Question about Garden
STX 38 Ride-on mower, Motor runs in neutral, but cuts out when you engage a gear, also cuts out when you switch on blades
  • 21 Answers
Check for build up around blades. But it sound as your fuel bowel is clogged or your carb needs cleaning.
Posted on Nov 10, 2012
  • 33 Answers
SOURCE: motor stops when the pto or cutting blades are turned on or engaged.
you most likely have a bad safety switch. there is one under your seat,one on engagement lever for blades,and probably one or two more in other places.start with the one under your seat by unplugging it and then going ahead with normale start up and implement engagement. you will have found the bad switch when everything works as it should.replace switch if you feel its necessary or just leave unplugged. it will not affect performance or longevity of the tractor
Posted on May 02, 2009
SOURCE: Stalls when engage blades in forward, but cuts fine in reverse
Did you try to disengage the safety feature that should shut the tractor off when the blades are engaged and the tractor is placed in reverse? I believe that it is located under the shift leaver
Posted on May 15, 2009
  • 376 Answers
SOURCE: mower will not drive
Usually, that's an indication the the seat switch is not working. It's like getting off the seat without locking down the parking brake or getting off the seat with the baldes engaged, same result...engine dies.
Posted on Jun 03, 2009
  • 81 Answers
SOURCE: Mower wants to stall when blades are engaged
Usually when the motor stalls when blades are engaged on any mower it is the carb that needs cleaned and rebuilt. The motor isn't getting enough gas to handle the load.
Posted on Jun 23, 2009
  • 9 Answers
SOURCE: i have a bolens 38 inch riding mower. it cranked
did you try depressing the clutch to disengage everything regardless of being in neutral? and it sounds like a pulley bearing went bad.try to spin the pulley with your hand and see if it moves.take the belt off to the mower deck and that should keep them from turning when you go to start it.
Posted on Feb 21, 2010
Testimonial: "thanks. at least i can crank it and get it to a trailer instead of pushing it. i really appreciate it.......cb"
Mower blades will not turn on with pto switch engaged on john deere stx 46
first look for a blown fuse the old clutch may have burn it out the check to see if a safety switch burned out
Apr 01, 2012 | Garden
Blades will not engage on my john deere stx 38
check your electrical switches.
Sep 21, 2011 | Garden
Mower cuts off when blade is engaged.
Not familiar with this model, but a thought, check for a kill switch.
Apr 27, 2010 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
I have a husqvarna 172 ride-on lawnmower. Running
This unit probably has a safety switch built into it and it could be below the gas tank. If this switch isn't adjusted properly then it's designed to cut off the motor. I think you should concentrate on that before attempting anything else.
Aug 02, 2009 | Garden
Where are the safety switches located?
one on the cutting deck or engagment lever, one on the clutch. some have one in the transaxle as well. start in neutral only.the deck sensor tell the mower if the blade is in or out of gear,the one on the clutch is for starting.
Jul 19, 2009 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Poulan Riding Mower will run in neutral, not in forward or revers
you have safty switch on the mower one or more are bad there are three of them
win you put in reverse some mower will cut off this is a safty device on some mower
Jul 18, 2009 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Mower wants to stall when blades are engaged on a Huskee 13hp 38'' cut Tecumseh engine 6 speed on the go shift
Jun 23, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
