Question about Arris SURFboard SBG900 Wireless Router (DHSBG900)
Changing rstp port on router - Arris SURFboard SBG900 Wireless Router (DHSBG900)
  • 2,878 Answers
Not capable. This is a modem with wireless gateway.
You would need at least 3 routers that support 803.1w or 803.1d for Spanning Tree.
http://media2.comcast.net/anon.comcastonline2/support/help/manuals/Motorola_SBG900.pdf
Posted on Nov 09, 2012
When i click on watch to see youtube video in samsung j700 ,there come malformed error
There could only be two reason for this,
1) The phone dont support Youtube, as this phone dont support RSTP protocol.
2) The URL typed is wrong.
Regards,
Shrey
May 31, 2011 | Computers & Internet
Im trying to chang the nat setting on my valet m10 router to open to all xbox 360 to run live
You need to setup port forwarding read below.
Once you open the set up interface of the router, you will be able to find the settings on the router where you can open the ports for the particular program.
If you are opening the ports for a special device in your network, then you must know the IP address of that device.
For example, wireless camera, DVR, X-box, Play station ...
You can choose the option PORT FORWARDING for a special device application.
If you just want to open the ports for all the network, then you can choose PORT TRIGGERING
For Linksys Router.
You have opened the set up interface of the router. You will see Application and Gaming TAB at the top.
If you click on that tab you will find different Sub tabs.
Click on Port Triggering => Here you can open the port numbers for the network.
Click On Port forwarding if you want to open the ports for a special device in the network.
Click Save settings once you open the ports on the router.
For D-link router
You will see Network settings in the left hand side panel of the page.
Click on Network settings and go to the Advanced TAB at the top.
Now you will find the option. Pot Forwarding in the left hand panel.
Here you can open the ports on the router.
BELKIN wireless router
Click on Virtual Servers under Firewall in the menu on the left
Click Enabled. Type a general description of the application i.e.. Remote Desktop. Type the port(s) specified by the program manufacture for both of the Inbound port fields. Select TCP, UDP, or BOTH for the Type.Private IP address: Enter the IP address of the computer you want grant access too. Type the port(s) specified by the program manufacture for both of the Private port fields.Click the Apply Changes button.
NETGEAR Router.
Click on Port Triggering under Advanced menu.
Change the value of Port Triggering Timeout as 20 Click on Add Service. Specify a Unique/User Defined name under Service Name. Ex: Mails, VPN. Specify the Service User as Any (if all the computers in the network are port triggered or if a single computer on a network is port triggered specify the IP address of the computer). Select the Service Type of the port to be triggered
Ex: TCP . Specify the Trigger Port (The port to be triggered). Select the Connection Type of Inbound Connection. Specify the Starting and Ending Port for Inbound Connection. Click Apply to accept changes. Your router is now set up for port triggering..
http://www.youtube.com/watch?v=fYwd0YkXdY0&feature=related
Jan 20, 2011 | Computers & Internet
How do I configure my router for port forwarding
For Linksys Router.
For D-link router
NETGEAR Router.
Jan 19, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
How do i make nat open
You have two options:
1. You can open port using router's web interface. Check what ports used your software, what protocol TCP/UDP then go to web interface's virtual server and add new user's rule. Then you have to save and reboot router. Every time your PC IP changed (static IP recommended) or program you using changed port number you have to do web interface operation again.
2. Download and install Router Commander (fully compatible with your router) and that's all. The software will forward ports automatically.
Dec 21, 2010 | D-Link DSL-G604T Wireless Router
My email does not come thru when my computer is connected to the router
did it work before? what did you change on your router? can you change it back?. does it work when you computer is directly connected to your modem?
if you download your email into an email client (outlook, outlook express, other)? you may need to configure the port forwarding on your router to allow the port used for this type of information to come through.
first find out the ports used, (if you use pop3 the port number is 110) but find out what specific ports are being used as per your email client configuration.
now go into your router's configuration page and go to the port forwarding section (under advance configuration) on you router and enable these ports if they are not enabled already enabled. (if your router is in fact blocking this ports this where the blocking happens) unless there's a good reason for you to configure this, do it otherwise leave the advance settings alone.
your router manual can be found here
good luck
Dec 27, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
How to forward port on telkom mega 100wr router
1. You can open port using router's web interface. Check what ports used your software, what protocol TCP/UDP/BOTH then go to web interface's virtual server and add new user's rule. Then you have to save and reboot router. Every time your PC IP changed (static IP recommended) or program you using changed port number you have to do web interface operation again.
Nov 05, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Netgear switch GS748T smart switch needs reboot very frequent
(Answering a six-year-old question...)
From the description--especially the part about having "spanning tree" disabled--the first thing that I would do is look for network loops. STP/RSTP ("spanning tree") detects these loops, and disables ports to prevent packet storms. If that is the problem, enabling STP should clear it up--but you also want to make sure you want those loops in the first place.
Dec 02, 2008 | NetGear ProSafe GS748T 48-port Gigabit...
Arris SURFboard SBG900 Wireless Router (DHSBG900) Logo
Top Arris Computers & Internet Experts
Suddenlink Help
Level 1 Expert
bobkoure
Level 1 Expert
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
