Question about BenQ FP737S-D 17" LCD Monitor
Blank scren, led stays green for only one second
Hi, I have had this screen for 2 years now. One day, it stopped working... The screen is blank and the LED is off. If I press the power button, the screen displays a BenQ logo and the front LED turns on (green); 1-2 second(s) later, the screen is blank again and the LED is off... I have tried a different graphix card, a different computer, a different VGA cable and a different power cable. I hope someone can help me... Thank you very much I hope I have been explicit enough Regards Cyril
    Genius:
  • 2,985 Answers
Explicit enough to see that's this a a repair shop job. That also probably means a replacement- cost of which will not be much more than repair prices. One thing how ever- the power supply[which would appear to be the problem] is this built into the screen [that is does the screen have mains power direct? Or is it powered from an external 'Power Brick' If it is of the Power Brick type - then a new power supply is the answer - get on of the stabilized universal type with a fistful of connectors and a voltage selector switch.
Posted on May 24, 2007
Luxor 40 914 tvb
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 13, 2014 | Televison & Video
Blank HP w1907
If the power light does not turn color and stay's green on startup, it is not a power problem. It is most likely the inverter. If the unit is in warranty, send it out ASAP. Contact HP customer care by email and have the issue logged in.
If in warranty, they will send you a box by FedX second day and have repaired.
This is a 19" monitor and will not be worth paying for repairs if not in warranty.
Sep 03, 2009 | HP w1907 LCD Monitor
Monitor goes blank after 2-3 seconds
could be hardware failure but i would try buttons on front of monitor first. notice, usually green led on monitor is green, if it goes to amber, you are loosing sync pulse.
Aug 20, 2009 | Computers & Internet
Screen stays blank My Ps3 machine turns on, the light is green and you can hear the machine is running, but the scren remains blank, is there something wrong with the aerial? I'm using the AV connection ,...
Sound like maybe, your input has changed , maybe from sd to hd .Try holding the ps3 button down for 4-5 seconds when you turn it on, this should reset the input mode
Jul 29, 2009 | Sony Playstation 3 (PS3) Console
Benq FP92G Display couple of seconds then blank. LED still green.
budged electrolytic capacitor nearby high voltage transformer. 220microcarad/25Volts. apply fresh solder and re-connect lamps.
Jun 01, 2009 | BenQ FP92G+S (Black,Sylver) (Silver,...
Screen goes blank within 1 second of being turned on
Bad capcitor in the psu would cause this to squel and even pop so have it looked at you be glad you did.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 23, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Emachine - T6420 - Monitor on stand by, no picture, fan running non stop, hard drive power on, screen blank, monitor in yellow not green the programs would end after 10 seconds---if you opened...
Most likely your video card is broken. To check if the motherboard isnt broken either, I would suggest you test usb, sound, and other features of the motherboard.
 If your motherboard isnt broken then you have to buy a "pci-e graphics card" at your local store. Shouldnt cost much, about $40-70. Hope that helps.
Jan 02, 2009 | E-Machines T6420 PC Desktop
Blank screen, led lights on, intermittent beeps
take out the RAM of your laptop, put it again,
also check the display on external monitor through vga port
Oct 20, 2008 | HP Compaq nc6000 Notebook
Monitor displays breifly then goes to blank screen
The power -inverter board probably needs an overhaul.
I redo many of these.
If the screen was pinkish or flickering before it finally got to this point, it is possible that a bulb has gone bad.
Fran
Sep 07, 2008 | Proview PL926WBi 19" LCD Monitor
Screen displays fine for a second, then goes blank
Dor, BenQ has a 3yr warranty on their monitors. I would contact their tech support and receive an RMA to return it for repair. It will cost you shipping out there but they will ship it back. I has a BenQ FP731 myself and it blew a capacitor inside that allowed the screen to stay on. Fixed it and had it back in 5-7 days. Good luck.
Aug 15, 2007 | BenQ FP737S-D 17" LCD Monitor
BenQ FP737S-D 17" LCD Monitor Logo
241 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tommmix
Level 1 Expert
Computer Links
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
