2011 | GE Profile JT952 Electric Double Oven
My RBD275PDB14 Whirlpool double electric oven started displaying an E6 F2 error message and intermitently shutting down after a power outage. I replaced the control panel but it is still displaying the...
F2 - E6 Cancel key drive line open 1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Nov 03, 2010 | Whirlpool RBD245PDS Electric Double Oven
Tip
Whirlpool oven, stove and range fault codes (ERC and EOC display errors).
Here a list of Whirpool oven fault codes. The codes had been collected from different service manuals. This was a memo that I wrote for my own use. I think this can be useful to owners and technicians.
WHIRLPOOL - most models
Range/Stove and Oven Fault Codes, Common error codes.
F1 - Analog control board Failure
Disconnect for one minute - if error comes back, replace control board
F1 - Shorted control keypad
Replace keypad
F3 - Oven temperature sensor open
Replace oven temperature probe
F2 - Oven temperature sensor shorted
F3 - Oven too hot
F3 - Clean temperature too hot
Replace oven probe
F5 - Door latch switch fault
Test and replace the door switch.
Whirlpool with 4 Digit Failure Code:
F1 - E1 - Electronic control (flip flop)
Replace control board
F2 - E0 - Shorted control keypad
Replace keypad
F3 - E0 - Oven temperature probe open
Replace temperature probe
F3 - E1 - Oven temperature probe shorted
F3 - E2 - Oven temp too high
F3 - E3 - Clean temp too hot
Replace temp. probe
F5 - E0 - Check door latch
F5 - E1 - Check door latch
Replace switch if defective
WHIRLPOOL Polara models 5 digit codes:
F1 F0 - EEPROM communication error
Replace ERC
F1 E1 - EEPROM checksum error
Replace ERC
F1 E2:7 - UL A/D errors
Replace ERC
F1 E4:2 - Model ID error
Reinsert keytail.
F1 E6:0 - Latch signal mismatch error
Replace ERC
F2 E0:4 - Shorted key error
Replace keypad assembly
F2 E1:3 Keytail unplugged
reinsert the keytail
F3 E0:5 Top oven sensor open
Test and replace top probe.
F3 E1:6 Top oven shorted
Test and replace temp probe
F3 E2:9 Bake range over temperature
F3 E3:8 Clean range over temperature
Test and replace temp probe.
F3 E4:10 Bottom oven sensor open
F3 E:15 Bottom oven sensor shorted
F5 E0:14 Door switch errot
Test and eventually replace door lock switch
F5 E1:16 Door latch not operating
Test and eventually replace door latch
F8 E0:17 Refrigeration error
Test the cooling module.
PF Power failure - Does not indicate a fault.
PF occurs when power is disconnected.
WHIRLPOOL
Models SF3, 30'' and 24"
F2 - Oven temperature above specifications
Check 8-pin connector from temp. probe to Electronic Oven Control
F3 - Open oven temperature probe failure
Check wiring, replace oven probe if necessary
F4 - Shorted oven temperature sensor failure
Check wiring harness, replace oven temperature probe if necessary
F5 - Push button stuck or faulty
Check for binding of pushbuttons and control panel glass. If OK, replace touch panel
F6 - Electronic control logic error (timing)
Replace Electronic Range Control (ERC)
F7 - Electronic control logic error (lock motor)
Replace ERC.
F8 - Electronic control logic error
Replace ERC.
on Jan 31, 2010 | Whirlpool RBS305PDS Electric Single Oven
When I turn the GE oven on sometimes it works fine other times it will shut off. When it shuts off it will give the F2 or F3 error sign.Can you please tell me what this means? Thanks
Hi, the F2 Error code means the oven has detected an excess temperature condition. Most often this is due to a bad temperature sensor - the sensor costs about $75 from an online repair site.
The "F3" error code means the oven sensor is open, I suggest you flip breaker off then back, on Re check for error, if OK fine if not turn back off and fix or call for service man...
Oct 06, 2010 | Ovens
My ge xl44 gas range, installed in 2000, turns off and flashes an f2 code occasionally. Can you give me the reason?
F2 means: For an unknown reason, the oven temperature has exceeded a preset threshold.
G.E. recommends you try this:
Sometimes shutting off the circuit breaker that the range or oven is connected to for 30 seconds will clear the fault, error or function code, however there are some cases when further service may be required. If you would like to schedule a service appointment, please contact GE Consumer Service at 1-800-432-2737
Here is the fault code guide link:
http://www.geappliances.com/search/fast/infobase/10009792.htm
May 20, 2010 | GE Kitchen Ranges
Self-cleaning oven F2 error message
Well I found three all same series... If it's occasional I'd leave it 'till was always on? Anyway .....
F2 - E0 Shorted keypad Replace Electronic Range Control/Clock (ERC)
OR....
F2 Oven temperature sensor shorted Replace oven temperature sensor
OR
F2 Temperature runaway detected (Bake/Broil: 600 - 700 F; Clean: 930 - 1000 degrees F). Sounds alarm and resets to non-cook mode. Check relay board for stuck contacts. Check oven temperature sensor for normal room temperature resistance (1085-1097 ohms at 75 degrees F). Check sensor wiring connectors for a loose or high resistance connection. Check electronic range control (also called clock or ERC) functions Replace relay board if necessary. Replace oven temperature sensor if other components check normal. If failure repeats, replace electronic range control (also called clock or ERC)
Feb 16, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
I have a Whirlpool Oven RBS305PDS16 is having an error code E1 F2 and then it shuts off. What could be wrong?
E1 F2 means bad connection between touch pad and control board. if connections are ok it may require parts. may get very expensive.
Aug 20, 2009 | Whirlpool RBS305PD Electric Single Oven
Kitchen Ranges Logo
280 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
