Question about Husqvarna Forest & Garden No.967012396 345 16" Gas Chain Saw
345 husqvarna chain saw will not run
After many 10-15 pulls it may start. But after I get it to idle I increase the rpms and it will die. Sounds like it floods out. I have drained the gas checked the diaphram. Please help!!!!!!!
  • Anonymous Feb 04, 2009
    will not start at all has spark everything as far as i can tell is working just wont start
  • 36 Answers
If it idles it is not flooding out as it it most vulnerable to flooding at idle if the stalling is happening as you try to throttle it up it is likely starved for fuel. Start by changing the in tank fuel filter, and the spark plug. good chance that will solve your problem. If it does not Turn the high idle screw out in 1/8 turn increments try running the saw after each adjustment. Keep track of the amount that you turn the screw. you might have to put it back to its original position. Some times adjustment screws will vi berate out of adjustment and other times crud will cause fuel restriction opening the screw allows for a larger port for any restrictions to pass through. After you use the saw for a short time turn screw back in if it starts to stall at idle or you notice increased smoke.
Posted on Jan 06, 2009
I have a husqvarna 345 run for a few cuts then stops.
either blocked fuel filter in the fuel tank ( hook out and replace ) or the fuel tank breather is blocked thus causing a vacume in the tank, to prove this, when the saw starts to die slacken off the filler cap, this will allow air into the tank and it should pick up again, the breather is pressed into the tank on the r/h side rear.
Sep 19, 2012 | Husqvarna Forest & Garden No.967012396 345...
Hi, i have a 1999 husqvarna 254xp... its abit hard to start and never idles more than 3secs.....from doing some looking into , i think maybe the L screw needs adj? if so could u explain in simple terms how...
In simple terms here we go, turn both L screw and H screw fully in until they stop ( clock wise ) now turn the L scew out one and a half turns out, and the H screw one and a quarter turns out, start the saw ans warm up the engine, allow the saw to idle, if need be turn the idle screw in to gain a slightly fast idle, start to turn the L screw in, the revs will start to increse as the mixture leans off, thet will reach a point where the engine then starts to die because it is too len, at this point unscrew the screw quarter turn, check the machine revs up clean, if there is a hesitation unscrew the jet a smaal bit at a time until it revs clean, now adjust the idle screw so the engine idles without the cutting chain rotating around the bar, the H screw should be about right however if it sounds too rich at full throttle srew the jet in a small amount until it sounds right, the maximum rpm should not exceed 13500, this should realy be check with a rev counter, if the engine revs too high there is a fear that it will over heat and seize.
Apr 13, 2011 | Husqvarna Forest & Garden No.967012396 345...
Chain suddenly stopped,#345, motor runs. can't turn it by hand
Sounds like you have had a kick back and the chainbrake has activated, with the engine stopped, grab the front hand guard and pull it fully back to the top handle, until you hear the click of the brake loading.
Apr 02, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna 345 chainsaw will not start. It is 3 years old. No problem till now. spark good, getting fuel, filter, sparkplug good.
I suspect she is flooded. Flooding is the most common cause of fails to start on a chainsaw. Remove the plug I bet it's wet.
Start Procedure
Cold:
  1. Ignition on/off to on
  2. Set compression release – optional step even if saw is equipped with a compression release
  3. Pull (close) choke, set fast idle (done when choke closed on some saws); pull starter and listen for an attempt to start. once heard (usually two pulls; no more than 4)
  4. Set compression release – optional step even if saw is equipped with a compression release
  5. Push (open) choke pull starter until it starts. (usually first pull)
Warm:
  3. Pull (close) choke, set fast idle (done when choke closed on some saws) - Don’t pull with choke closed.
  4. Push (open) choke, pull starter until it starts. (usually first pull)
Hope this helps
Lou
I've a 359 one time I forgot to pull then push the choke (sets fast idle). My shoulder gets sore just thinking about it.
Nov 10, 2009 | Husqvarna Forest & Garden No.967012396 345...
Hard to start Husqvarna 435
reportedly you need to open up the low idle jet screw about 1/4 turn, takes an odd shaped tool to get at it, Husky sells this tool, or you can probably makeshift one from hard plastic tube... anyway, this is due to EPA issues, but once you increase the L adjustment 1/4 turn (counter clockwise, I believe), problem is said to go away.
Aug 30, 2009 | Husqvarna Forest & Garden No.967012396 345...
Husqvarna chainsaw carburetor adjustment
Find the 2 screws. There will be a (h) high and (L) low. These are for hig rpms and low rpms. First tighten the screws. Then unscrew them about 1-1/4 turns. Then start the saw and let it warm up. Start with the high rpms first pull the trigger all the way then adjust the screw in 1/8 turns either way until it is running good at high rpms. Then work on the L rpms. Get the saw to idle then pull the trigger, there should not be any hesitation when going from L to H rpms. Just adjust the low same as the High. They have to work together so if the high is good and the low is not just right turn the h a small amount. If you have any more questions let me know
Jun 11, 2009 | Husqvarna Forest & Garden No.967012396 345...
Where is the bar oil adjusted from on husqvarna 345
Turn the Hus 345 chain saw upside down, you may see a little Icon of a oil droplet and a + - arrow by the chain. THe adjustment screw is not pictured in any of the standard user manuals,. but it is a small black slot headed screw over a rectangale metal tab by the chain. I believe if you turn it counter-clockwise, it will give you more oil,, It did for me. If you have the bar off, you can start the saw and see it come out the hole, that would verify your oil pump is working. Make sure the holes on the bar are clean also. running the saw at a fast idle for 1 min should oil the chain well enouth that it starts spraying off the end of the bar when you gun the engine.
Mar 31, 2009 | Husqvarna Forest & Garden No.967012396 345...
My 345 chainsaw bogs down when it hits wood
There are two idle screws one high, and one low. Your high adjustment idle screw needs to be adjusted.
Jan 18, 2009 | Husqvarna Forest & Garden No.967012396 345...
Husqvarna model 345 chainsaw
adjust the gas by turning the screw on the carburator
Dec 28, 2008 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna Forest & Garden No.967012396 345 16" Gas Chain Saw Logo
930 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
