Question about Ricoh Office Equipment & Supplies
Vertical black line
I have started getting a vertical black line on the right side of all printed or copied pages. The printer otherwise seems to be working fine.
  • Ricoh Expert
  • 414 Answers
Problem in drum charger clean it OR developer unit clean
Posted on Nov 09, 2012
  • steve64419
    steve64419 Nov 09, 2012
    Thanks! Would the instructions on cleaning those parts be in the regular user manual or do I need a repair manual?
  • 62 Answers
SOURCE: Canon NP-4050 printing almost completely black pages
This problem appears to be that the scanlamp cable has fatigued and become open-circuit. This can be checked by selecting A3 and pressing the START button while having the lid up. Watch to see if the light stays on all the way through the forward pass of scan cycle, it can be intermittent. Make sure that the machine is unplugged before attempting to replace the cable.The drum is definitely on its way out at that amount of copies, but can be made to last a fair bit longer with some fine-tuning.
Posted on Nov 09, 2007
SOURCE: I am using a gestetner 1502 I am getting and 1/2
It's strange to me the it would take so long to show up. Problems like this typically happen within the first few pages. "Bands" like this are almost always related to the drum or the fuser, but again, it usually happens right away. It's still likely either of those 2 units, but you should have a technician look at it and tell you for sure.
Posted on Mar 28, 2009
20YrsCompExp
  • 227 Answers
SOURCE: vertical black line on side of copies only when using autofeed
Clean the small piece of glass on the flat bed. Should be on the left side of the flat bed when you lift the doc feeder.
Posted on Apr 11, 2009
SOURCE: Minolta 1030
ecrie probleme j3
Posted on Nov 27, 2009
SOURCE: Printer is printing black lines across all print jobs
i would check the fixing section of the machine which is the hottest part of the machine. weather it is a film or roller you probley have a mark that unit
Posted on Dec 04, 2009
Hp laserjet m1522nf is copying 3inch vertical line in left side of the page and otherwise page is very very clear
If your printed documents are clear then you need to clean small glass which is on left side from big glass. this glass is used for copying from ADF.
Otherwise it is faulty toner cartridge.
May 12, 2016 | HP Office Equipment & Supplies
My HL2040 printer is printing black vertical lines along the right-hand side of the page, about 3" or so. A month ago I took it apart and cleaned the roller. Still doing it.
If the lines go all the way down the page, check the position of the corona wire cleaner tab (blue or green) at the top front of the drum unit. if not parked fully to one side it will create a solid black lines where it blocks the laser. Otherwise look for some other foreign object (or torn paper piece) that may be blocking the laser from the drum. If the lines are thin and shark, check for scratches on the drum (not repairable without replacing drum). If the lines are uneven thickness but in a pattern that repeats down the page every few inches, then the film on the drum is probably worn or wearing away and the drum needs to be replaced.
Mar 04, 2015 | Brother HL-2040 Laser Printer
Getting a black line on paper when printer warms up...
Black lines on copy come from toner cartridge, or drum unit, or fuser unit which is in the back. check drum and see if you can see line, back of machine with flash light you may be able to see line on fuser roller. Be carefull Fuser is hot.
A copy that is good and then starts to get lines usually the drum unit...
Mar 26, 2017 | Brother MFC-9840CDW Laser Printer
HP Officejet Pro 8600 vertical lines on all copies
I had the same problem; it happened with the first copy I tried to make directly from the printer's console - but only with the Black ink function - with the same original on the flatbed glass I then tried the Color function and it worked fine. But when I tried the Black copy function, the strong vertical lines appeared again - about 7, evenly spaced across the page and running the entire length of the page.
Nothing about cleaning any part made sense: the printer was brand new, out of the box, the color ink function worked fine to copy; so did making scan copies. It was only the black ink mode in the copy function with the original on the flatbed glass that produced the vertical lines.
What cleared it up was shutting it down, removing and re-inserting the power cord the other way, i.e., turning it around (which might have nothing to do with the outcome) and Voila! - no vertical lines with the black ink copy function - Go figure...
May 29, 2012 | HP OfficeJet Pro K8600 Printer
Broad dark line on right edge of copied papers
If you have the black line on copies and scans but printing from P.C is fine, then your scanner is broken.
Contact your printer manufacturer for a replacement or repair.
May 12, 2010 | Office Equipment & Supplies
HP Laserjet 3330 printed dark page especially around the middle
Does this happen both when copying and printing?
For printing solution, try another toner cartridge.
If lines continue to appear when copying (primarily through the automatic feeder) then lift the auto feeder, and clean the glass -mainly the narrow piece on the left side.
please rate solution :)
Apr 07, 2009 | HP LaserJet 3330 All-In-One Printer
Brother MFC7820N
I assumed you are using a digital copier/printer, in digital machine there were 2 kinds of diagnosing a problem, and you are right with your observation Copying and Printing, and each have two separate troubleshooting.
If you say that in printing is fine, then the problem is with the scanning part which is in your Optical Unit, here's some pointers
1- Open the optical glass on the top, with screws
2- Observed the optical unit with 3 reflective glass, it could be dirty
3- the middle of the optical system is called the CCD which converts the image from the reflective mirrors, see if you can find dust and dirt.
4- Check the lamp for any sign of dirt this could cause also some problems.
these are the only areas you need to check, nothing else, and this would surely solve this problem
Jul 15, 2008 | Office Equipment & Supplies
Copying with page feed results in a vertical line on every page
There must be a strip of glass about one inch wide, next to
the large glass. There is the problem !
Clean that strip thourougly. When you use the feeder the pages
are scanned thru the small strip of glass.
Mar 26, 2008 | Canon PIXMA MP780 All-In-One InkJet...
HP 3050 Black Line
I was getting a verticle black line and I had to clean the glass, the long white bar above the glass, and the white and black rollers before my problem was solved.
Mar 12, 2008 | HP LaserJet 3050 All-In-One Printer
95 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Bernard D'Souza
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
