Question about HP Computers & Internet
How to manually disable internal sound card
Is there a way to disable the internal sound card
  • 564 Answers
If you go to your control panel and choose sound you can disable it.
Posted on Nov 09, 2012
2 Suggested Answers
knotbeerdan
  • 413 Answers
SOURCE: I am running a new usb sound card on my fujitsu n6410
go to the device manager by going into the control panel and double clicking on system then the hardware tab then device manager
Posted on Dec 30, 2008
How do I access BIOS to disable my internal sound card
to enter the CMOS by pressing one of the below five keys during the boot. Usually it's one of the first two.
Sep 07, 2012 | Gigabyte GA-G31M-ES2L Motherboard
Hey, I've got an HP Compaq D530 SFF desktop machine whose sound card uses the SoundMAX drivers. The problem is that when I connect earphones/headphones on the front panel, and try to listen to music or...
if you go to the bios (restart computer and press del to go to setup) you should be able to look around and find the option for internal speaker. Set that option to disable and do not change anything else unless you know your way around. Save it and restart afterwards and it should disable the internal speakers.
May 06, 2011 | HP Compaq Evo d530 PC Desktop
I have ASUS M2N--68 mother board. its sound driver is not getting indstalled in Win Xp SP3. Urgent help required..
hi shreyash, do you having on board audio card mean go to bios and check weather you have disable , if it was disable mean enable it.
If you using internal or external sound card mean, go to bios Disable your onboard audio card , so only your internal or external sound card will work.
And i will give original Asus mn2 motherboard driver , install it and check it once. copy and paste the link i have given below
http://www.asus.com/product.aspx?P_ID=0pKBwEIE8tqMT4j7
or click here
After page get loaded scroll down, click download in tab and select your OS and download your Drivers.
Good luck
Jan 11, 2011 | ASUS M2N-MX Motherboard
My speakers are on but sound does not come out, There is beeping noise when turned on to full. Any help?
Well, you don't loose your sound, you loose your sound card setup and driver, you need to reinstall the audio card in another slot PCI, ( if is a external sound card) and install again the sound card drivers. If is internal sound, onboard audio, you need to go into BIOS and disable, and reenable the audio card, and reinstall the drivers. it should work
And Thanks.
Mar 10, 2010 | IBM ThinkPad R40 2722 Notebook
How to disable on board sound card in dell dimension 8200
At the boot process press key F2 in order to get into the bios settings. Here you will find "Integrated Devices" select this line with the cursor keys (up and down) and press enter (or spacebar).
On the new panel locate the option "sound". It must be marked as ON state. With the cursor keys (left and right) or + / - change the state at OFF. Press escape to exit from this pane, and escape again to exit the bios. At the prompt panel that appears select "save changes and exit" and press enter. Your Dell is going to reboot now with the internal sound card in disabled state.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"????????? ???????"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
Feb 25, 2010 | Dell Dimension 8200 PC Desktop
The sound goes off intermittently
Forget Sharp's defective speakers. Connect your sound output to powered stereo speakers and disable the internal speakers (look through the TV's menu). The operator's manual explains how to disable the internal speakers. You'll be able to control the sound normally (mute, volume) with a remote control.
I connected my stereo output (2 RCA plugs) to an old boom-box and I get better sound than with Sharp's built-in speakers.
Jun 28, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Dec 30, 2008 | Fujitsu Siemens LIFEBOOK N6410 PC Notebook
Soundcard
Hey there, the HP bios is pretty smart - it should automatically detect a new sound card and switch off the internal one when installed - alternatively you can go to the 'system devices' panel and disable it in the software as well.
hope this helps
cheers
Nov 19, 2008 | HP Compaq dc7600 Convertible Minitower PC...
Re: Volume dropping in and out while recording audio.
I’ve never tried using an external USB sound card before but apparently they are available. As far as disabling your existing sound card, check in the BIOS (Setup Menu <F2>). It is also possible to disable under “Device Manager”. Here’s a link to service and owner’s manual for your model: http://support.dell.com/support/edocs/systems/ins6400/en/index.htm
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Oct 29, 2008 | Dell Inspiron E1505 Notebook
Do you have to alter jumpers to fit a sound card
No, you just have to disable the onboard sound card by going into the device manager and right click on whatever sound device is listed then click on disable. when you install your new sound card its software will install it's drivers and away you go.
Hope this helps,
George
Jul 14, 2008 | Intel Motherboard
Computers & Internet Logo
22 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
