Question about Samsung CLP 315 Laser Printer
I get Parallel lines in print - Samsung CLP 315 Laser Printer
Remove the cartridge then open the cartridge u will see roller behind the drum replace or change the entire cartridge
Posted on Nov 09, 2012
I replaced a tsp600 with a new tsp600
There are DIP switch settings in the printer, Check the old one and change the new on to match.
Feb 22, 2014 | Star Micronics TSP600 Thermal Printer
HP LaserJet P3005 Printer will not print using a parallel cable.
# Switch off the printer, cancel pending jobs..Refix parallel cable both ends & tighten them Check proper drivers installed or not if not install proper drivers.. shoot print command. check..if not resolved...For tech guys:# Replace cable..checkRemove printer formatter, check any dry solder or pin breakage at parallel port.(show in snap shot), found... try to repair it or replace the formatter assm. Check system parallel port working or not...
Dec 30, 2011 | HP LaserJet P3005 Printer
I need to add network to 2844 printer currently USB/Serial
You need to buy the zebranet PS2 print server
P/N G46692 External PrintServer II. It will plug into the parallel port. they just stoped making them but they are still for sale at zebra resellers. here is one at random from google
resize?sq=80&uid=1127727233 ZEBRA G46692 EXTERNAL PARALLEL PRINT SERVER II
more at ZDTronic.com
ZDTronic.com $160.50
  • product
ZEBRA G46692 EXTERNAL PARALLEL PRINT SERVER II ZEBRA G46692 EXTERNAL PARALLEL PRINT SERVER II $160.50 at ZDTronic.com
May 12, 2010 | Zebra TLP 2844-Z Thermal Label Printer
No black when printing color
Dear Sir,
You are getting black lines in green color,and apperence of parallel light and dark lines because your colour catridge is almost empty.So solution is replace the catridge and take a printout. There is no proplem with a printer. i think it solves your problem.
good luck
chandrashekhar
Jul 29, 2009 | HP OfficeJet 4255 All-In-One InkJet...
Tally t6045 printing problem
hi!
there is two reasons behind this problem.
1. The parallel cable is damaged .
2.The parallel port of your computer is damaged.
so at first changed the parallel cable .if not solved connect your printer to another pc.
i hope the solution will work for u.
Regards
Swarnava Palit
U can mail me your problem- swarnavapalit@gmail.com
Dec 21, 2008 | Tally Line Matrix T6050 Printer
Xerox phaser 7700 having problems printing transparencies and accumulator belt problems
Hi xander4265:
I
Streaks in direction of paper travel
There are dark lines running along
the page in the direction of paper
travel from the leading edge to the
trailing edge (B-size print shown).
The printer displays no error code.
Note A-size prints are processed
through the printer with the short
edge of the print parallel to the
direction of the paper path --
making horizontal print artifacts
parallel to the shot edge of the
print.
B-size prints are processed
through the printer with the long
paper path -- making horizontal
artifacts parallel to the long axis
of the print.
1. Check the end of life for each of
the consumables by printing the
supplies usage page. From the front panel’s Printable Pages Menu, select
Print Supplies Page.
2. Run the solid fill test pages; From the front panel’s Printable Pages Menu,
select Service Pages, then select Print Solid Fill Pages. If the missing bands
only occur in a single primary color, replace the print cartridge of the affected
color.
3. Swap print cartridges and run another test print.
Note Under some circumstances, streaking may occur in the margin of
SRA3-size paper. This is due to the edges of the paper extending
beyond the end of the imaging components. print-quality in the
margins of SRA3 paper is not guaranteed.
4. Inspect the Accumulator Belt cleaner; replace the cleaner, if necessary.
5. Run the Remove Print Smears routine. From the front panel’s Support Menu,
select Improve Print-Quality?, then select Remove Print Smears.
6. Replace the Developer Housing Assembly (RRP 27, on page 7-171).
7. Remove the print cartridge and (with a flashlight) check for debris along the
edge of the developer housing.
3041-42
Leading Edge
hope that this will help you.
Sep 18, 2008 | Xerox Phaser 7700 Laser Printer
My Sharp Copier AR-5320 print black and white horizontal parallel lines on the documents.
Check for scratches on the drum surface. If you have ran a lot of copies on there, its a good time to get it serviced. It could be the cleaning blade on the drum as well.
Jul 20, 2008 | Sharp AR-5320 Black and White Copier
Troubles with printing . . .
Replace the communication cable (parallel cable).
If that does not solves, your PC parallel port is damaged. must replace it.
Apr 03, 2008 | Epson FX 1170 Matrix Printer
Tally printer T6180 Printing problem
There are several reson behind the problem.
1. Check the driver settings & match it with the printer imulation.
2.Check the parallel cable.
If not solved connect the printer to a new pc.
some time computer's parallel port may damaged.
Jan 24, 2007 | Tally Line Matrix T6180 Printer
Samsung CLP 315 Laser Printer Logo
12 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
