Question about Saniflo & Saniplus& Macerator Pump
How do i test the actual motor on a saniflo macerator?
How to test the motor using an ohm meter? also what type of microswitch does it use... SPDT????
  • jonny serlo Nov 12, 2012
    ok figured out micoswitch but now to test the motor before i put it together? anybody? should i be looking for NO continuity between the 4 wires(3+1 earth? )
3 Suggested Answers
  • 251 Answers
SOURCE: saniflo macerator pump to toilette cauase mcb to
hi, the usual cause is damp or water in the connector box on the unit .
hope this helps
p.s. wear gloves
Posted on Apr 24, 2010
  • 115 Answers
SOURCE: macerator
You can download their installation manuals from their website at www.saniflo.com
Posted on Jan 26, 2012
I have a Sanipro,it sounds like it pumps real weak and goes off quickly instead of emptying out everything. then it will come on again after aseveral seconds . Could it be the Condenser on the motor?
  1. Saniflo & Saniplus&... Repair Questions - Fixya
    www.fixya.com/.../p1064016-saniflo_saniplus_macerator_pump_002 Saniflo & Saniplus& Macerator Pump - Recent Questions, Troubleshooting & Support ... My saniflo does not flush properly always leaves the toilet paper behind.
Jul 20, 2015 | Saniflo SANIPRO Macerating Pump
How do i fit micrio switch
The microswitch is located inside the pressure chamber. The pump will have to be opened, the motor and pressure chamber will have to be removed out the top of the casing as one piece, the pressure chamber has to be opened and the internal components will come off the bottom, you can access the micro switch at that point. You can also download the installation manual from the Saniflo website.
Mar 05, 2013 | Saniflo & Saniplus& Macerator Pump
Macerator works only for 5mins every 15mins. But won't work during the 15mins.
Well it is working in a stinky environment! Just think, without it you could be hand chopping all that "stuff" up!!!
http://www.ehow.com/info_12169188_saniflo-system-work.html
Sounds like you have a sticky switch inside the macerator.
http://www.saniflo.com/products/index/show-product/lang/en/type/part/id/54
As this is a messy piece of plumbing, I'm going to recommed that you take it out of the system and take it outside in the yard, away from the house and give it a good hosing out. It is possible that some gunk has clogged up the pressure chambers vents and this is causing the float or whatever mechanism in there to be stuck on. Flush it as much as possible before you disconnect it.
Sep 04, 2012 | Saniflo SANIPRO Macerating Pump
Saniflow motor is not swiching off after water is pumped out
The "Sensor" has failed, it needs to be repaired or replaced.
Apr 16, 2010 | Saniflo & Saniplus& Macerator Pump
My Saniflo sanicompact does not flush away, when i press the flush botton it does not work, the toilet buzzes all the time. when the water gets to a level it use to pump away but has stoped doing this.
saniflo buzzing all the time means that the motor is trying to run but cannot. indicates that something is blocking the pump impeller from rotating. unit needs to be removed, cleared and tested. if fault contiues you may blow the fuse (if you are lucky) otherwise the motor will eventually burn out. get this checked soon.
Apr 12, 2010 | Saniflo Sanicompact Elite - One Piece...
Saniflo Saniplus won't stop pumping
is it pumping against gravity? if so there is a non-return flap in the outlet spigot could be stuck or worn.
Apr 10, 2010 | Saniflo & Saniplus& Macerator Pump
Self activating and not pumping away. waste backing up into pan
self activating - the pipe work is blocked and the saniflo is trying to emty (microswitch activated). as the outlet is blocked so effluent will be forced back - in this case up into the pan. Messy job- drain down remove clean clear blockages refit.
Mar 13, 2010 | Saniflo & Saniplus& Macerator Pump
I have a 3 year old Sanivite 3 macerator that has stopped pumping. It is used under the kitchen sink for removing water and soft food waste. Yesterday I removed the unit and cleaned the inside which was...
if the unit is properly clean and you have checked the fuse - then i suggest it is the microswitch that needs replacing. these tend to go (break) within 5 years on the sanivite 3 models. If not the swich then it could be the capacitor (try this first - although as the swich is located next to the capacitor you can test this for operation at the same time). if none of this works then its time for a new unit.
Nov 09, 2009 | Saniflo & Saniplus& Macerator Pump
Saniflo Macerator Noise
If it's a one shot cleaning and not an ongong additive, bleach can be used to dissolve the tissue.
Charlie
Aug 03, 2009 | Saniflo & Saniplus& Macerator Pump
Saniflo & Saniplus& Macerator Pump  Logo
51 people viewed this question
Top Saniflo Home Experts
paulcarew
Donni Steen
Are you a Saniflo Home Expert? Answer questions, earn points and help others
