Question about Belkin Computers & Internet
Cannot connect to my belkin n150 model f9k1001v1 router
Every time i try to connect to it on my mac it keeps saying connection time out.. i have another router already but 1 modem i am trying to set up a second router but connecting it through my first belkin router could that be an issue or is it something else?
  • 2,878 Answers
Yes. You need to modify the IP and DHCP scope on the second, so there are no IP conflicts.
Plus this setups a second LAN, and obviously a second network configuration if you are trying to use the same computer.
Posted on Nov 09, 2012
sandrew
  • 2961 Answers
SOURCE: Belkins router not connecting to cable modem
You need to start from beginning. Clear all temp internet files and run this programme Start>Run ipconfig /flushdns and hit enter. Get into the routers settings(probably 192.168.2.1) and ensure in the Lan settings that 'DHCP Server' is on and wireless is enabled.(you might need to be connected by RJ45 lan cable first) If it's a 125mbps router change settings to 54mbps to try that speed first(especially as your wireless cards will be 54 mbps) look in Mac address Filtering is off. Look in the DHCP Client list and see if your pc's were allocated ip addresses, if so it should allow an internet connection. Go to both your pc's wireless cards properties and under TCP/IP properties ensure obtain ip address automatically is checked. Restart both pc's and the router, disconnect cable and try wirelessly
Posted on Mar 07, 2007
kakee
  • 1269 Answers
SOURCE: XBOX 360 not connected to wireless connection on Linskys WAG54G2
You should enter the "Wireless MAC Address" of the XBOX and not just the "MAC Address". You can see it on the system info of the XBOX settings.
Posted on Jan 06, 2009
SOURCE: Belkin Wireless N+ router - can't connect to Etisalat in UAE
you could try updating your router's firmware.. it fixes a number of bugs and makes the web interface multi-lingual. This version supports English, German, French and Spanish.
Posted on Feb 25, 2009
RickOz
  • 145 Answers
SOURCE: Connecting Laptop wireless and Desktop wired to the router
Do you need to see the desktop or just share folders from each other? If the latter then you need to do the following:
Use Windows Explorer and select a folder you want to share. Right click and select sharing and security.
On the sharing tab click on Share this folder. Enter a share name ( I like to enter the PC name _folder name; Rick1_Downloads)
Click on Permissions. If your ok with everyone using the PC's and Laptops having access then highlight Everyone and click on Full Control.
Do this on each PC and Laptop.
That should be it or darned near close.
Posted on Apr 10, 2009
  • 181 Answers
SOURCE: trying install belkin n150 router.setup router and
Try the following:
1. Make sure your PC is connected to the router directly and the LAN ports are lighting up
2. Reset the router
3. Reset the network adapter on your PC (or just restart the PC)
This should ensure that you are connecting on the LAN port.
Posted on Jan 04, 2010
Need password
Connect the Belkin router to a computer with an ethernet cable
Open a web browser and enter 192.168.2.1 in the address bar.
Check the Network name and Password - make a note of them.
Setting up the Belkin router
Belkin
N150 Wireless Router
Part # F9K1001
Belkin
Feb 18, 2014 | Belkin Connect N150 Wireless N Router
Belkin n150 cisco vpn
hi - I just had a tough day trying to connect N150 to my company's VPN, and after a long struggle found out that Belkin N150 does not support the VPN connections. simply upgrade it to N300 and you would be fine.
Jun 08, 2012 | Belkin Connect N150 Wireless Router...
Belkin N150 MODEL F9K1001v1
The Wep Key might be on the side or bottom of your router. It will be on a label and most likely called the Network Key.
If it is not there then you will have to get on the computer that is connected to the router with a Network Cable (most likely a desktop might be already connected to the router with a cable) and then you will have to type the ip address of the router (something similiar to 192.168.1.1) to get into the router to see the wireless Network Key. The ip address might be on the side or bottom of the router also.
If you don't know the ip address look for the manual that came with the router or you can google the router's model for the ip address or go to the manufacturer of the router's website for the manual.
You will also need the login user id and password to get into the router. Most times it will be the default userid and password set by the manufacturer unless whoever installed the wireless router changed it. The manual can also tell you the default userid and password.
May 13, 2012 | Computers & Internet
My belkin N150 adapter keeps dropping connection on my pc
For the WIFI connection droping problem ,goto browser and in URL 192.168.2.1 and click on security and keep it disabled .this will solve the connection droping problem..if u r concern with the security add the required MAC address in the mac adress filtering ..
i tried this and its wrking great..
regards,
goutham
Jan 11, 2012 | Belkin Basic Wireless N150 USB Adapter
I have a new belkin n150 when i conect to the modem, there is a amber flash light for the modem on the router, when i conect the computer directly i have conection, i have folowed all the instructions but...
This indicates that router can't detect cable modem or this is unresponsive, probably your modem is logically tied with your PC (MAC address associated), that's why when you connect them directly work fine, if this is the case, you'll have to clone the MAC address of your PC into your router, this should be at Setup Menu, Manage MAC addresses option.
Feb 21, 2011 | Belkin N150 Enhanced Wireless Router...
I have Belkin N150 Rouer. My internet is Time warner. It has no connection between the modern and Belkin router. How can I set up Belkin N150 Router to solve this problem?
f the modem light keeps blinking, it means that the router hasn't been configured yet. Also, rarely, it can be an issue with WAN port/modem port on the router or the ethernet cable connecting the modem to router or finally, modem may not be working as its not applicable in this case(as you said).
1.Connect comp.--(gray port) router (yellow port)--modem
2.On the computer, open the router page by typing 192.168.2.1 in the address bar of browser
NOTE : IF YOUR INTERNET SERVICE PROVIDER IS CABLE FOLLOW THE BELOW STEPS
3.Under Internet WAN , SELECT the connection type as Dynamic.->NEXT
4.On the far left column, click on "MAC address" under Internet WAN.
5.Click on clone and apply changes and finally check Internet status
6.If internet status > Not connected, we need to do a network power cycle
7.For this, unplug the power from router, then from modem, then unplug the coaxial cable from cable modem.
8. Wait for 60 sec, then connect the coaxial cable, then connect power to modem, wait for lights on modem to get steady, then finally, plug in the power to router.
Now, you may see proper lights lit on the router.
All my best wishes for a fast internet service through the router.
FOR PPPOE OR DSL CONNECTIONS
1.Under Internet WAN , SELECT the connection type as PPPOE ->NEXT
2.ENTER THE USERNAME & PASSWORD PROVIDED BY YOUR IN INTERNET SERVICE PROVIDER
3.CLICK ON APPLY CHANGES
For any advanced help, revert asap!
Thanks and regards,
MILAN
Jan 20, 2011 | Belkin Connect N150 Wireless Router...
I have Belkin N150 Wireless Router installed. I can connect my laptop to it. When I tried my PS3 and I pod Touch and enter the same password but still it can't connect..guys, help me please..tnx
You have to allow these device to connect via MAC address ( Media Access Control) or set an IP.
This is done in the router. Check your router instructions for game settings.
Setting the router firewall game allowance or device is possibly where you are have an issue.
Jul 02, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
Unable to configure belkin n150 router manually
while connected to router, open internet browser and enter 192.168.2.1 into the address bar. this opens most belkin router setup utilities.
Mar 04, 2010 | Belkin Computers & Internet
Computers & Internet Logo
176 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
